Navi Reset Bug Kernel Patch v2
This patch and all other kernel pathes for vega/navi on this website are now obsoleted by the vendor-reset project:
Starting from gnif’s original kernel patch, I looked for another way to reset my Navi cards, as certain things (VM crash, reboot, etc) would leave things broken and require a reboot. I managed to find some success in an alternative method to trigger a reset, and it seems the cards reset at least completely enough to put the card in a suspend power state afterwards.
I’ve tested it on Navi 10 (5600 XT) and Navi 14 (5500 XT) cards. I would appreciate some further testing especially on older Navi cards (as @gnif
mentioned there were some issues with mode 1 reset on older Navi cards).
Edit by @gnif: Latest version (update3): Navi Reset Bug Kernel Patch v2
diff --git a/drivers/pci/quirks.c b/drivers/pci/quirks.c
index 2a589b6d6ed8..b7554b1b141d 100644
--- a/drivers/pci/quirks.c
+++ b/drivers/pci/quirks.c
@@ -3969,17 +3969,371 @@ static int delay_250ms_after_flr(struct pci_dev *dev, int probe)
 	return 0;
+ * AMD Navi 10 series GPUs require a vendor specific reset procedure.
+ * According to AMD a PSP mode 2 reset should be enough however at this
+ * time the details of how to perform this are not available to us.
+ * Instead we can signal the SMU to enter and exit BACO which has the same
+ * desired effect.
+static int reset_amd_navi10(struct pci_dev *dev, int probe)
+	const int mmMM_INDEX = 0x0000;
+	const int mmMM_DATA = 0x0001;
+	const int mmPCIE_INDEX2 = 0x000e;
+	const int mmPCIE_DATA2 = 0x000f;
+	const int MP0_BASE = 0x00016000L;
+	const int mmMP0_SMN_C2PMSG_33 = 0x0061 + MP0_BASE;
+	const int mmMP0_SMN_C2PMSG_35 = 0x0063 + MP0_BASE;
+	const int mmMP0_SMN_C2PMSG_64 = 0x0080 + MP0_BASE;
+	const int mmMP0_SMN_C2PMSG_81 = 0x0091 + MP0_BASE;
+	const int mmMP1_SMN_C2PMSG_66 = 0x0282 + MP0_BASE;
+	const int mmMP1_SMN_C2PMSG_82 = 0x0292 + MP0_BASE;
+	const int mmMP1_SMN_C2PMSG_90 = 0x029a + MP0_BASE;
+	const int GFX_CTRL_CMD_ID_MODE1_RST = 0x00070000L;
+	const int MP1_Public = 0x03b00000L;
+	const int smnMP1_PUB_CTRL = 0x3010b14;
+	const int MP1_SMN_PUB_CTRL__RESET_MASK = 0x00000001L;
+	const int smnMP1_FIRMWARE_FLAGS = 0x3010024;
+	const int MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED_MASK = 0x00000001L;
+	const int MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED__SHIFT = 0x0;
+	const int mmRCC_DEV0_EPF0_RCC_CONFIG_MEMSIZE = 0x00c3 + 0x00000D20L;
+	const int scratch_reg_offset = 0x4c;
+	const int ATOM_S3_ASIC_GUI_ENGINE_HUNG = 0x20000000L;
+	u16 cfg;
+	u32 tmp, smu_resp, sol, mp1_intr, psp_bl_ready;
+	resource_size_t mmio_base, mmio_size;
+	uint32_t __iomem *mmio;
+	unsigned int timeout;
+	spinlock_t pcie_lock;
+	 * if the device has FLR return -ENOTTY indicating that we have no
+	 * device-specific reset method.
+	if (pcie_has_flr(dev))
+		return -ENOTTY;
+	/* bus resets still cause navi to flake out */
+	dev->dev_flags |= PCI_DEV_FLAGS_NO_BUS_RESET;
+	/* if we're managed by amdgpu, do not reset */
+	if (dev->driver && !strcmp(dev->driver->name, "amdgpu"))
+		return -ENOTTY;
+	if (probe)
+		return 0;
+	spin_lock_init(&pcie_lock);
+	/* map BAR5 */
+	mmio_base = pci_resource_start(dev, 5);
+	mmio_size = pci_resource_len(dev, 5);
+	mmio = ioremap(mmio_base, mmio_size);
+	if (mmio == NULL) {
+		pci_disable_device(dev);
+		pci_err(dev, "Navi10: cannot iomap device\n");
+		return 0;
+	/* save the PCI state and enable memory access */
+	pci_read_config_word(dev, PCI_COMMAND, &cfg);
+	pci_write_config_word(dev, PCI_COMMAND, cfg | PCI_COMMAND_MEMORY);
+	pci_set_power_state(dev, PCI_D0);
+#define RREG32(reg)                                                            \
+		u32 out;                                                       \
+		if ((reg) < mmio_size)                                         \
+			out = readl(mmio + (reg));                             \
+		else {                                                         \
+			writel((reg), mmio + mmMM_INDEX);                      \
+			out = readl(mmio + mmMM_DATA);                         \
+		out;                                                           \
+#define WREG32(reg, v)                                                         \
+	do {        \
+			writel(v, mmio + (reg));                               \
+		else {                                                         \
+			writel(v, mmio + mmMM_DATA);                           \
+	} while (0)
+#define WREG32_PCIE(reg, v)                                                    \
+	do {        \
+		unsigned long __flags;                                         \
+		spin_lock_irqsave(&pcie_lock, __flags);                        \
+		WREG32(mmPCIE_INDEX2, reg);                                    \
+		(void)RREG32(mmPCIE_INDEX2);                                   \
+		WREG32(mmPCIE_DATA2, v);                                       \
+		(void)RREG32(mmPCIE_DATA2);                                    \
+		spin_unlock_irqrestore(&pcie_lock, __flags);                   \
+	} while (0)
+#define RREG32_PCIE(reg)                                                       \
+		u32 __tmp_read;                                                \
+		__tmp_read = RREG32(mmPCIE_DATA2);                             \
+		__tmp_read;                                                    \
+#define SMU_WAIT()                                                             \
+		u32 __tmp;                                                     \
+		for (timeout = 100000;                                         \
+		     timeout &&                                                \
+		     (RREG32(mmMP1_SMN_C2PMSG_90) & 0xFFFFFFFFL) == 0;         \
+		     --timeout)                                                \
+			udelay(1);                                             \
+		if ((__tmp = RREG32(mmMP1_SMN_C2PMSG_90)) != 0x1)              \
+			pci_info(dev, "Navi10: SMU error 0x%x (line %d)\n",    \
+				 __tmp, __LINE__);                             \
+	/* it's important we wait for the SOC to be ready */
+	for (timeout = 100000; timeout; --timeout) {
+		sol = RREG32(mmMP0_SMN_C2PMSG_81);
+		if (sol != 0xFFFFFFFF)
+			break;
+		udelay(1);
+	if (sol == 0xFFFFFFFF) {
+		pci_warn(dev,
+			 "Navi10: Timed out waiting for SOL to be valid\n");
+		goto out;
+	 * okay there's three things we need to check:
+	 * sign-of-life, MP1 intr state (enabled means MP1 is probably live),
+	 * and finally PSP bootloader state (needs to be ready)
