Just checked… even the X370 taichi has been updated for Ryzen 3000 support. So… if you had to go cheap you could even drop down to an x370 (or maybe even B350) board plus the cheapest grottiest AM4 Athlon you can find in order to flash the bios and then run a ryzen 3000 in it…
Sticking a 3900X on a cheapo B350 mb
next will be an A320
You can fast fwd to 12 min mark to get past the boring bios update.
No re-install of Win10 either, no Precision OC support
MC has a few 50 dollar off deals on CPU/MB combos
Anyone know what the cheapest bottem barrel trash Motherboard that supports precision OC?
The Radeon 5700 and RTX2060 Super are two very interesting mid range competitors.
Depending on the price differences and games you play,
those are two very interesting cards to look at.
The 5700XT is also a pretty nice card at $400,-, but the 5700 might be a better bang for buck card.
Depending on the price i’m pretty interested in the Radeon 5700.
I also think that Radeon cards generally age better.
It may be good value, but it’s potential is gimped by a artificial clock limit. Gone are the days when you can flash a 480 to a 580, because secure boot has now prevented pretty much all VBIOS modding.
I did some investigation and it’s confirmed write performance isn’t great, but don’t forget half the lg frame fits in cache. This will have to be tested.
The thing is, I found it in one store…
Once the other stores push it, it will drop a bit, but I don’t expect it to go much cheaper…
For perspective, the cheapest 2070 is 508 euros and it’s slower than 5700XT… Supers are nowhere to be seen on the local market. 2060 goes below 400 euros though…
A BIOS update completely changed their boosting behavior. Blue line is the clocks with the original Bios they used in their first review. Orange is with one that released late yesterday
