Hello all.
I have been having annoying problem recently again, which are CPU#3 soft lockup. These lockups starting occurring again after about 20 days after a fix from this site, link:
The soft lockup only happens at boot up. Now they don’t happen as often as they did, but they do happen almost every time I boot. This time I only have to reboot once instead of up to 4 - 6 times before the fix mentioned in the link.
I went through journalctl and didn’t see any issues regarding this exact problem. I did not know how much info from journalctl I should put here.
júl 25 05:33:29 OVG-ACER kernel: Freeing SMP alternatives memory: 28K
júl 25 05:33:29 OVG-ACER kernel: smpboot: CPU0: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx (family: 0x17, model: 0x11, stepping: 0>
júl 25 05:33:29 OVG-ACER kernel: Performance Events: Fam17h core perfctr, AMD PMU driver.
júl 25 05:33:29 OVG-ACER kernel: ... version: 0
júl 25 05:33:29 OVG-ACER kernel: ... bit width: 48
júl 25 05:33:29 OVG-ACER kernel: ... generic registers: 6
júl 25 05:33:29 OVG-ACER kernel: ... value mask: 0000ffffffffffff
júl 25 05:33:29 OVG-ACER kernel: ... max period: 00007fffffffffff
júl 25 05:33:29 OVG-ACER kernel: ... fixed-purpose events: 0
júl 25 05:33:29 OVG-ACER kernel: ... event mask: 000000000000003f
júl 25 05:33:29 OVG-ACER kernel: Hierarchical SRCU implementation.
júl 25 05:33:29 OVG-ACER kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
júl 25 05:33:29 OVG-ACER kernel: smp: Bringing up secondary CPUs ...
júl 25 05:33:29 OVG-ACER kernel: x86: Booting SMP configuration:
júl 25 05:33:29 OVG-ACER kernel: .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
júl 25 05:33:29 OVG-ACER kernel: smp: Brought up 1 node, 8 CPUs
júl 25 05:33:29 OVG-ACER kernel: smpboot: Max logical packages: 2
júl 25 05:33:29 OVG-ACER kernel: smpboot: Total of 8 processors activated (31950.20 BogoMIPS)
júl 25 05:33:29 OVG-ACER kernel: devtmpfs: initialized
júl 25 05:33:29 OVG-ACER kernel: x86/mm: Memory block size: 128MB
júl 25 05:33:29 OVG-ACER kernel: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f09fff] (40960 bytes)
júl 25 05:33:29 OVG-ACER kernel: PM: Registering ACPI NVS region [mem 0x8d7bf000-0x8f7befff] (33554432 bytes)
júl 25 05:33:29 OVG-ACER kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
júl 25 05:33:29 OVG-ACER kernel: futex hash table entries: 4096 (order: 6, 262144 bytes)
júl 25 05:33:29 OVG-ACER kernel: pinctrl core: initialized pinctrl subsystem
júl 25 05:33:29 OVG-ACER kernel: RTC time: 5:33:27, date: 07/25/18
júl 25 05:33:29 OVG-ACER kernel: NET: Registered protocol family 16
júl 25 05:33:29 OVG-ACER kernel: cpuidle: using governor ladder
júl 25 05:33:29 OVG-ACER kernel: cpuidle: using governor menu
júl 25 05:33:29 OVG-ACER kernel: Simple Boot Flag at 0x44 set to 0x1
júl 25 05:33:29 OVG-ACER kernel: ACPI: bus type PCI registered
júl 25 05:33:29 OVG-ACER kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
júl 25 05:33:29 OVG-ACER kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
júl 25 05:33:29 OVG-ACER kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
júl 25 05:33:29 OVG-ACER kernel: PCI: Using configuration type 1 for base access
júl 25 05:33:29 OVG-ACER kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
júl 25 05:33:29 OVG-ACER kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
júl 25 05:33:29 OVG-ACER kernel: ACPI: Added _OSI(Module Device)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Added _OSI(Processor Device)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Added _OSI(Processor Aggregator Device)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Added _OSI(Linux-Dell-Video)
júl 25 05:33:29 OVG-ACER kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
júl 25 05:33:29 OVG-ACER kernel: ACPI: 10 ACPI AML tables successfully acquired and loaded
júl 25 05:33:29 OVG-ACER kernel: ACPI: EC: EC started
júl 25 05:33:29 OVG-ACER kernel: ACPI: EC: interrupt blocked
júl 25 05:33:29 OVG-ACER kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Used as first EC
júl 25 05:33:29 OVG-ACER kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
júl 25 05:33:29 OVG-ACER kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Used as boot DSDT EC to handle transactions
júl 25 05:33:29 OVG-ACER kernel: ACPI: Interpreter enabled
júl 25 05:33:29 OVG-ACER kernel: ACPI: (supports S0 S3 S4 S5)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Using IOAPIC for interrupt routing
júl 25 05:33:29 OVG-ACER kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
júl 25 05:33:29 OVG-ACER kernel: ACPI: Enabled 2 GPEs in block 00 to 1F
júl 25 05:33:29 OVG-ACER kernel: ACPI: Power Resource [P0ST] (on)
júl 25 05:33:29 OVG-ACER kernel: ACPI: Power Resource [P3ST] (on)
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
júl 25 05:33:29 OVG-ACER kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
júl 25 05:33:29 OVG-ACER kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