+	smu_resp = RREG32(mmMP1_SMN_C2PMSG_90);
+	mp1_intr = (RREG32_PCIE(MP1_Public |
+				(smnMP1_FIRMWARE_FLAGS & 0xffffffff)) &
+		    MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED_MASK) >>
+		   MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED__SHIFT;
+	psp_bl_ready = !!(RREG32(mmMP0_SMN_C2PMSG_35) & 0x80000000L);
+	pci_info(
+		dev,
+		"Navi10: SMU response reg: %x, sol reg: %x, mp1 intr enabled? %s, bl ready? %s\n",
+		smu_resp, sol, mp1_intr ? "yes" : "no",
+		psp_bl_ready ? "yes" : "no");
+	/* check the sign of life indicator */
+	if (sol == 0x0 && !mp1_intr && psp_bl_ready) {
+		/* either already clean or in a state we can't fix */
+		goto out;
+	/* save the state around the reset */
+	pci_info(dev, "Navi10: Clear master\n");
+	pci_clear_master(dev);
+	pci_save_state(dev);
+	/* this tells the drivers nvram is lost and everything needs to be reset */
+	pci_info(dev, "Navi10: Clearing scratch regs 6 and 7\n");
+	WREG32(scratch_reg_offset + 6, 0);
+	WREG32(scratch_reg_offset + 7, 0);
+	/* it only makes sense to reset mp1 if it's running */
+	if (smu_resp != 0x01 && mp1_intr) {
+		pci_info(dev, "Navi10: MP1 reset\n");
+		WREG32_PCIE(MP1_Public | (smnMP1_PUB_CTRL & 0xffffffff),
+			    1 & MP1_SMN_PUB_CTRL__RESET_MASK);
+			    1 & ~MP1_SMN_PUB_CTRL__RESET_MASK);
+		pci_info(dev, "Navi10: wait for MP1\n");
+			tmp = RREG32_PCIE(MP1_Public |
+					  (smnMP1_FIRMWARE_FLAGS & 0xffffffff));
+			if ((tmp &
+			    MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED__SHIFT)
+				break;
+			udelay(1);
+		if (!timeout &&
+		    !((tmp & MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED_MASK) >>
+		      MP1_FIRMWARE_FLAGS__INTERRUPTS_ENABLED__SHIFT)) {
+			pci_warn(dev,
+				 "Navi10: timed out waiting for MP1 reset\n");
+		SMU_WAIT();
+		pci_info(dev, "Navi10: SMU resp reg: %x\n", tmp);
+	pci_info(dev, "Navi10: begin reset\n");
+	 * again, this only makes sense if we have an SMU to talk to
+	 * some of these may fail, that's okay. we're just turning off as many
+	 * things as possible
+	if (mp1_intr) {
+		/* stop SMC */
+		pci_info(dev, "Navi10: gfx off\n");
+		WREG32(mmMP1_SMN_C2PMSG_90, 0x00);
+		WREG32(mmMP1_SMN_C2PMSG_82, 0x00);
+		WREG32(mmMP1_SMN_C2PMSG_66, 0x2A);
+		SMU_WAIT();
+		pci_info(dev, "Navi10: jpeg off\n");
+		WREG32(mmMP1_SMN_C2PMSG_66, 0x2E);
+		SMU_WAIT();
+		pci_info(dev, "Navi10: vcn off\n");
+		WREG32(mmMP1_SMN_C2PMSG_66, 0x2C);
+		SMU_WAIT();
+		/* stop SMC */
+		pci_info(dev, "Navi10: Prep Reset\n");
+		/* PPSMC_MSG_PrepareMp1ForReset */
+		WREG32(mmMP1_SMN_C2PMSG_66, 0x33);
+		SMU_WAIT();
+#define PSP_WAIT(reg_index, reg_val, mask, err_exit)        \
+	do {        \
+		for (timeout = 1000000; timeout; --timeout) {        \
+			tmp = RREG32(reg_index);        \
+			if ((tmp & mask) == reg_val)        \
+				break;        \
+			udelay(1);        \
+		if (((tmp & mask) != reg_val)) {        \
+			pci_err(dev,        \
+				"Navi10: reg %08x (0x%08x, masked 0x%08x) did not reach needed value (0x%08x), (line %d)\n", \
+				reg_index, tmp, (tmp & mask), reg_val,                                                       \
+				__LINE__);        \
+			if (err_exit)        \
+				goto mode1_out;        \
+	} while (0)
+	pci_info(dev, "Navi10: begin psp mode 1 reset\n");
+	/* mark amdgpu_atombios_scratch_regs_engine_hung */
+	tmp = RREG32(scratch_reg_offset + 3);
+	tmp |= ATOM_S3_ASIC_GUI_ENGINE_HUNG;
+	WREG32(scratch_reg_offset + 3, tmp);
+	/* check validity of PSP before reset */
+	pci_info(dev, "Navi10: PSP wait\n");
+	PSP_WAIT(mmMP0_SMN_C2PMSG_64, 0x80000000, 0x8000FFFF, false);
+	/* reset command */
+	pci_info(dev, "Navi10: do mode1 reset\n");
+	WREG32(mmMP0_SMN_C2PMSG_64, GFX_CTRL_CMD_ID_MODE1_RST);
+	msleep(500);
+	/* wait for ACK */
+	PSP_WAIT(mmMP0_SMN_C2PMSG_33, 0x80000000, 0x80000000, true);
+	pci_info(dev, "Navi10: psp mode1 succeeded\n");
+	/* restore state here and wait */
+	pci_restore_state(dev);
+		tmp = RREG32(mmRCC_DEV0_EPF0_RCC_CONFIG_MEMSIZE);
+		if (tmp != 0xffffffff)
+			break;
+		udelay(1);
+	pci_info(dev, "Navi10: memsize: %x\n", tmp);
+	/* unmark amdgpu_atombios_scratch_regs_engine_hung */
+	tmp &= ~ATOM_S3_ASIC_GUI_ENGINE_HUNG;
+	/* this takes a long time :( */
+	for (timeout = 100; timeout; --timeout) {
+		/* see if PSP bootloader comes back */
+		if (RREG32(mmMP0_SMN_C2PMSG_35) & 0x80000000L)
+			break;
+		pci_info(dev, "Navi10: PSP bootloader flags? %x, timeout: %s\n",
+			 RREG32(mmMP0_SMN_C2PMSG_35), !timeout ? "yes" : "no");
+		msleep(100);
+	if (!timeout && !(RREG32(mmMP0_SMN_C2PMSG_35) & 0x80000000L)) {
+		pci_info(
+			dev,
+			"Navi10: timed out waiting for PSP bootloader to respond after reset\n");
+	} else {
+		pci_set_power_state(dev, PCI_D3hot);
+		pci_info(dev, "Navi10: PSP mode1 reset successful\n");
+mode1_out:
+#undef RREG32
+#undef WREG32
+#undef RREG32_PCIE
+#undef WREG32_PCIE
+#undef PSP_WAIT
+#undef SMU_WAIT
+out:
+	/* unmap BAR5 */
+	iounmap(mmio);
+	/* restore the state and command register */
+	pci_write_config_word(dev, PCI_COMMAND, cfg);
+	return 0;
 static const struct pci_dev_reset_methods pci_dev_reset_methods[] = {
 	{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82599_SFP_VF,
-		 reset_intel_82599_sfp_virtfn },
-	{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_IVB_M_VGA,
-		reset_ivb_igd },
-	{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_IVB_M2_VGA,
-		reset_ivb_igd },
+	  reset_intel_82599_sfp_virtfn },
+	{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_IVB_M_VGA, reset_ivb_igd },
+	{ PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_IVB_M2_VGA, reset_ivb_igd },
 	{ PCI_VENDOR_ID_SAMSUNG, 0xa804, nvme_disable_and_flr },
 	{ PCI_VENDOR_ID_INTEL, 0x0953, delay_250ms_after_flr },
-	{ PCI_VENDOR_ID_CHELSIO, PCI_ANY_ID,
-		reset_chelsio_generic_dev },
+	{ PCI_VENDOR_ID_CHELSIO, PCI_ANY_ID, reset_chelsio_generic_dev },
+	{ PCI_VENDOR_ID_ATI, 0x7310, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7312, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7318, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7319, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x731a, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x731b, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x731f, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7340, reset_amd_navi10 },
 	{ 0 }
This looks legitimate people, I have already had a look over it and plan to do some testing over the next few days. Awesome work @belfrypossum!
