That looks clean
Somewhat reluctantly sticking with oVirt on CentOS Stream 8, but going with a vanilla OS install instead of their appliance iso to avoid LVM thin provisioning and generally reduce the footprint somewhat.
Here is my kickstart. Installs onto a Supermicro SataDOM, brings up the first onboard NIC and deploys my SSH key. I believe it should work with any RHEL distro.
clearpart --drives=disk/by-id/ata-SuperMicro_SSD* --all
zerombr
ignoredisk --only-use=disk/by-id/ata-SuperMicro_SSD*
bootloader --location=mbr
#autopart --type=lvm --fstype=ext4
part /boot --fstype=ext4 --asprimary --size=4000
part pv.01 --asprimary --size=100000 --grow
volgroup vg-001 pv.01
logvol / --vgname=vg-001 --name=root --size=32000 --fstype=ext4
logvol swap --recommended --vgname=vg-001 --name=swap
logvol /tmp --vgname=vg-001 --name=tmp --size=8000 --fstype=ext4
logvol /var --vgname=vg-001 --name=var --size=8000 --fstype=ext4 --grow
logvol /var/tmp --vgname=vg-001 --name=var-tmp --size=10000 --fstype=ext4
logvol /var/log --vgname=vg-001 --name=var-log --size=8000 --fstype=ext4
logvol /var/log/audit --vgname=vg-001 --name=var-log-audit --size=4000 --fstype=ext4
logvol /home --vgname=vg-001 --name=home --size=1000 --fstype=ext4
selinux --enforcing
rootpw --lock
network --bootproto=dhcp --device=eno1
keyboard us
lang en_US
timezone --utc America/New_York
%packages --excludeWeakdeps
@^Minimal Install
openssh-server
%end
sshkey --username=root "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAACAQDPoWEqeFgAsri67X5zNkT51frC
ZLzvfTAufpCqFaQdu7CuEmtI69t/3SlqzmZVokbH0q6OL1XQzrCFzKdgmQbdylW7AoLSEThT44BOrh+nkTO8sp89
kT3HTdRt7zmhMgN0tCrIZn5Y3Tz+Vb5vBkhFWSborIiJb9EkKx6ERDY2SR8TWGeyefoTJhx2V+Q1ULTaCEQX3I9C
0YGRybJ5x9jPGvhHlaACRBAGecBPi3ortOICZnbyMpe239gq/UIILHCET7b6kVW5FnYUa6ljSl0nrdUC7ho4DPbb
zAr88mSU9y1q/JrnYvjr6W5D2WIeZNXmxXloZD+4MxufQNUNB2BmsaL5+FhPC2tnTazWWqWPlaO3us6kG1bvbR1W
lcIxChJ4xwLOBuyKTyCFak0+hG+2CXpaJ9X37LXcYgNljfA4895Dj2HKTH/vTch8+bdpN60TDd3htWLQuipecf9x
1pM563Llsql9y66i6MV0cSLhfA2AsMTup0VYpqQb/D3HAag6rdxOJUqSA6wSmOmTrdWYHKiyJkjcBOHsQ4vFcwHk
WXpJdOmh4fV+zTWpkc2vjLUMUZy91M4/zAAIIb6fB6jo2t3sSc9frv0ScefcGbOSlaUEyBhRP8DKOO/Twl9Eq1Q9
g+vtmFvMJvlXaVjackxd7bvGjHLRrliAHmWom/woIw=="
services --enabled=sshd
reboot --eject
@PhaseLockedLoop do you know the syntax for a /23 classless PTR zone? I usually stick with /24s but I need a big boy and I remember being thoroughly frustrated by classless PTR syntax.
I think I just do 2 class c reverse zones. Itās the smaller subnets that get weird.
I havent written that one before but this should help
As should RFC2317
Hope that helps
Finally implementing SSHFP. Feels good.
Iām done. No more RHEL.
https://www.reddit.com/r/AlmaLinux/comments/1544w8b/red_hat_refuses_almas_cve_patches_to_centos/
I think I can break completely from their ecosystem with the exception of Ansible.
Suse and NixOS are new areas of interest for me. Relying heavily on Debian currently.
I mostly have relayd working as a reverse proxy with a wildcard Letsencrypt certificate. I have 3 lingering issues:
Miktrotik admin interface refuses to work. It throws
TLS handshake error: handshake failed: error:1400442E:SSL routines:CONNECT_CR_SRVR_HELLO:tlsv1 alert protocol version, GET: Undefined error: 0
which appears to be an error relating to incompatibility between the browser and TLS but this is working fine on other nearly identical forwarding instances, so Iām confusedā¦ In this case, relayd is relaying to HTTP, so there is no TLS between the proxy and server at all and TLS is resolving fine in every other instance between browser and proxy. -
noVNC doesnāt work in Proxmox while using the reverse proxy.
Various issues with checks in relayd. For proxmox, HTTPS code 200 checks do not work and might be an issue of checks using HTTP 1.0 vs HTTP 1.1. However, TLS check works fine for Proxmox. I could not get HTTPS or TLS checks to work with IPMI HTTPS interfaces despite no issues while using curl.
Also of note, relayd does not support ecdsa which is disappointing in 2023. That said, Iām still using RSA for SSH so whateverā¦
Itās cool that youāre using OpenBASED, but are you sure you donāt want to use HAProxy and use relayd instead? I have a feeling you might have a better time with the former.
I think the noVNC console fails because it needs to use some additional ports that arenāt redirected (and probably because of the http version as well, but I canāt tell). HAProxy might be able to get around that easier.
