Well buy the Sabertooth X99 board and paint it, that board just happens to be a solid less expensive X99 board
is this when I start to say hard mode and white pcb only, I can paint plastic on a mobo I cant exactly paint a mobo
Right, the sabertooth board has armor.
This is why I don't waste time with aesthetics lol, you tend to lose out on performance or have to waste some of the budget
MSI has the krait boards, but given the functionality of the sabertooth board it doesn't really compare
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130812
alright, well the most luck I have found so far is this http://www.newegg.com/Product/Product.aspx?Item=N82E16813132715
That's Z170 though, no point in buying the 6700K really when the 5820K costs the same
The Fatal1ty boards are red and usually aren't too bad
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157540
But just find a picture of a PC and tape it to the window of your case and call it a day.
http://pcpartpicker.com/p/sNL2K8
Updated with the red ram and everything...
You can also think about those:
Bitfenix Alchemy
Cant find them in the part picker...