Ping @wendell !
I cannot test, but will watch eagerly! Thank you for you contribution
Per a comment by an AMD dev, I removed the specific JPEG and VCN shutdown code as it is apparently not needed. Testing yields the same results as the original (at least on Navi 10), so here’s an updated patch with that code removed.
index 2a589b6d6ed8..c86bdc1069d3 100644
@@ -3969,17 +3969,362 @@ static int delay_250ms_after_flr(struct pci_dev *dev, int probe)
 	return 0;
+ * Instead we can signal the PSP to perform a mode 1 reset, which _is_
+ * available to us. Unfortunately, it probably takes more time.
+	u16 cfg;
+		return -ENOTTY;
+		return -ENOTTY;
+	if (probe)
+		return 0;
+	/* map BAR5 */
+		return 0;
+		u32 out;                                                       \
+		else {                                                         \
+		out;                                                           \
+	do {        \
+		else {                                                         \
+	} while (0)
+	do {        \
+	} while (0)
+		u32 __tmp_read;                                                \
+		__tmp_read;                                                    \
+		u32 __tmp;                                                     \
+		     timeout &&                                                \
+		     --timeout)                                                \
+			udelay(1);                                             \
+			break;
+		udelay(1);
+		pci_warn(dev,
+		goto out;
+	pci_info(
+		dev,
+		goto out;
+	 * XXX: is this even necessary? in early testing, I ran into
+	 * situations where MP1 was alive but not responsive, but in
+	 * later testing I have not been able to replicate this scenario.
+			if ((tmp &
+				break;
+			udelay(1);
+		if (!timeout &&
+			pci_warn(dev,
+		SMU_WAIT();
+	if (mp1_intr) {
+		/* stop SMC */
+		SMU_WAIT();
+		/* stop SMC */
+		SMU_WAIT();
+	do {        \
+				break;        \
+			udelay(1);        \
+			pci_err(dev,        \
+				__LINE__);        \
+			if (err_exit)        \
+				goto mode1_out;        \
+	} while (0)
+	msleep(500);
+			break;
+		udelay(1);
+			break;
+		msleep(100);
+		pci_info(
+			dev,
+	} else {
+mode1_out:
+#undef RREG32
+#undef WREG32
+#undef RREG32_PCIE
+#undef WREG32_PCIE
+#undef PSP_WAIT
+#undef SMU_WAIT
+out:
+	/* unmap BAR5 */
+	iounmap(mmio);
+	return 0;
-		reset_ivb_igd },
-		reset_ivb_igd },
 	{ 0 }
This works perfectly, thank you so much! I thought I’d never be able to do PCIe passthrough with my GPU.
Hello everyone, first of all I’d like to say thank you for taking the time to work on this patch, I sincerely appreciate your efforts.
Can someone help me install this patch. I’m fairly comfortable in linux and the terminal, but sadly I’ve never applied patches to my kernel…seems like an easy process but I also cant figure out from where to download the aforementioned (navi v2 reset patch)…Any help/guidance would be greatly appreciated. A bit about my system, I have a 5700XT card that I am trying to passthrough, no issues with the passthrough, but definitely issues with system hanging when the VM using the 5700XT is not shutdown properly or like rebooted, then I need to reboot system before it will work again. I have a 10980xe with plenty of RAM and storage and what not, running Ubuntu 20.10 groovy gorilla (kernel 5.8.0-26).
Look forward to hearing from someone.
Thanks
First, familiarize yourself with how to build a custom kernel on Ubuntu.
Then, you can apply the patch to the kernel source code, and rebuild and install.
The patch is actually in this thread. See the code blocks in first and fourth posts.
Copy the entirety of the code block and paste it into a text file. The file name does not really matter, but something like navi_reset_patch_v2.patch would be good.
Then, apply it to the source code with the patch utility, then reconfigure, recompile, and reinstall the kernel.
This set of instructions seems to be reasonable.
this is nice, i have been waiting ever since i got my 5700xt for this patch.
i know there was a patch out there but if this works even better im even happier!
v3 @belfrypossum posted on VFIO discord, fixes a minor issue.