júl 25 05:33:29 OVG-ACER kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this br>
júl 25 05:33:29 OVG-ACER kernel: PCI host bridge to bus 0000:00
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfed3ffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.6: [1022:15d3] type 01 class 0x060400
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.6: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.7: [1022:15d3] type 01 class 0x060400
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.7: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.2: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: [10ec:5287] type 00 class 0xff0000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: reg 0x10: [mem 0xe0905000-0xe0905fff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: reg 0x30: [mem 0xffff0000-0xffffffff pref]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: supports D1 D2
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: [10ec:8168] type 00 class 0x020000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: reg 0x10: [io 0x2000-0x20ff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: reg 0x18: [mem 0xe0904000-0xe0904fff 64bit]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: reg 0x20: [mem 0xe0900000-0xe0903fff 64bit]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: supports D1 D2
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.1: PME# supported from D0 D1 D2 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.6: PCI bridge to [bus 01]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.6: bridge window [io 0x2000-0x2fff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.6: bridge window [mem 0xe0900000-0xe09fffff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:02:00.0: [168c:0042] type 00 class 0x028000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:02:00.0: reg 0x10: [mem 0xe0200000-0xe03fffff 64bit]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.7: PCI bridge to [bus 02]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:01.7: bridge window [mem 0xe0200000-0xe03fffff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: [1002:15dd] type 00 class 0x030000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: reg 0x20: [io 0x1000-0x10ff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: reg 0x24: [mem 0xe0800000-0xe087ffff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: BAR 0: assigned to efifb
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.1: [1002:15de] type 00 class 0x040300
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.1: reg 0x10: [mem 0xe0888000-0xe088bfff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.1: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.1: PME# supported from D1 D2 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.2: [1022:15df] type 00 class 0x108000
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.2: reg 0x18: [mem 0xe0700000-0xe07fffff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.2: reg 0x24: [mem 0xe088c000-0xe088dfff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.2: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.3: [1022:15e0] type 00 class 0x0c0330
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.3: reg 0x10: [mem 0xe0600000-0xe06fffff 64bit]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.3: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.3: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.4: [1022:15e1] type 00 class 0x0c0330
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.4: reg 0x10: [mem 0xe0500000-0xe05fffff 64bit]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.4: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.4: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.6: [1022:15e3] type 00 class 0x040300
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.6: reg 0x10: [mem 0xe0880000-0xe0887fff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.6: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.6: PME# supported from D0 D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: PCI bridge to [bus 03]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: bridge window [io 0x1000-0x1fff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: bridge window [mem 0xe0500000-0xe08fffff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.1: bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:04:00.0: [1022:7901] type 00 class 0x010601
júl 25 05:33:29 OVG-ACER kernel: pci 0000:04:00.0: reg 0x24: [mem 0xe0400000-0xe04007ff]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:04:00.0: enabling Extended Tags
júl 25 05:33:29 OVG-ACER kernel: pci 0000:04:00.0: PME# supported from D3hot D3cold
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.2: PCI bridge to [bus 04]
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:08.2: bridge window [mem 0xe0400000-0xe04fffff]
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 5 6 10 11) *0, disabled.
