I am looking to do a custom red and white theme for my next project and was in hope that people here would be able to help me find I list of parts that are about 80% red and white, some black is fine. Intel or AMD for CPU and hopes of going with AMD for graphics.
I am hoping for mostly white as I will be adding a red water cooling loop.
As of right now, no budget really. I plan on taking my time with this build and so I would love to find something high end as to not have it too outdated in a year or two
That doesn't help at all, what budget, because you could easily just save up for a 22 core Xeon and dual Radeon Pro Duos
If you want a crazy small high end build actually you could go for a Define Nano S with the Radeon Pro Duo and do your water cooling that way on the CPU. which would probably be like a 5820K
Well start here I guess, CPU is a bit overkill but whatever, you'd be fine with an i7 6700(non K)
I mean I guess the RAM is red, other parts are just economical. You're probably going to want a Define R5 or S, or spend the money for a caselabs case which are easily the best water cooling cases
CPU Intel Core i7-5820K 3.3GHz 6-Core Processor $369.99
Motherboard MSI X99A SLI KRAIT EDITION ATX LGA2011-3 Motherboard $238.00 Memory Crucial Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory $37.99 Storage A-Data Premier Pro SP900 256GB 2.5" Solid State Drive $72.99 Video Card XFX Radeon R9 Fury 4GB Triple Dissipation Video Card $499.99
Case NZXT H440 (White/Black) ATX Mid Tower Case $105.59
Power Supply FSP Group 750W 80+ Silver Certified ATX Power Supply $71.30
Base Total: $1399.54 Mail-in Rebates: -$10.00 Shipping: $6.31 Total: $1395.85
OK, here it is... White motherboard, gray SSD, bla bla bla... Get yourself a hard drive, i just showed you the SSD, because the case is H440 from NZXT... The SSD will be visible. You can really easy disassemble the case, remove the black plastic parts and paint them red... http://www.overclock3d.net/reviews/cases_cooling/nzxt_h440_custom_colour_swap/1 With the red liquid and stuff... And you can have 360 rad on the roof and 240 on the front and still have enough space for the hard drive...
And i'm just going to say it once - F*CK fractal's R5..