index 2a589b6d6ed8..1b84090db691 100644
@@ -3969,17 +3969,517 @@ static int delay_250ms_after_flr(struct pci_dev *dev, int probe)
 	return 0;
+	static const u16 vega10_device_ids[] = { 0x6860, 0x6861, 0x6862, 0x6863,
+						 0x6864, 0x6867, 0x6868, 0x6869,
+						 0x686a, 0x686b, 0x686c, 0x686d,
+						 0x686e, 0x686f, 0x687f };
+	static const u16 vega12_device_ids[] = {
+		0x69A0, 0x69A1, 0x69A2, 0x69A3, 0x69AF,
+	static const u16 vega20_device_ids[] = {
+		0x66A0, 0x66A1, 0x66A2, 0x66A3, 0x66A4, 0x66A7, 0x66AF,
+	const int PPSMC_MSG_DisableSmuFeatures = 0x5; /* vega10 */
+	const int PPSMC_MSG_DisableAllSmuFeatures = 0x7; /* vega12/vega20 */
+	const int SMC_DPM_FEATURES = 0x30F;
+	int smnMP1_FIRMWARE_FLAGS = 0x3010024;
+	// this is the case for navi but I'm not sure about vega yet
+	enum { VEGA10, VEGA12, VEGA20, NAVI } device_type = NAVI;
+	u16 cfg;
+	int i;
+		return -ENOTTY;
+		return -ENOTTY;
+	if (probe)
+		return 0;
+	/* detect device */
+	for (i = 0; i < sizeof vega10_device_ids / sizeof(u16); ++i) {
+		if (dev->device == vega10_device_ids[i]) {
+			device_type = VEGA10;
+			goto done_detect;
+	for (i = 0; i < sizeof vega12_device_ids / sizeof(u16); ++i) {
+		if (dev->device == vega12_device_ids[i]) {
+			device_type = VEGA12;
+			goto done_detect;
+	for (i = 0; i < sizeof vega20_device_ids / sizeof(u16); ++i) {
+		if (dev->device == vega20_device_ids[i]) {
+			device_type = VEGA20;
+			goto done_detect;
+done_detect:
+	if (device_type != NAVI && device_type != VEGA20) {
+		smnMP1_FIRMWARE_FLAGS = 0x3010028;
+	/* map BAR5 */
+		return 0;
+		u32 out;                                                       \
+		else {                                                         \
+		out;                                                           \
+	do {        \
+		else {                                                         \
+	} while (0)
+	do {        \
+	} while (0)
+		u32 __tmp_read;                                                \
+		__tmp_read;                                                    \
+		u32 __tmp;                                                     \
+		     timeout &&                                                \
+		     --timeout)                                                \
+			udelay(1);                                             \
+			break;
+		udelay(1);
+		pci_warn(dev,
+		/* we will continue anyway because it's possible to do
+		 * a mode 1 reset on navi at least */
+	pci_info(
+		dev,
+		"Navi10: Device type %d, SMU response reg: %x, sol reg: %x, mp1 intr enabled? %s, bl ready? %s\n",
+		device_type, smu_resp, sol, mp1_intr ? "yes" : "no",
+		goto out;
+	if (smu_resp != 0x01 && mp1_intr && device_type == NAVI) {
+			if ((tmp &
+				break;
+			udelay(1);
+		if (!timeout &&
+			pci_warn(dev,
+		SMU_WAIT();
+	if (mp1_intr) {
+		SMU_WAIT();
+		switch (device_type) {
+		case NAVI:
+			/* stop SMC */
+			SMU_WAIT();
+			/* stop SMC */
+			SMU_WAIT();
+			break;
+		case VEGA10:
+		 * frankly, I have no idea if this has to be done in a particular order
+		 * hence this long sequence of bits that comes from the hwmgr destroy
+#define DISABLE_FEAT(bits)                                                     \
+	do {        \
+		WREG32(mmMP1_SMN_C2PMSG_90, 0x00);                             \
+		WREG32(mmMP1_SMN_C2PMSG_82, (bits));                           \
+		WREG32(mmMP1_SMN_C2PMSG_66, PPSMC_MSG_DisableSmuFeatures);     \
+		SMU_WAIT();                                                    \
+	} while (0)
+			/* disable power containment */
+			pci_info(dev, "Vega10: disable power containment\n");
+			DISABLE_FEAT(1L << 14);
+			DISABLE_FEAT(1L << 15);
+			/* disable avfs */
+			pci_info(dev, "Vega10: disable avfs\n");
+			DISABLE_FEAT(1L << 10);
+			/* stop dpm */
+			pci_info(dev, "Vega10: disable dpm\n");
+			DISABLE_FEAT(1L << 24);
+			DISABLE_FEAT(SMC_DPM_FEATURES);
+			/* disable deep sleep */
+			pci_info(dev, "Vega10: disable deep sleep\n");
+			DISABLE_FEAT(1L << 11);
+			DISABLE_FEAT(1L << 12);
+			DISABLE_FEAT(1L << 13);
+			DISABLE_FEAT(1L << 9);
+			/* disable ulv */
+			pci_info(dev, "Vega10: disable ulv\n");
+			DISABLE_FEAT(1L << 6);
+			/* disable acg */
+			pci_info(dev, "Vega10: disable acg\n");
+			DISABLE_FEAT(1L << 28);
+			/* disable PCC limit */
+			pci_info(dev, "Vega10: disable PCC\n");
+			DISABLE_FEAT(1L << 29);
+#undef DISABLE_FEAT
+			break;
+		case VEGA12:
+		case VEGA20:
+			pci_info(dev, "Vega12/20: disable GFX\n");
+			       PPSMC_MSG_DisableAllSmuFeatures);
+			SMU_WAIT();
+			break;
+		default:
+			break;
+	do {        \
+				break;        \
+			udelay(1);        \
+			pci_err(dev,        \
+				__LINE__);        \
+			if (err_exit)        \
+				goto mode1_out;        \
+	} while (0)
+	/* I don't know if I have the base register right for non-navi cards */
+	if (device_type == NAVI) {
+	msleep(500);
+			break;
+		udelay(1);
+			break;
+		msleep(100);
+		pci_info(
+			dev,
+	} else {
+mode1_out:
+#undef RREG32
+#undef WREG32
+#undef RREG32_PCIE
+#undef WREG32_PCIE
+#undef PSP_WAIT
+#undef SMU_WAIT
+out:
+	/* unmap BAR5 */
+	iounmap(mmio);
+	return 0;
-		reset_ivb_igd },
-		reset_ivb_igd },
+	{ PCI_VENDOR_ID_ATI, 0x6860, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6861, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6862, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6863, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6864, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6867, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6868, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x6869, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686a, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686b, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686c, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686d, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686e, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x686f, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x687f, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x69A0, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x69A1, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x69A2, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x69A3, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x69AF, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A0, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A1, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A2, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A3, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A4, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66A7, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x66AF, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7341, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7347, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x734F, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7360, reset_amd_navi10 },
+	{ PCI_VENDOR_ID_ATI, 0x7362, reset_amd_navi10 },
 	{ 0 }
Haha, the minor issue was about the patch I posted just before that and deleted. That’s my first pass at a Vega reset. It’s not fully functional yet though and needs some revision.
Oh ooops :), I didn’t look too closely sorry
I have a Powercolor 5700XT on Manjaro with 5.9 Kernel.
This new Patch does not work for me! On second boot the screen does not even get a signal!
Besides applying the patch during compilation is there anything else I need to modify in the patch itself or something like that?
Can you send me the output of dmesg around the time you tried to reboot your VM? I think all Navi 10 cards were listed in the patch, but it wouldn’t hurt to double check the device ID of your card matches one of those that the quirk applies to.