júl 25 05:33:29 OVG-ACER kernel: ACPI: EC: interrupt unblocked
júl 25 05:33:29 OVG-ACER kernel: ACPI: EC: event unblocked
júl 25 05:33:29 OVG-ACER kernel: ACPI: \_SB_.PCI0.LPC0.EC0_: Used as boot DSDT EC to handle transactions and events
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: vgaarb: bridge control possible
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.0: vgaarb: setting as boot device
júl 25 05:33:29 OVG-ACER kernel: vgaarb: loaded
júl 25 05:33:29 OVG-ACER kernel: pps_core: LinuxPPS API ver. 1 registered
júl 25 05:33:29 OVG-ACER kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
júl 25 05:33:29 OVG-ACER kernel: PTP clock support registered
júl 25 05:33:29 OVG-ACER kernel: EDAC MC: Ver: 3.0.0
júl 25 05:33:29 OVG-ACER kernel: Registered efivars operations
júl 25 05:33:29 OVG-ACER kernel: PCI: Using ACPI for IRQ routing
júl 25 05:33:29 OVG-ACER kernel: PCI: pci_cache_line_size set to 64 bytes
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x00087000-0x0008ffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x09b00000-0x0bffffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x842aa000-0x87ffffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x8b5bf000-0x8bffffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x8f800000-0x8fffffff]
júl 25 05:33:29 OVG-ACER kernel: e820: reserve RAM buffer [mem 0x1af340000-0x1afffffff]
júl 25 05:33:29 OVG-ACER kernel: NetLabel: Initializing
júl 25 05:33:29 OVG-ACER kernel: NetLabel: domain hash size = 128
júl 25 05:33:29 OVG-ACER kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
júl 25 05:33:29 OVG-ACER kernel: NetLabel: unlabeled traffic allowed by default
júl 25 05:33:29 OVG-ACER kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
júl 25 05:33:29 OVG-ACER kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
júl 25 05:33:29 OVG-ACER kernel: clocksource: Switched to clocksource tsc-early
júl 25 05:33:29 OVG-ACER kernel: VFS: Disk quotas dquot_6.6.0
júl 25 05:33:29 OVG-ACER kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
júl 25 05:33:29 OVG-ACER kernel: pnp: PnP ACPI init
júl 25 05:33:29 OVG-ACER kernel: system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:00: [mem 0xfda00000-0xfdafffff] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
júl 25 05:33:29 OVG-ACER kernel: pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
júl 25 05:33:29 OVG-ACER kernel: pnp 00:02: Plug and Play ACPI device, IDs FUJ7401 PNP0303 (active)
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0400-0x04cf] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x04d0-0x04d1] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x04d6] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0c00-0x0c01] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0c14] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0c50-0x0c52] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0c6c] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0c6f] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: [io 0x0cd0-0x0cdb] has been reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
júl 25 05:33:29 OVG-ACER kernel: system 00:04: [mem 0x000e0000-0x000fffff] could not be reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:04: [mem 0xff800000-0xffffffff] could not be reserved
júl 25 05:33:29 OVG-ACER kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c01 (active)
júl 25 05:33:29 OVG-ACER kernel: pnp: PnP ACPI: found 5 devices
júl 25 05:33:29 OVG-ACER kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: can't claim BAR 6 [mem 0xffff0000-0xffffffff pref]: no compatible bridge window
júl 25 05:33:29 OVG-ACER kernel: pci 0000:01:00.0: BAR 6: assigned [mem 0xe0910000-0xe091ffff pref]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 19 [mem 0xd0000000-0xf7ffffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:00: resource 20 [mem 0xfc000000-0xfed3ffff window]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:01: resource 1 [mem 0xe0900000-0xe09fffff]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:02: resource 1 [mem 0xe0200000-0xe03fffff]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:03: resource 1 [mem 0xe0500000-0xe08fffff]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:03: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
júl 25 05:33:29 OVG-ACER kernel: pci_bus 0000:04: resource 1 [mem 0xe0400000-0xe04fffff]
júl 25 05:33:29 OVG-ACER kernel: NET: Registered protocol family 2
júl 25 05:33:29 OVG-ACER kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
júl 25 05:33:29 OVG-ACER kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
júl 25 05:33:29 OVG-ACER kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
júl 25 05:33:29 OVG-ACER kernel: TCP: Hash tables configured (established 65536 bind 65536)
júl 25 05:33:29 OVG-ACER kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
júl 25 05:33:29 OVG-ACER kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.1: Linked as a consumer to 0000:03:00.0
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.3: quirk_usb_early_handoff+0x0/0x6c6 took 12647 usecs
júl 25 05:33:29 OVG-ACER kernel: pci 0000:03:00.4: quirk_usb_early_handoff+0x0/0x6c6 took 19021 usecs
júl 25 05:33:29 OVG-ACER kernel: PCI: CLS 64 bytes, default 64
júl 25 05:33:29 OVG-ACER kernel: Unpacking initramfs...
júl 25 05:33:29 OVG-ACER kernel: Freeing initrd memory: 9228K
júl 25 05:33:29 OVG-ACER kernel: AMD-Vi: Unable to write to IOMMU perf counter.
