The electric company must love you.
Or maybe this guy.
@anon79053375
I like this a lot. I donāt know why.
Needs more anime on the walls xD
Just getting a basic work area setup over the weekend. Messy but it works for now while I look for a larger desk. Right now Iām using a heavy 5ā table.
Theyāre all over in the apart ^^
Specs?
Not 100% sure what Iām looking at.
I5 4690k
ECS Z97I-Drone ITX mobo
R9 380 4GB
Noctua Fans and U9S heatshink
120GB Kingston v300 SSD
2x 1TB WD Blueās
16GB Patriot Viper 3 DDR3 ram
CoolerMaster G650M PSU
Wheel Setup
GT Omega wheel stand
Thrustmaster TX FFB wheel, TM28 Leather Rim, TH8A Shifter, T3PA Pro pedals
Ive posted on here before but itās been a good year to 2 yearsā¦
Thatās a damn good system. I remember a friend of mine had a z87 ITX system that was similar. How are you liking the wheel? Iāve been thinking about getting one, but theyāre a hell of an investment (well, relatively speaking)
I quiet like it, I started with a Thrustmaster TMX and its been quiet an investment no doubt but the hours spent in assetto corsa and Iracing where well worth itā¦
As for the TX, the standard āferrari 458ā rim is garbage and has horrible grip, I bought the TM28 leather within the first week and it feels amazing it feels like the leather rim from my starion just a lil smaller. The base is great and is butter smooth compared what Iāve used in the past. The T3PA Proās to me are meh there a great set but I used a pair of clubsport v2 at a friends recently and my heart is set on those, only buy the proās if the with in $10-$20 range of the standard T3PA, the shifter is amazing I have no faults with it shifts are solid with a bit of a longer throw than a modern shifter in a car if only it was bit easier to switch shift modes⦠The stand Iām having some complications with it holds everything well but its not as sturdy as Iād like. Iām sketching up some 8020 models in some CAD software to replace it.
You should check out Synergy. https://symless.com/synergy
In case you want to use one keyboard/mouse for both rigs rather than having to constantly switch between two.
was slightly hesitant to give this a like⦠pc on floor cringes but at least itās not carpet
I donāt like it either. Need to find a piece of wood to make a small platform I can put it on then. And I would never put a PC with the PSU facing down on a carpet. Iām not a monster.
@WolfTech716 Thats the NZXT H440 v2 matte black windowed.
I was a bit worried about dust, though. It shows more on black/dark colors. But since itās matte I can just wipe it off with a cloth without worrying about scratches or smudges like on shiny surfaces.
Right-angled SATA ports on the mobo arenāt the best though for this case. The cable holes next to the motherboard tray are agled (not flat) and longer connectors can bend. Maybe my SATA cables are just too stiff.