This is a short part of journalctl -b, it should include the first successful start of the VM, a shutdown as well as a second failed start. Hope it helps:
Okt 31 10:56:09 machine kernel: cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
Okt 31 10:56:11 machine kernel: virbr0: port 2(vnet0) entered learning state
Okt 31 10:56:13 machine kernel: virbr0: port 2(vnet0) entered forwarding state
Okt 31 10:56:13 machine kernel: virbr0: topology change detected, propagating
Okt 31 10:56:13 machine NetworkManager[2191]: <info>  [1604138173.4254] device (virbr0): carrier: link connected
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: enabling device (0002 -> 0003)
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
Okt 31 10:56:13 machine kernel: vfio-pci 0000:0b:00.1: enabling device (0000 -> 0002)
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Gaming Keyboard
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "25"
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) event2  - Gaming Keyboard: device removed
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) UnloadModule: "libinput"
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:66
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Gaming Keyboard Mouse
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "26"
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) event3  - Gaming Keyboard Mouse: device removed
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:67
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Gaming Keyboard Consumer Control
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "27"
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: not releasing fd for 13:68, still in use
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) event4  - Gaming Keyboard Consumer Control: device removed
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:68
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Gaming Keyboard System Control
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "28"
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) event5  - Gaming Keyboard System Control: device removed
Okt 31 10:56:13 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:69
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Gaming Keyboard
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "29"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event6  - Gaming Keyboard: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) UnloadModule: "libinput"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:70
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Razer Razer DeathAdder Essential
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "30"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event7  - Razer Razer DeathAdder Essential: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:71
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Razer Razer DeathAdder Essential Keyboard
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "33"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event8  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:72
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Razer Razer DeathAdder Essential Consumer Control
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "31"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: not releasing fd for 13:73, still in use
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event9  - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:73
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: removing device Razer Razer DeathAdder Essential System Control
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "32"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event10 - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:74
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (**) Option "fd" "34"
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) event12 - Razer Razer DeathAdder Essential: device removed
Okt 31 10:56:14 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: releasing fd for 13:76
Okt 31 10:56:14 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
Okt 31 10:56:14 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 10:56:14 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=disk reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-disk="?" new-disk="/mnt/secondssd/Virtualization/libvirt/images/gaming-clone.qcow2" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=net reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-net="?" new-net="52:54:00:bf:2b:a7" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.0" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.1" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device="003.003" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device="003.004" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device=555342207265646972646576 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=shmem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 size=33554432 path=/dev/shm/looking-glass exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=mem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-mem=0 new-mem=30720000 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=vcpu reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-vcpu=0 new-vcpu=12 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:15 machine audit[2263]: VIRT_CONTROL pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=start reason=booted vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=4228 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:20 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 10:56:20 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 10:56:20 machine kernel: usb 3-6.2: reset low-speed USB device number 3 using xhci_hcd
Okt 31 10:56:20 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2
Okt 31 10:56:33 machine dnsmasq-dhcp[4197]: DHCPDISCOVER(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 10:56:33 machine dnsmasq-dhcp[4197]: DHCPOFFER(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 10:56:33 machine dnsmasq-dhcp[4197]: DHCPREQUEST(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 10:56:33 machine dnsmasq-dhcp[4197]: DHCPACK(virbr0) 192.168.122.69 52:54:00:bf:2b:a7 Gaming-VM
Okt 31 10:56:33 machine kernel: nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
Okt 31 10:56:51 machine kernel: usb 3-6.2: reset low-speed USB device number 3 using xhci_hcd
Okt 31 10:56:51 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2
Okt 31 10:56:51 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 10:56:51 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 10:56:55 machine kernel: virbr0: port 2(vnet0) entered disabled state
Okt 31 10:56:55 machine audit: ANOM_PROMISCUOUS dev=vnet0 prom=0 old_prom=256 auid=4294967295 uid=1000 gid=992 ses=4294967295
Okt 31 10:56:55 machine kernel: device vnet0 left promiscuous mode
Okt 31 10:56:55 machine NetworkManager[2191]: <info>  [1604138215.2273] device (vnet0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Okt 31 10:56:55 machine NetworkManager[2191]: <info>  [1604138215.2281] device (vnet0): released from master device virbr0
Okt 31 10:56:55 machine gnome-shell[3334]: Removing a network device that was not added
Okt 31 10:56:55 machine dbus-daemon[2190]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=2191 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Okt 31 10:56:55 machine systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 31 10:56:55 machine gnome-shell[3334]: JS ERROR: TypeError: this._devices[section] is undefined
                                          _connectionRemoved@resource:///org/gnome/shell/ui/status/network.js:1925:27
Okt 31 10:56:55 machine dbus-daemon[2190]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Okt 31 10:56:55 machine systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 31 10:56:55 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:56:55 machine libvirtd[2263]: internal error: End of file from qemu monitor
Okt 31 10:56:55 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.0008/input/input29
Okt 31 10:56:55 machine kernel: hid-generic 0003:1532:006E.0008: input,hidraw1: USB HID v1.11 Mouse [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input0
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input30
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input31
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input32
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input33
Okt 31 10:56:55 machine kernel: hid-generic 0003:1532:006E.0009: input,hidraw2: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input1
Okt 31 10:56:55 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.000A/input/input34
Okt 31 10:56:55 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 10:56:55 machine kernel: hid-generic 0003:1532:006E.000A: input,hidraw3: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input2
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/mouse0)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) No input driver specified, ignoring this device.
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) This device may have been added with another device file.
Okt 31 10:56:55 machine systemd-logind[2193]: Watching system buttons on /dev/input/event4 (Razer Razer DeathAdder Essential Consumer Control)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Consumer Control (/dev/input/event4)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 26 paused 0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event4"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "_source" "server/udev"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event4  - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event4  - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event4  - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: needs a virtual subdevice
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input31/event4"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: MOUSE, id 8)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "AccelerationScheme" "none"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) selected scheme none/0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration factor: 2.000
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration threshold: 4
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "_source" "_driver/libinput"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: is a virtual subdevice
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: KEYBOARD, id 9)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "xkb_layout" "de"
Okt 31 10:56:55 machine systemd-logind[2193]: Watching system buttons on /dev/input/event7 (Razer Razer DeathAdder Essential)
Okt 31 10:56:55 machine systemd-logind[2193]: Watching system buttons on /dev/input/event5 (Razer Razer DeathAdder Essential System Control)
Okt 31 10:56:55 machine systemd-logind[2193]: Watching system buttons on /dev/input/event3 (Razer Razer DeathAdder Essential Keyboard)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event7)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: Applying InputClass "system-keyboard"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 27 paused 0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: always reports core events
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event7"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event7  - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event7  - Razer Razer DeathAdder Essential: device is a keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event7  - Razer Razer DeathAdder Essential: device removed
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.000A/input/input34/event7"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: KEYBOARD, id 10)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential System Control (/dev/input/event5)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "system-keyboard"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential System Control'
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 28 paused 0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential System Control: always reports core events
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event5"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event5  - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event5  - Razer Razer DeathAdder Essential System Control: device is a keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event5  - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input32/event5"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential System Control" (type: KEYBOARD, id 11)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Keyboard (/dev/input/event3)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "system-keyboard"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Keyboard'
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 29 paused 0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential Keyboard: always reports core events
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event3"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event3  - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event3  - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event3  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input30/event3"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Keyboard" (type: KEYBOARD, id 12)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event6)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event2)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev pointer catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput pointer catchall"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 30 paused 0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event2"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event2  - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event2  - Razer Razer DeathAdder Essential: device is a pointer
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) event2  - Razer Razer DeathAdder Essential: device removed
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.0008/input/input29/event2"
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: MOUSE, id 13)
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: (accel) selected scheme none/0
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: (accel) acceleration factor: 2.000
Okt 31 10:56:55 machine /usr/lib/gdm-x-session[3190]: (**) Razer Razer DeathAdder Essential: (accel) acceleration threshold: 4
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 10:56:55 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 10:56:55 machine kernel: usb 3-6.2: reset low-speed USB device number 3 using xhci_hcd
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 10:56:56 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 10:56:56 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 10:56:56 machine kernel: input: Gaming Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.0/0003:1017:2010.000B/input/input35
Okt 31 10:56:56 machine kernel: hid-generic 0003:1017:2010.000B: input,hidraw4: USB HID v1.10 Keyboard [Gaming Keyboard] on usb-0000:05:00.3-6.2/input0
Okt 31 10:56:56 machine kernel: input: Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input36
Okt 31 10:56:56 machine kernel: input: Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input37
Okt 31 10:56:56 machine kernel: input: Gaming Keyboard System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input38
Okt 31 10:56:56 machine kernel: input: Gaming Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input39
Okt 31 10:56:56 machine kernel: hid-generic 0003:1017:2010.000C: input,hiddev1,hidraw5: USB HID v1.10 Mouse [Gaming Keyboard] on usb-0000:05:00.3-6.2/input1
Okt 31 10:56:56 machine upowerd[2553]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard Mouse (/dev/input/mouse1)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) No input driver specified, ignoring this device.