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
júl 25 05:33:29 OVG-ACER kernel: pci 0000:00:00.2: PCI INT A: not connected
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:01.0 to group 0
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:01.6 to group 1
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:01.7 to group 2
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:08.0 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:08.1 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:08.2 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:14.0 to group 4
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:14.3 to group 4
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.0 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.1 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.2 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.3 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.4 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.5 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.6 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:00:18.7 to group 5
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:01:00.0 to group 6
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:01:00.1 to group 6
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:02:00.0 to group 7
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.0 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.1 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.2 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.3 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.4 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:03:00.6 to group 3
júl 25 05:33:29 OVG-ACER kernel: iommu: Adding device 0000:04:00.0 to group 3
júl 25 05:33:29 OVG-ACER kernel: AMD-Vi: Found IOMMU at 0000:00:00.2 cap 0x40
júl 25 05:33:29 OVG-ACER kernel: AMD-Vi: Extended features (0x4f77ef22294ada):
júl 25 05:33:29 OVG-ACER kernel: PPR NX GT IA GA PC GA_vAPIC
júl 25 05:33:29 OVG-ACER kernel: AMD-Vi: Lazy IO/TLB flushing enabled
júl 25 05:33:29 OVG-ACER kernel: amd_uncore: AMD NB counters detected
júl 25 05:33:29 OVG-ACER kernel: amd_uncore: AMD LLC counters detected
júl 25 05:33:29 OVG-ACER kernel: Scanning for low memory corruption every 60 seconds
júl 25 05:33:29 OVG-ACER kernel: Initialise system trusted keyrings
júl 25 05:33:29 OVG-ACER kernel: Key type blacklist registered
júl 25 05:33:29 OVG-ACER kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
júl 25 05:33:29 OVG-ACER kernel: zbud: loaded
júl 25 05:33:29 OVG-ACER kernel: pstore: using lz4hc compression
júl 25 05:33:29 OVG-ACER kernel: Key type asymmetric registered
júl 25 05:33:29 OVG-ACER kernel: Asymmetric key parser 'x509' registered
júl 25 05:33:29 OVG-ACER kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
júl 25 05:33:29 OVG-ACER kernel: io scheduler noop registered
júl 25 05:33:29 OVG-ACER kernel: io scheduler deadline registered
júl 25 05:33:29 OVG-ACER kernel: io scheduler cfq registered (default)
júl 25 05:33:29 OVG-ACER kernel: io scheduler mq-deadline registered
júl 25 05:33:29 OVG-ACER kernel: io scheduler kyber registered
júl 25 05:33:29 OVG-ACER kernel: io scheduler bfq registered
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:01.6: AER enabled with IRQ 26
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:01.7: AER enabled with IRQ 27
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:01.6: Signaling PME with IRQ 26
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:01.7: Signaling PME with IRQ 27
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:08.1: Signaling PME with IRQ 28
júl 25 05:33:29 OVG-ACER kernel: pcieport 0000:00:08.2: Signaling PME with IRQ 29
júl 25 05:33:29 OVG-ACER kernel: efifb: probing for efifb
júl 25 05:33:29 OVG-ACER kernel: efifb: framebuffer at 0xd0000000, using 8128k, total 8128k
júl 25 05:33:29 OVG-ACER kernel: efifb: mode is 1920x1080x32, linelength=7680, pages=1
júl 25 05:33:29 OVG-ACER kernel: efifb: scrolling: redraw
júl 25 05:33:29 OVG-ACER kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
júl 25 05:33:29 OVG-ACER kernel: Console: switching to colour frame buffer device 240x67
júl 25 05:33:29 OVG-ACER kernel: fb0: EFI VGA frame buffer device
júl 25 05:33:29 OVG-ACER kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
júl 25 05:33:29 OVG-ACER kernel: ACPI: Power Button [PWRB]
júl 25 05:33:29 OVG-ACER kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
júl 25 05:33:29 OVG-ACER kernel: ACPI: Sleep Button [SLPB]
júl 25 05:33:29 OVG-ACER kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:27/PNP0C0D:00/input/input2
júl 25 05:33:29 OVG-ACER kernel: ACPI: Lid Switch [LID0]
júl 25 05:33:29 OVG-ACER kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
júl 25 05:33:29 OVG-ACER kernel: ACPI: Power Button [PWRF]
júl 25 05:33:29 OVG-ACER kernel: ACPI: Video Device [VGA2] (multi-head: yes rom: no post: no)
júl 25 05:33:29 OVG-ACER kernel: acpi device:0d: registered as cooling_device0
júl 25 05:33:29 OVG-ACER kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0c/LNXVIDEO:02/input/input4
júl 25 05:33:29 OVG-ACER kernel: Monitor-Mwait will be used to enter C-1 state
júl 25 05:33:29 OVG-ACER kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
júl 25 05:33:29 OVG-ACER kernel: ledtrig-cpu: registered to indicate activity on CPUs
júl 25 05:33:29 OVG-ACER kernel: NET: Registered protocol family 10
júl 25 05:33:29 OVG-ACER kernel: Segment Routing with IPv6
júl 25 05:33:29 OVG-ACER kernel: NET: Registered protocol family 17
júl 25 05:33:29 OVG-ACER kernel: RAS: Correctable Errors collector initialized.
