I’ve resorted to using MPV for playing FLACs, Clementine uses 10%+ CPU all the time, Foobar is nowhere near complete, Tomahawk was also resoruce heavy.
MPV is like VLC, but more lightweight and does just play everything pretty much perfectly, without any other features than just play the thing you pressed on in your file explorer, however. So as a music player/library manager for like 2k music files… no, thank you very much. But it´s a great replacement for VLC for the most part. VLC can do other things like converting and cutting videos even, if you need to and lack a proper editor at the time. So for that reason, I keep VLC around as well “just in case” it might be doing something I might eventually need that MPV does not, but I really only use MPV now. Not like it costs anything to install both though.