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) This device may have been added with another device file.
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 10156228, mp1 intr enabled? yes, bl ready? no
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: gfx off
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Prep Reset
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 10:56:56 machine systemd-logind[2193]: Watching system buttons on /dev/input/event10 (Gaming Keyboard Consumer Control)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard Consumer Control (/dev/input/event10)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Gaming Keyboard Consumer Control'
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 31 paused 0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: always reports core events
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event10"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "_source" "server/udev"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event10 - Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event10 - Gaming Keyboard Consumer Control: device is a keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event10 - Gaming Keyboard Consumer Control: device removed
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) libinput: Gaming Keyboard Consumer Control: needs a virtual subdevice
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input37/event10"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard Consumer Control" (type: MOUSE, id 14)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "AccelerationScheme" "none"
Okt 31 10:56:56 machine systemd-logind[2193]: Watching system buttons on /dev/input/event12 (Gaming Keyboard)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: (accel) selected scheme none/0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: (accel) acceleration factor: 2.000
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Consumer Control: (accel) acceleration threshold: 4
Okt 31 10:56:56 machine systemd-logind[2193]: Watching system buttons on /dev/input/event8 (Gaming Keyboard)
Okt 31 10:56:56 machine systemd-logind[2193]: Watching system buttons on /dev/input/event11 (Gaming Keyboard System Control)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: returning pre-existing fd for /dev/input/event10 13:74
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "_source" "_driver/libinput"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) libinput: Gaming Keyboard Consumer Control: is a virtual subdevice
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard Consumer Control" (type: KEYBOARD, id 15)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "xkb_layout" "de"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard (/dev/input/event12)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard: Applying InputClass "system-keyboard"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Gaming Keyboard'
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 32 paused 0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard: always reports core events
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event12"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event12 - Gaming Keyboard: is tagged by udev as: Keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event12 - Gaming Keyboard: device is a keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event12 - Gaming Keyboard: device removed
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input39/event12"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard" (type: KEYBOARD, id 16)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard (/dev/input/event8)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 33 paused 0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event8"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event8  - Gaming Keyboard: is tagged by udev as: Keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event8  - Gaming Keyboard: device is a keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event8  - Gaming Keyboard: device removed
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.0/0003:1017:2010.000B/input/input35/event8"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard" (type: KEYBOARD, id 17)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard System Control (/dev/input/event11)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard System Control: Applying InputClass "evdev keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard System Control: Applying InputClass "libinput keyboard catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard System Control: Applying InputClass "system-keyboard"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Gaming Keyboard System Control'
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 34 paused 0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard System Control: always reports core events
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event11"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event11 - Gaming Keyboard System Control: is tagged by udev as: Keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event11 - Gaming Keyboard System Control: device is a keyboard
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event11 - Gaming Keyboard System Control: device removed
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input38/event11"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard System Control" (type: KEYBOARD, id 19)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) config/udev: Adding input device Gaming Keyboard Mouse (/dev/input/event9)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: Applying InputClass "evdev pointer catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: Applying InputClass "libinput pointer catchall"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) Using input driver 'libinput' for 'Gaming Keyboard Mouse'
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 56 paused 0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: always reports core events
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "Device" "/dev/input/event9"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event9  - Gaming Keyboard Mouse: is tagged by udev as: Mouse
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event9  - Gaming Keyboard Mouse: device is a pointer
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) event9  - Gaming Keyboard Mouse: device removed
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000C/input/input36/event9"
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (II) XINPUT: Adding extended input device "Gaming Keyboard Mouse" (type: MOUSE, id 20)
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: (accel) selected scheme none/0
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: (accel) acceleration factor: 2.000
Okt 31 10:56:56 machine /usr/lib/gdm-x-session[3190]: (**) Gaming Keyboard Mouse: (accel) acceleration threshold: 4
Okt 31 10:56:57 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:56:57 machine kernel: vfio-pci 0000:0b:00.0: Navi10: psp mode1 succeeded
Okt 31 10:56:57 machine kernel: vfio-pci 0000:0b:00.0: Navi10: memsize: 1ff0
Okt 31 10:56:57 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:56:58 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:56:59 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:01 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:02 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:03 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:04 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:05 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 10:57:05 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:06 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:07 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 10:57:07 machine kernel: vfio-pci 0000:0b:00.0: Navi10: timed out waiting for PSP bootloader to respond after reset
Okt 31 10:57:07 machine kernel: vfio-pci 0000:0b:00.0: refused to change power state from D0 to D3hot
Okt 31 10:57:07 machine systemd[1]: machine-qemu\x2d2\x2dgaming\x2dclone.scope: Succeeded.
Okt 31 10:57:07 machine systemd-machined[2194]: Machine qemu-2-gaming-clone terminated.
Okt 31 10:57:08 machine audit[2263]: VIRT_CONTROL pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=stop reason=shutdown vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=-1 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_MACHINE_ID pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-ctx=+1000:+992 img-ctx=+1000:+992 model=dac exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit: ANOM_PROMISCUOUS dev=vnet0 prom=256 old_prom=0 auid=4294967295 uid=0 gid=0 ses=4294967295
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=net reason=open vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 net=52:54:00:bf:2b:a7 path="/dev/net/tun" rdev=0A:C8 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine libvirtd[2263]: Domain id=3 name='gaming-clone' uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 is tainted: custom-argv
Okt 31 10:57:15 machine kernel: virbr0: port 2(vnet0) entered blocking state
Okt 31 10:57:15 machine kernel: virbr0: port 2(vnet0) entered disabled state
Okt 31 10:57:15 machine kernel: device vnet0 entered promiscuous mode
Okt 31 10:57:15 machine kernel: virbr0: port 2(vnet0) entered listening state
Okt 31 10:57:15 machine libvirtd[2263]: Domain id=3 name='gaming-clone' uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 is tainted: host-cpu
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3782] manager: (vnet0): new Tun device (/org/freedesktop/NetworkManager/Devices/7)
Okt 31 10:57:15 machine systemd-machined[2194]: New machine qemu-3-gaming-clone.
Okt 31 10:57:15 machine systemd[1]: Started Virtual Machine qemu-3-gaming-clone.
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3866] device (vnet0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3888] device (vnet0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3895] device (vnet0): Activation: starting connection 'vnet0' (78be6ea1-34af-4d48-b406-4717f74a361c)
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3898] device (vnet0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3901] device (vnet0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3955] device (vnet0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3957] device (virbr0): bridge port vnet0 was attached
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3957] device (vnet0): Activation: connection 'vnet0' enslaved, continuing activation
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.3959] device (vnet0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine dbus-daemon[2190]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=2191 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Okt 31 10:57:15 machine systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 31 10:57:15 machine dbus-daemon[2190]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Okt 31 10:57:15 machine systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 31 10:57:15 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.4052] device (vnet0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.4055] device (vnet0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Okt 31 10:57:15 machine NetworkManager[2191]: <info>  [1604138235.4064] device (vnet0): Activation: successful, device activated.
