Here are some benchmarks I did at 2560x1440. I previously had a Fury X in here. The OC was 2050MHz core and 5544MHz memory.
GTAV Fury In Car: 90.1 to 91.7 Driving: Low 80s 1080ti stock In Car: 152.9 to 157 Driving: Low 140s 1080ti OC In Car: 168.7 to 173.6 Driving: low 146.3 Note: I was driving around the prison, not the middle of downtown.
TWWarhammer Fury: 51.6 avg 1080ti stock: 101.2 avg 1080ti OC: 106.7 It really doesn't seem to care about the OC.
Overwatch Test Range Spawn Fury: 61.8 to 63 Might not be accurate, I think I maybe had the frames limited by mistake. 1080ti stock: 156.8 to 158 1080ti OC: 183 to 187
Nothing to do with the benchmarks but about your pc in terms of lighting with the yellow on the PSU and the gold fittings or whatever you should use yellow lighting if you can inside that case. Are those lights able to be changed?
