Question for y’all. So, I am in the process of following Wendell’s recent homelab guide. I unfortunately don’t have the hardware storage requirements for TruNAS, so I just have a debian machine running Portainer, so everything on Portainer that you did I followed along with (NextCloud and TailScale). I set up the advertise-routes and in tailscale I have it set to route subnet. When I try to connect to NextCloud using the 100.#.#.#:8080 IP or the local 192.#.#.#:8080 IP I still get the “untrusted domain” message. I did a sanity check restart on the machine running Portainer but did affect the issue.
NOTE: I’m pretty new to this and since I am not using TruNas, I should have probably changed the volumes for the stack compose files but didn’t. I don’t know if that is a factor because the machine is on TailScale and I can access NextCloud locally.
