First thought is to put something flat over it and hammer it indirectly, but idk if I can improve results with temp or other tricks. I have a decent array of tools but don’t know much about metal (hobby is woodworking).
I have once used the rubber hammer and a piece of wood with a cloth on the other side and straightened the thing, but it was not on thick metal (and probably that wasn’t the way you’re supposed to do it) but I managed to get a half decent result and the rubber hammer doesn’t damage the paint if you go gently enough…
Like fmissio95 said try to hammer it carefully with rubber hammer, and put something inside that you can hammer it against. Wood block should be good enough. Won’t look like new but should still make it bit better. If the rubber hammer isn’t enough move on to bigger hammer.
I always thought gimp was an objectively poor name. It’s just bad branding and seems infantile. On top of that, the UI is very dated and clumsy to use imho. Looking forward to a better overall ux in glimpse.
Using the adobe suite for professional-ish work I just can’t stand to use gimp for anything more than resizing pictures or small things…it just drives me crazy, this Glimpse thing seems interesting…
Yeah me too. I did download a gimp config that maps the shortcut keys like photoshop and that did make it much more useful, but still nowhere near a replacement.
