Like Zibob says, it’s most likely a capacitor. These things happen, even in the best products. It can, to some degree, be less likely to happen, if you buy parts that are MIL Spec, but it’s impossible to prevent.
It is possible to replace it with a relatively cheap part, but you SERIOUSLY have to watch what you’re doing if you chose to do so. Unless you know what you’re doing, or know someone that can do it for you, don’t.
The same basically happened to a Corsair HX850i of me.
I guess there were a few bad Actors on the same outlet that probably influenced the PSU to fail prematurely.
Something on the AC side caused sparks and such without actual burn-marks etc.
The good thing and message i wanted to relay is that since that happened on the AC Side, all Protections did their work and nothing happened on the component and DC side.
Just a dead PSU.
yea, thanks for the endorsment, but i havn’t jet figured out if i’m the problem or if it’s indeed the switches.
Cherrys are cherrys and shouldn’t have those problems.
if it turns out to be the switches, i’ll totally replace them.
For now, this weekend is stufffed full enough though.
Have to replace a few dead DDR4 chips on some Dimms : D
You can assemble your system here and this way get the total power requirement. A good idea is to always go a bit bigger than what’s needed. When I build systems, I always make sure the PSU can deliver what’s needed + 10-15%, so PSU is running at around 85-90% load when everything is running at full speed.
I think the problem is either input spike or just a bad cap which blew. If you want to be certain, you’ll have to lift the lid of the PSU and see if the blown cap is on the AC or DC side. Just follow the leads forward or backward depending on which side you start.
Just don’t stick your fingers in there, at least on AC side of the PSU.
I’d think that a PSU is electrically separated, to prevent hardware from being destroyed incase of a spike in supply.
Also, caps are used to stabilize the voltage on the input side (noise cancellation), which flatten these spikes, on the output side they act as battery/buffer also to stabilize.
Someone correct me if I’m wrong please, 20 years since I learned about analogue electronics.
There should be good isolation between input and output side. Yet there are a few failure modes wich can lead to high voltage making its way to the output side.