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=deny vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=all exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=major category=pty maj=88 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/null" rdev=01:03 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/full" rdev=01:07 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/zero" rdev=01:05 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/random" rdev=01:08 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/urandom" rdev=01:09 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/ptmx" rdev=05:02 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/kvm" rdev=0A:E8 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/vfio/25" rdev=F1:00 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/vfio/vfio" rdev=0A:C4 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:15 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=cgroup reason=allow vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 cgroup="/sys/fs/cgroup/devices/machine.slice/machine-qemu\x2d3\x2dgaming\x2dclone.scope/" class=path path="/dev/vfio/26" rdev=F1:01 acl=rw exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:17 machine kernel: virbr0: port 2(vnet0) entered learning state
Okt 31 10:57:18 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=01:00:5e:00:00:01:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: enabling device (0400 -> 0403)
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 10:57:18 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:57:19 machine kernel: virbr0: port 2(vnet0) entered forwarding state
Okt 31 10:57:19 machine kernel: virbr0: topology change detected, propagating
Okt 31 10:57:19 machine NetworkManager[2191]: <info>  [1604138239.5587] device (virbr0): carrier: link connected
Okt 31 10:57:20 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 10:57:20 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 10:57:21 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.1: enabling device (0000 -> 0002)
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 10:57:23 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:57:25 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 10:57:25 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:26 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00070000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 10:57:26 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 10:57:26 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:57:28 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=disk reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-disk="?" new-disk="/mnt/secondssd/Virtualization/libvirt/images/gaming-clone.qcow2" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=net reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-net="?" new-net="52:54:00:bf:2b:a7" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.0" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.1" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device=555342207265646972646576 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=shmem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 size=33554432 path=/dev/shm/looking-glass exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=mem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-mem=0 new-mem=30720000 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_RESOURCE pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=vcpu reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-vcpu=0 new-vcpu=12 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:57:29 machine audit[2263]: VIRT_CONTROL pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=start reason=booted vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=4367 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:58:00 machine audit: ANOM_PROMISCUOUS dev=vnet0 prom=0 old_prom=256 auid=4294967295 uid=1000 gid=992 ses=4294967295
Okt 31 10:58:00 machine kernel: virbr0: port 2(vnet0) entered disabled state
Okt 31 10:58:00 machine kernel: device vnet0 left promiscuous mode
Okt 31 10:58:00 machine NetworkManager[2191]: <info>  [1604138280.6968] device (vnet0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Okt 31 10:58:00 machine NetworkManager[2191]: <info>  [1604138280.6974] device (vnet0): released from master device virbr0
Okt 31 10:58:00 machine gnome-shell[3334]: Removing a network device that was not added
Okt 31 10:58:00 machine dbus-daemon[2190]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=2191 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Okt 31 10:58:00 machine systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 31 10:58:00 machine gnome-shell[3334]: JS ERROR: TypeError: this._devices[section] is undefined
Okt 31 10:58:00 machine dbus-daemon[2190]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Okt 31 10:58:00 machine systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 31 10:58:00 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.1: refused to change power state from D0 to D3hot
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 10:58:00 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:58:03 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00070000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 10:58:03 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 10:58:03 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 10:58:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 10:58:05 machine kernel: vfio-pci 0000:0b:00.0: refused to change power state from D0 to D3hot
Okt 31 10:58:06 machine systemd[1]: machine-qemu\x2d3\x2dgaming\x2dclone.scope: Succeeded.
Okt 31 10:58:06 machine systemd-machined[2194]: Machine qemu-3-gaming-clone terminated.
Okt 31 10:58:06 machine audit[2263]: VIRT_CONTROL pid=2263 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=stop reason=destroyed vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=-1 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 10:58:09 machine systemd[3171]: Started Application launched by gnome-shell.
Okt 31 10:58:09 machine dbus-daemon[3228]: [session uid=1000 pid=3228] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.82' (uid=1000 pid=4446 comm="gnome-terminal --window " label="unconfined")
Okt 31 10:58:09 machine systemd[3171]: Starting GNOME Terminal Server...
Okt 31 10:58:09 machine dbus-daemon[3228]: [session uid=1000 pid=3228] Successfully activated service 'org.gnome.Terminal'
Okt 31 10:58:09 machine systemd[3171]: Started GNOME Terminal Server.
Okt 31 10:58:09 machine systemd[3171]: Started VTE child process 4458 launched by gnome-terminal-server process 4451.
Okt 31 10:58:09 machine systemd[3171]: gnome-launched-org.gnome.Terminal.desktop-4446.scope: Succeeded.
Okt 31 10:58:10 machine systemd[3171]: Started Application launched by gnome-shell.
Okt 31 10:58:10 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 10:58:10 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 10:58:11 machine audit[4554]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4554 subj==unconfined comm=495043204C61756E6368
Okt 31 10:58:11 machine rtkit-daemon[2580]: Supervising 5 threads of 1 processes of 1 users.
Okt 31 10:58:11 machine rtkit-daemon[2580]: Successfully made thread 4575 of process 4463 owned by '1000' RT at priority 10.
Okt 31 10:58:11 machine rtkit-daemon[2580]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 10:58:12 machine audit[4554]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4554 subj==unconfined comm=495043204C61756E6368
Okt 31 10:58:12 machine rtkit-daemon[2580]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 10:58:13 machine systemd[3171]: Started Application launched by gnome-shell.
Okt 31 10:58:14 machine audit[4756]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4756 subj==unconfined comm="WhatsApp"
Okt 31 10:58:14 machine [email protected][3334]: Impossible to send about-to-show to menu: Gio.DBusError: GDBus.Error:org.freedesktop.DBus.Error.Failed: error occurred in AboutToShow
Okt 31 10:58:14 machine gnome-shell[3334]: JS ERROR: Exception in callback for signal: property-changed: GdkPixbuf.PixbufError: Unrecognized image file format
                                          _updateImage@/usr/share/gnome-shell/extensions/[email protected]/dbusMenu.js:649:49
                                          _onPropertyChanged@/usr/share/gnome-shell/extensions/[email protected]/dbusMenu.js:585:42
                                          _emit@resource:///org/gnome/gjs/modules/core/_signals.js:133:47
                                          property_set@/usr/share/gnome-shell/extensions/[email protected]/dbusMenu.js:126:14
                                          _endRequestProperties/<@/usr/share/gnome-shell/extensions/[email protected]/dbusMenu.js:289:22
                                          _endRequestProperties@/usr/share/gnome-shell/extensions/[email protected]/dbusMenu.js:283:19
                                          asyncCallback@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:132:13
Okt 31 10:58:18 machine systemd[3171]: Started Application launched by gnome-shell.
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 10:58:21 machine gnome-shell[3334]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Thanks for the logs. Interesting, on your card it seems one of my assumptions doesn’t hold. It looks like the card resets at least partially, but no signal on the second boot means something still got stuck.
One thing that I would be interested in seeing is what happens if you rebind the card to amdgpu after you shut your VM down. In my testing, this often hinted to me about the card’s internal state.