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU0: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU1: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU2: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU3: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU4: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU5: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU6: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: CPU7: patch_level=0x08101007
júl 25 05:33:29 OVG-ACER kernel: microcode: Microcode Update Driver: v2.2.
júl 25 05:33:29 OVG-ACER kernel: sched_clock: Marking stable (1092894359, 0)->(1432073502, -339179143)
júl 25 05:33:29 OVG-ACER kernel: registered taskstats version 1
júl 25 05:33:29 OVG-ACER kernel: Loading compiled-in X.509 certificates
júl 25 05:33:29 OVG-ACER kernel: zswap: loaded using pool lzo/zbud
júl 25 05:33:29 OVG-ACER kernel: Key type big_key registered
júl 25 05:33:29 OVG-ACER kernel: Magic number: 10:442:568
júl 25 05:33:29 OVG-ACER kernel: hctosys: unable to open rtc device (rtc0)
júl 25 05:33:29 OVG-ACER kernel: Freeing unused kernel memory: 1476K
júl 25 05:33:29 OVG-ACER kernel: Write protecting the kernel read-only data: 16384k
júl 25 05:33:29 OVG-ACER kernel: Freeing unused kernel memory: 2016K
júl 25 05:33:29 OVG-ACER kernel: Freeing unused kernel memory: 608K
júl 25 05:33:29 OVG-ACER kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
júl 25 05:33:29 OVG-ACER kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
júl 25 05:33:29 OVG-ACER kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
júl 25 05:33:29 OVG-ACER kernel: ACPI: bus type USB registered
júl 25 05:33:29 OVG-ACER kernel: usbcore: registered new interface driver usbfs
júl 25 05:33:29 OVG-ACER kernel: usbcore: registered new interface driver hub
júl 25 05:33:29 OVG-ACER kernel: usbcore: registered new device driver usb
júl 25 05:33:29 OVG-ACER kernel: SCSI subsystem initialized
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.3: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 1
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x40000410
júl 25 05:33:29 OVG-ACER kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.17
júl 25 05:33:29 OVG-ACER kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
júl 25 05:33:29 OVG-ACER kernel: usb usb1: Product: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: usb usb1: Manufacturer: Linux 4.17.8-1-ARCH xhci-hcd
júl 25 05:33:29 OVG-ACER kernel: usb usb1: SerialNumber: 0000:03:00.3
júl 25 05:33:29 OVG-ACER kernel: hub 1-0:1.0: USB hub found
júl 25 05:33:29 OVG-ACER kernel: hub 1-0:1.0: 4 ports detected
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 2
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.3: Host supports USB 3.10 Enhanced SuperSpeed
júl 25 05:33:29 OVG-ACER kernel: usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
júl 25 05:33:29 OVG-ACER kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.17
júl 25 05:33:29 OVG-ACER kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
júl 25 05:33:29 OVG-ACER kernel: usb usb2: Product: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: usb usb2: Manufacturer: Linux 4.17.8-1-ARCH xhci-hcd
júl 25 05:33:29 OVG-ACER kernel: usb usb2: SerialNumber: 0000:03:00.3
júl 25 05:33:29 OVG-ACER kernel: hub 2-0:1.0: USB hub found
júl 25 05:33:29 OVG-ACER kernel: hub 2-0:1.0: 4 ports detected
júl 25 05:33:29 OVG-ACER kernel: usb: port power management may be unreliable
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.4: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.4: new USB bus registered, assigned bus number 3
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x40000410
júl 25 05:33:29 OVG-ACER kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.17
júl 25 05:33:29 OVG-ACER kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
júl 25 05:33:29 OVG-ACER kernel: usb usb3: Product: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: usb usb3: Manufacturer: Linux 4.17.8-1-ARCH xhci-hcd
júl 25 05:33:29 OVG-ACER kernel: usb usb3: SerialNumber: 0000:03:00.4
júl 25 05:33:29 OVG-ACER kernel: hub 3-0:1.0: USB hub found
júl 25 05:33:29 OVG-ACER kernel: hub 3-0:1.0: 2 ports detected
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.4: new USB bus registered, assigned bus number 4
júl 25 05:33:29 OVG-ACER kernel: xhci_hcd 0000:03:00.4: Host supports USB 3.10 Enhanced SuperSpeed
júl 25 05:33:29 OVG-ACER kernel: usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
júl 25 05:33:29 OVG-ACER kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.17
júl 25 05:33:29 OVG-ACER kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
júl 25 05:33:29 OVG-ACER kernel: usb usb4: Product: xHCI Host Controller
júl 25 05:33:29 OVG-ACER kernel: usb usb4: Manufacturer: Linux 4.17.8-1-ARCH xhci-hcd
júl 25 05:33:29 OVG-ACER kernel: usb usb4: SerialNumber: 0000:03:00.4
júl 25 05:33:29 OVG-ACER kernel: hub 4-0:1.0: USB hub found
júl 25 05:33:29 OVG-ACER kernel: hub 4-0:1.0: 1 port detected
júl 25 05:33:29 OVG-ACER kernel: libata version 3.00 loaded.