Weāll see! I am not so ideological about using OpenBSD that I will avoid using a clearly superior solution but I will put some effort into making the openbsd solution work. In this case, I have not yet put in the requisite effort to write off relayd entirely, but I might fall back on haproxy if relayd is not suitable.
Yeah I donāt know enough about HTTP and websocket to figure out how to make relayd work here unfortunately. Might come back to it, but indeed haproxy works so long as you specify balance source
so that the novnc session is not load balanced to a different host.
Nope, relayd is working!
This was the problem:
match request header set "Connection" value "close"
Otherwise you need http websockets
and mode source-hash
and itās all good.
This caused some frustration this evening: Certificate validation fails when the last certificate of the chain is signed by an expired CA (DST Root CA X3) Ā· Issue #606 Ā· ipxe/ipxe Ā· GitHub
Also, OpenBSD PSA:
zenbleed fix requires additional update procedure. I donāt know if this is necessary if you arenāt running an affected processor, but better safe than sorry since the consequences are a system that does not bootā¦
#!/usr/bin/env sh
set -eux
{ [ $(whoami) = 'root' ]
syspatch
pkg_add -u
fw_update
installboot -v sd0 #change to your boot drive
echo SUCCESS
echo FAIL
exit 1
#Reboot at your discretion
Maybe not a bad idea to do this on all updates tbh
So I have the gateways serving some files over http to facilitate iPXE installs, and that creating some headache with relayd. relayd has one very frustrating behavior if youāre forwarding to multiple hosts via SNI on the same interface, some of the forwarding arguments appear to be applied universally. For instance, I cannot forward to a combination of HTTP and HTTPS backends on the same interface. Transparency also was all or nothing. Checks were not though? Itās weird and I wonder if itās a bug or Iām doing something wrong.
Anyway, for one relay, I want to essentially pass it through to httpd running on the localhost. But since relayd is bound to that interface, it has to act as the intermediary. So my instinct was to run httpd on 127.0.0.1 and relay to that. But I need a certificate because as mentioned, itās all HTTP or HTTPS and all the other SNI-defined backends for that interface are HTTPS (self-signed). I could not figure out how to generate a self-signed certificate that httpd would accept for the localhost interface. Iām sure thereās a way to do it, but I could not figure it out. Instead, I set a fqdn in /etc/hosts
ending in my Letās Encrypt wildcard domain for 127.0.0.1 which tricked httpd into loading the Letās Encrypt certificate. Now this works but only if transparency is disabled, so Iām living with that for now.
Anyway, config looks like this:
interval 3
log state changes
log connection errors
prefork 3
table <localhost> { localhost.my.letsencrypt.domain } #127.0.0.1 (defined in /etc/hosts on the relayd host)
table <oobm1> { 192.168.1.11 }
table <oobm2> { 192.168.1.12 }
table <oobm3> { 192.168.1.13 }
table <proxmox> { 192.168.2.11 192.168.2.12 192.168.2.13 }
http protocol "https" {
return error
match request header append "X-Forwarded-For" value "$REMOTE_ADDR"
match request header append "X-Forwarded-By" value "$SERVER_ADDR:$SERVER_PORT"
#match request header set "Connection" value "close" #Breaks novnc
match response header set "Strict-Transport-Security" value "max-age=15552000; includeSubDomains; preload"
match response header set "X-Content-Type-Options" value "nosniff"
match response header set "X-Frame-Options" value "SAMEORIGIN"
match response header set "X-XSS-Protection" value "1; mode=block"
tcp sack
tcp nodelay
http websockets
tls keypair "my.letsencrypt.domain"
tls ciphers HIGH
#tls no tlsv1.2
#tls tlsv1
match request header "Host" value "www.my.letsencrypt.domain" forward to <localhost>
match request header "Host" value "oobm1.my.letsencrypt.domain" forward to <oobm1>
match request header "Host" value "oobm2.my.letsencrypt.domain" forward to <oobm2>
match request header "Host" value "oobm3.my.letsencrypt.domain" forward to <oobm3>
match request header "Host" value "proxmox.my.letsencrypt.domain" forward to <proxmox>
relay "lan" {
listen on 192.168.1.1 port https tls
protocol "https"
forward with tls to <localhost> port https check https "/" code 200
forward with tls to <oobm1> port https check tcp #IPMI doesn't like relayd's https or tls checks
forward with tls to <oobm2> port https check tcp
forward with tls to <oobm3> port https check tcp
relay "proxmox" {
listen on 192.168.2.1 port https tls
protocol "https"
transparent forward with tls to <proxmox> port https mode source-hash check tls #proxmox also doesn't like relayd's https check
yikes
I barely touched code but it sounds like poor scope handling when declaring some object or function.
Source code?
Yeah I donāt know. OpenBSD devs make design choices very deliberately so Iām sure thereās some reason but it definitely will be a deal breaker for a lot of people coming from haproxy. Luckily in my case, everything I am using has or can easily be equipped with self-signed certificates, and itās always nice to keep things encrypted anyway, even behind the proxy.
Lol, I had to deal with that at work, although not with ipxe. Funny how the certificates were valid, so no alerts triggered, but the CA expired and everything went to . Who thought it was a good idea to make a CA, but not set alerts when it expires?..
I finally saved my random word 1-liner to a script instead of searching for it in history.
sed -n "$(( $RANDOM$RANDOM % $(wc -l /usr/share/dict/words | awk '{print $1}' ) ))p" /usr/share/dict/words
I just realized I had actually already done under a different name and forgotā¦
Iām stealing this
Sir? wtf is this?
