Hi i'm from Mexico and gointo to build a new pc in fact my first pc but i just want to check with you that if im choosing the right parts for it i will be doing web development (ruby, python) and gaming not many editing and some audio here are the parts that i can get in my country without importing:
This ITX build will not allow you any watercooling... As for the build - it's fine... Fairly balanced when it comes to cpu-gpu speed... However, ITX may not be the best option for first build... It's really frustrating some times, it requires a lot of effort to build it properly...
Id rather go with this one... Faster that SP600... You gonna do custom loop or AIO? AIO with thin rad will fit. Custom watercooling with the pump, reservoir and everything will not... But it's your choice... I still would not go for ITX for first build...
If from $54.98 to $86.01 you get 4 times the ssd size, you really do not want to buy that 64 gb at all. I do not know that ssd either, but each one i know comes faster in bigger sizes. Other options have been linked.
2.
The Psu is much, much overkill. 500 is not "enough", it is in fact still plenty. Also, isn't that an ATX psu in an ITX case?Did you make sure it'l fit? Doesn't look like it to me.
(it's not like you can upgrade a second gpu in there, don't think you will ever run out of power in that case with a sturdy 500w psu)
3.
I am outdated in terms of drives, but is 7200 rps the way to go for this by todays standards?
4.
had that screen once, it's nice...but i changed away from it quickly. Reasons are already posted
5.
Itx, gaming, r9 390, stock cooler....that's some devilish combo. Watercooling over a distance of 5cm doesn't make sence imoo. Get some good low noise fans and you are all set.