júl 25 05:33:29 OVG-ACER kernel: ahci 0000:04:00.0: version 3.0
júl 25 05:33:29 OVG-ACER kernel: ahci 0000:04:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x2 impl SATA mode
júl 25 05:33:29 OVG-ACER kernel: ahci 0000:04:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
júl 25 05:33:29 OVG-ACER kernel: scsi host0: ahci
júl 25 05:33:29 OVG-ACER kernel: scsi host1: ahci
júl 25 05:33:29 OVG-ACER kernel: ata1: DUMMY
júl 25 05:33:29 OVG-ACER kernel: ata2: SATA max UDMA/133 abar m2048@0xe0400000 port 0xe0400180 irq 51
júl 25 05:33:29 OVG-ACER kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
júl 25 05:33:29 OVG-ACER kernel: usb 1-1: new low-speed USB device number 2 using xhci_hcd
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: new high-speed USB device number 2 using xhci_hcd
júl 25 05:33:29 OVG-ACER kernel: tsc: Refined TSC clocksource calibration: 1996.258 MHz
júl 25 05:33:29 OVG-ACER kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x398cbed4ccd, max_idle_ns: 881590514681 ns
júl 25 05:33:29 OVG-ACER kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
júl 25 05:33:29 OVG-ACER kernel: ata2.00: ATA-9: HFS256G39TND-N210A, 30001P10, max UDMA/133
júl 25 05:33:29 OVG-ACER kernel: ata2.00: 500118192 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
júl 25 05:33:29 OVG-ACER kernel: ata2.00: configured for UDMA/133
júl 25 05:33:29 OVG-ACER kernel: scsi 1:0:0:0: Direct-Access ATA HFS256G39TND-N21 1P10 PQ: 0 ANSI: 5
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] 500118192 512-byte logical blocks: (256 GB/238 GiB)
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] 4096-byte physical blocks
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] Write Protect is off
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
júl 25 05:33:29 OVG-ACER kernel: sda: sda1 sda2 sda3 sda4
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: [sda] Attached SCSI disk
júl 25 05:33:29 OVG-ACER kernel: usb 1-1: New USB device found, idVendor=093a, idProduct=2521, bcdDevice= 1.00
júl 25 05:33:29 OVG-ACER kernel: usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
júl 25 05:33:29 OVG-ACER kernel: usb 1-1: Product: USB OPTICAL MOUSE
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: New USB device found, idVendor=0bda, idProduct=5648, bcdDevice= 0.06
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: Product: VGA WebCam
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: Manufacturer: KSVGA0500181201E56LM06
júl 25 05:33:29 OVG-ACER kernel: usb 3-1: SerialNumber: 200901010001
júl 25 05:33:29 OVG-ACER kernel: hidraw: raw HID events driver (C) Jiri Kosina
júl 25 05:33:29 OVG-ACER kernel: usbcore: registered new interface driver usbhid
júl 25 05:33:29 OVG-ACER kernel: usbhid: USB HID core driver
júl 25 05:33:29 OVG-ACER kernel: input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:08.1/0000:03:00.3/usb1/1-1/1-1:1.0/0003:093A>
júl 25 05:33:29 OVG-ACER kernel: hid-generic 0003:093A:2521.0001: input,hidraw0: USB HID v1.11 Mouse [USB OPTICAL MOUSE] on usb-0000:>
júl 25 05:33:29 OVG-ACER kernel: PM: Image not found (code -22)
júl 25 05:33:29 OVG-ACER kernel: random: fast init done
júl 25 05:33:29 OVG-ACER kernel: EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
júl 25 05:33:29 OVG-ACER kernel: usb 1-4: new full-speed USB device number 3 using xhci_hcd
júl 25 05:33:29 OVG-ACER systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP >
júl 25 05:33:29 OVG-ACER systemd[1]: Detected architecture x86-64.
júl 25 05:33:29 OVG-ACER systemd[1]: Set hostname to <OVG-ACER>.
júl 25 05:33:29 OVG-ACER kernel: usb 1-4: New USB device found, idVendor=04ca, idProduct=3015, bcdDevice= 0.01
júl 25 05:33:29 OVG-ACER kernel: usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
júl 25 05:33:29 OVG-ACER kernel: random: systemd: uninitialized urandom read (16 bytes read)
júl 25 05:33:29 OVG-ACER systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
júl 25 05:33:29 OVG-ACER systemd[1]: Listening on Process Core Dump Socket.
júl 25 05:33:29 OVG-ACER systemd[1]: Listening on Journal Socket (/dev/log).
júl 25 05:33:29 OVG-ACER systemd[1]: Created slice User and Session Slice.
júl 25 05:33:29 OVG-ACER systemd[1]: Reached target Login Prompts.
júl 25 05:33:29 OVG-ACER systemd[1]: Listening on LVM2 metadata daemon socket.
júl 25 05:33:29 OVG-ACER systemd[1]: Listening on Journal Socket.
júl 25 05:33:29 OVG-ACER kernel: EXT4-fs (sda3): re-mounted. Opts: discard
júl 25 05:33:29 OVG-ACER kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
júl 25 05:33:29 OVG-ACER systemd-journald[246]: Journal started
júl 25 05:33:29 OVG-ACER systemd-journald[246]: Runtime journal (/run/log/journal/35e6a9199c0340b8bb2740a1f45c0e24) is 8.0M, max 245.>
júl 25 05:33:29 OVG-ACER kernel: vboxdrv: loading out-of-tree module taints kernel.
