mb sound should get you by. I was considering building this for myself.
http://pcpartpicker.com/user/Freaksamcker/saved/ZgDtt6
Sound cards are a waste of $ imo... if you need great quality sound go w/ external amp & dac. If you're just wondering if you need it for sound then no, your motherboard already has onboard audio that you can access from the rear i/o panel or the front panel if you connected the hd audio connector.
Depending on which case you get it will have a few fans included just do your research on the prospective cases.
@shadowvengence22 @Freaksmacker @ThatBootsGuy thanks for the recommendations im definatly not getting a sound card then, i just wanted to make sure that i would be able to get sound without one.