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'crypto_user'
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'sg'
júl 25 05:33:29 OVG-ACER systemd[1]: Starting Flush Journal to Persistent Storage...
júl 25 05:33:29 OVG-ACER kernel: vboxdrv: Found 8 processor cores
júl 25 05:33:29 OVG-ACER systemd[1]: Started Create System Users.
júl 25 05:33:29 OVG-ACER systemd[1]: Starting Create Static Device Nodes in /dev...
júl 25 05:33:29 OVG-ACER systemd-journald[246]: Time spent on flushing to /var is 63.346ms for 744 entries.
júl 25 05:33:29 OVG-ACER systemd-journald[246]: System journal (/var/log/journal/35e6a9199c0340b8bb2740a1f45c0e24) is 656.0M, max 4.0>
júl 25 05:33:29 OVG-ACER kernel: vboxdrv: TSC mode is Invariant, tentative frequency 1996255663 Hz
júl 25 05:33:29 OVG-ACER kernel: vboxdrv: Successfully loaded version 5.2.16 (interface 0x00290001)
júl 25 05:33:29 OVG-ACER kernel: VBoxPciLinuxInit
júl 25 05:33:29 OVG-ACER kernel: vboxpci: IOMMU found
júl 25 05:33:29 OVG-ACER kernel: VBoxNetAdp: Successfully started.
júl 25 05:33:29 OVG-ACER kernel: VBoxNetFlt: Successfully started.
júl 25 05:33:29 OVG-ACER systemd[1]: Started udev Coldplug all Devices.
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'vboxdrv'
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'vboxpci'
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'vboxnetadp'
júl 25 05:33:29 OVG-ACER systemd-modules-load[256]: Inserted module 'vboxnetflt'
júl 25 05:33:29 OVG-ACER systemd[1]: Started Load Kernel Modules.
júl 25 05:33:29 OVG-ACER systemd[1]: Started Create Static Device Nodes in /dev.
júl 25 05:33:29 OVG-ACER systemd[1]: Starting udev Kernel Device Manager...
júl 25 05:33:29 OVG-ACER systemd[1]: Starting Apply Kernel Variables...
júl 25 05:33:29 OVG-ACER systemd[1]: Mounting Kernel Configuration File System...
júl 25 05:33:29 OVG-ACER systemd[1]: Mounted Kernel Configuration File System.
júl 25 05:33:29 OVG-ACER systemd[1]: Started Apply Kernel Variables.
júl 25 05:33:29 OVG-ACER systemd[1]: Started udev Kernel Device Manager.
júl 25 05:33:29 OVG-ACER systemd[1]: Started Flush Journal to Persistent Storage.
júl 25 05:33:29 OVG-ACER kernel: acpi_cpufreq: overriding BIOS provided _PSD data
júl 25 05:33:29 OVG-ACER kernel: input: Acer Wireless Radio Control as /devices/LNXSYSTM:00/10251229:00/input/input7
júl 25 05:33:29 OVG-ACER kernel: random: crng init done
júl 25 05:33:29 OVG-ACER kernel: random: 7 urandom warning(s) missed due to ratelimiting
júl 25 05:33:39 OVG-ACER lvm[252]: WARNING: Device /dev/sda1 not initialized in udev database even after waiting 10000000 microseco>
júl 25 05:33:41 OVG-ACER kernel: acpi AMDI0010:01: Already enumerated
-- Reboot --
And the second one is from about 20 minutes of writing this post.
júl 25 20:02:03 OVG-ACER tracker-extract[7559]: If the error above is recurrent for the same item/ID, consider running "tracker-extra>
júl 25 20:02:14 OVG-ACER dbus-daemon[787]: [session uid=1000 pid=787] Activating via systemd: service name='org.freedesktop.Tracker1.>
júl 25 20:02:14 OVG-ACER systemd[767]: Starting Tracker metadata extractor...
júl 25 20:02:15 OVG-ACER dbus-daemon[787]: [session uid=1000 pid=787] Successfully activated service 'org.freedesktop.Tracker1.Miner.>
júl 25 20:02:15 OVG-ACER systemd[767]: Started Tracker metadata extractor.
júl 25 20:02:15 OVG-ACER tracker-extract[7583]: Could not insert metadata for item "file:///home/olividir/Skj%C3%B6l/H%C3%A1sk%C3%B3l>
júl 25 20:02:15 OVG-ACER tracker-extract[7583]: If the error above is recurrent for the same item/ID, consider running "tracker-extra>
júl 25 20:02:15 OVG-ACER tracker-extract[7583]: Could not insert metadata for item "file:///home/olividir/T%C3%B3nlist/Interpol%20Dis>
júl 25 20:02:26 OVG-ACER dbus-daemon[787]: [session uid=1000 pid=787] Activating via systemd: service name='org.freedesktop.Tracker1.>
júl 25 20:02:26 OVG-ACER systemd[767]: Starting Tracker metadata extractor...
júl 25 20:02:27 OVG-ACER dbus-daemon[787]: [session uid=1000 pid=787] Successfully activated service 'org.freedesktop.Tracker1.Miner.>
júl 25 19:41:18 OVG-ACER kernel: Bluetooth: HCI socket layer initialized
júl 25 19:41:18 OVG-ACER kernel: Bluetooth: L2CAP socket layer initialized
júl 25 19:41:18 OVG-ACER kernel: Bluetooth: SCO socket layer initialized
júl 25 19:41:18 OVG-ACER kernel: FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
júl 25 19:40:24 OVG-ACER kernel: random: systemd: uninitialized urandom read (16 bytes read)
júl 25 19:40:24 OVG-ACER systemd[1]: Reached target Slices.
júl 25 19:40:24 OVG-ACER systemd[1]: Reached target Login Prompts.
júl 25 19:40:24 OVG-ACER systemd[1]: Starting Create list of required static device nodes for the current kernel...
júl 25 19:40:24 OVG-ACER systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
júl 25 19:40:24 OVG-ACER systemd[1]: Starting Load Kernel Modules...
júl 25 19:40:24 OVG-ACER kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
júl 25 19:40:24 OVG-ACER kernel: EXT4-fs (sda3): re-mounted. Opts: discard
júl 25 19:40:24 OVG-ACER kernel: vboxdrv: loading out-of-tree module taints kernel.
júl 25 19:40:24 OVG-ACER kernel: vboxdrv: Found 8 processor cores
júl 25 19:40:24 OVG-ACER systemd-journald[256]: Journal started
júl 25 19:40:24 OVG-ACER systemd-journald[256]: Runtime journal (/run/log/journal/35e6a9199c0340b8bb2740a1f45c0e24) is 8.0M, max 245.>
júl 25 19:40:24 OVG-ACER systemd-modules-load[250]: Inserted module 'crypto_user'
júl 25 19:40:24 OVG-ACER systemd-modules-load[250]: Inserted module 'sg'
júl 25 19:40:24 OVG-ACER systemd-modules-load[250]: Inserted module 'vboxdrv'
júl 25 19:40:24 OVG-ACER systemd[1]: Starting Flush Journal to Persistent Storage...
júl 25 19:40:24 OVG-ACER systemd[1]: Starting Create Static Device Nodes in /dev...
júl 25 19:40:24 OVG-ACER kernel: vboxdrv: TSC mode is Invariant, tentative frequency 1996248942 Hz
júl 25 19:40:24 OVG-ACER kernel: vboxdrv: Successfully loaded version 5.2.16 (interface 0x00290001)
júl 25 19:40:24 OVG-ACER systemd-modules-load[250]: Inserted module 'vboxpci'
júl 25 19:40:24 OVG-ACER systemd-modules-load[250]: Inserted module 'vboxnetadp'
júl 25 19:40:24 OVG-ACER kernel: VBoxPciLinuxInit
júl 25 19:40:24 OVG-ACER kernel: vboxpci: IOMMU found
júl 25 19:40:24 OVG-ACER kernel: VBoxNetAdp: Successfully started.
júl 25 19:40:24 OVG-ACER systemd-journald[256]: Time spent on flushing to /var is 43.396ms for 751 entries.
-- Reboot --
Since this is happening again for me, I have no idea of where I should look for answers.
It would be very nice to get rid of this problem.
Thank you for your time.
lscpu is:
[olividir@OVG-ACER ~]$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: AuthenticAMD
CPU family: 23
Model: 17
Model name: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
Stepping: 0
CPU MHz: 1481.152
CPU max MHz: 2000,0000
CPU min MHz: 1600,0000
BogoMIPS: 3994.90
Virtualization: AMD-V
L1d cache: 32K
L1i cache: 64K
L2 cache: 512K
L3 cache: 4096K
NUMA node0 CPU(s): 0-7
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw skinit wdt tce topoext perfctr_core perfctr_nb bpext perfctr_llc mwaitx hw_pstate sme ssbd sev ibpb vmmcall fsgsbase bmi1 avx2 smep bmi2 rdseed adx smap clflushopt sha_ni xsaveopt xsavec xgetbv1 xsaves clzero irperf xsaveerptr arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov succor smca