If you’re interested in getting those logs for me, the commands would be (provided amdgpu is not blacklisted):
echo 1 | sudo tee /sys/bus/pci/devices/0000:0b:00.0/remove
echo "0xvendor_id 0xdevice_id" | sudo tee /sys/bus/pci/drivers/vfio-pci/remove_id
echo "0xvendor_id 0xdevice_id" | sudo tee /sys/bus/pci/drivers/amdgpu/new_id
echo 1 | sudo tee /sys/bus/pci/rescan
and then capturing the kernel logs that amdgpu spits out.
I started the vm and shut it down again.
Then I ran your commands with my devices vendor- and device_id! This it the journalctl part that should be relevant:
Okt 31 17:56:53 machine kernel: cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
Okt 31 17:56:55 machine kernel: virbr0: port 2(vnet0) entered learning state
Okt 31 17:56:55 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 17:56:55 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: enabling device (0002 -> 0003)
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
Okt 31 17:56:56 machine kernel: vfio-pci 0000:0b:00.1: enabling device (0000 -> 0002)
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: removing device Razer Razer DeathAdder Essential
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (**) Option "fd" "30"
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) event7  - Razer Razer DeathAdder Essential: device removed
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) UnloadModule: "libinput"
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: releasing fd for 13:71
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: removing device Razer Razer DeathAdder Essential Keyboard
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (**) Option "fd" "33"
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) event8  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 17:56:56 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: releasing fd for 13:72
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: removing device Razer Razer DeathAdder Essential Consumer Control
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (**) Option "fd" "31"
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) UnloadModule: "libinput"
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: not releasing fd for 13:73, still in use
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) event9  - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: releasing fd for 13:73
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: removing device Razer Razer DeathAdder Essential System Control
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (**) Option "fd" "32"
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) event10 - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: releasing fd for 13:74
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (**) Option "fd" "34"
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) event12 - Razer Razer DeathAdder Essential: device removed
Okt 31 17:56:57 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: releasing fd for 13:76
Okt 31 17:56:57 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 0, sol reg: 0, mp1 intr enabled? no, bl ready? yes
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=disk reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-disk="?" new-disk="/mnt/secondssd/Virtualization/libvirt/images/gaming-clone.qcow2" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=net reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-net="?" new-net="52:54:00:bf:2b:a7" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.0" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.1" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device="003.004" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device=555342207265646972646576 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=shmem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 size=33554432 path=/dev/shm/looking-glass exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=mem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-mem=0 new-mem=30720000 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_RESOURCE pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=vcpu reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-vcpu=0 new-vcpu=12 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine audit[2264]: VIRT_CONTROL pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=start reason=booted vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=3946 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:57 machine NetworkManager[2194]: <info>  [1604163417.8794] device (virbr0): carrier: link connected
Okt 31 17:56:57 machine kernel: virbr0: port 2(vnet0) entered forwarding state
Okt 31 17:56:57 machine kernel: virbr0: topology change detected, propagating
Okt 31 17:56:57 machine systemd[1]: fprintd.service: Succeeded.
Okt 31 17:56:57 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:56:58 machine audit[313]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=313 subj==unconfined comm="kworker/u64:12"
Okt 31 17:57:02 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 17:57:02 machine kernel: retire_capture_urb: 29 callbacks suppressed
Okt 31 17:57:02 machine upowerd[2525]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 17:57:06 machine systemd[1]: systemd-localed.service: Succeeded.
Okt 31 17:57:06 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:06 machine systemd[1]: systemd-hostnamed.service: Succeeded.
Okt 31 17:57:06 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:06 machine gnome-shell[3312]: updates_checker.vala:65: check updates
Okt 31 17:57:06 machine audit[296]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=296 subj==unconfined comm="kworker/u64:7"
Okt 31 17:57:07 machine audit: BPF prog-id=15 op=UNLOAD
Okt 31 17:57:07 machine audit: BPF prog-id=14 op=UNLOAD
Okt 31 17:57:07 machine audit[296]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=296 subj==unconfined comm="kworker/u64:7"
Okt 31 17:57:07 machine audit: BPF prog-id=12 op=UNLOAD
Okt 31 17:57:07 machine audit: BPF prog-id=11 op=UNLOAD
Okt 31 17:57:08 machine gnome-shell[3312]: updates_checker.vala:95: 0 updates found
Okt 31 17:57:08 machine tracker-store[3755]: OK
Okt 31 17:57:08 machine systemd[3150]: tracker-store.service: Succeeded.
Okt 31 17:57:15 machine dnsmasq-dhcp[3926]: DHCPDISCOVER(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 17:57:15 machine dnsmasq-dhcp[3926]: DHCPOFFER(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 17:57:15 machine dnsmasq-dhcp[3926]: DHCPREQUEST(virbr0) 192.168.122.69 52:54:00:bf:2b:a7
Okt 31 17:57:15 machine dnsmasq-dhcp[3926]: DHCPACK(virbr0) 192.168.122.69 52:54:00:bf:2b:a7 Gaming-VM
Okt 31 17:57:15 machine kernel: nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based  firewall rule not found. Use the iptables CT target to attach helpers instead.
Okt 31 17:57:16 machine pulseaudio[3296]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Okt 31 17:57:16 machine pulseaudio[3296]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Okt 31 17:57:16 machine pulseaudio[3296]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Okt 31 17:57:27 machine geoclue[2529]: Service not used for 60 seconds. Shutting down..
Okt 31 17:57:27 machine systemd[1]: geoclue.service: Succeeded.
Okt 31 17:57:27 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:28 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 17:57:28 machine upowerd[2525]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 17:57:31 machine kernel: virbr0: port 2(vnet0) entered disabled state
Okt 31 17:57:31 machine audit: ANOM_PROMISCUOUS dev=vnet0 prom=0 old_prom=256 auid=4294967295 uid=1000 gid=992 ses=4294967295
Okt 31 17:57:31 machine kernel: device vnet0 left promiscuous mode
Okt 31 17:57:31 machine NetworkManager[2194]: <info>  [1604163451.9482] device (vnet0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Okt 31 17:57:31 machine NetworkManager[2194]: <info>  [1604163451.9488] device (vnet0): released from master device virbr0
Okt 31 17:57:31 machine gnome-shell[3312]: Removing a network device that was not added
Okt 31 17:57:31 machine dbus-daemon[2193]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=2194 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Okt 31 17:57:31 machine gnome-shell[3312]: JS ERROR: TypeError: this._devices[section] is undefined
                                          _connectionRemoved@resource:///org/gnome/shell/ui/status/network.js:1925:27
Okt 31 17:57:31 machine systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 31 17:57:31 machine dbus-daemon[2193]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Okt 31 17:57:31 machine systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 31 17:57:31 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:32 machine libvirtd[2264]: internal error: End of file from qemu monitor
Okt 31 17:57:32 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.0008/input/input29
Okt 31 17:57:32 machine kernel: hid-generic 0003:1532:006E.0008: input,hidraw3: USB HID v1.11 Mouse [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input0
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input30
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input31
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input32
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input33
Okt 31 17:57:32 machine kernel: hid-generic 0003:1532:006E.0009: input,hidraw4: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input1
Okt 31 17:57:32 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.000A/input/input34
Okt 31 17:57:32 machine upowerd[2525]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 17:57:32 machine kernel: hid-generic 0003:1532:006E.000A: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input2
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/mouse1)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) No input driver specified, ignoring this device.
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) This device may have been added with another device file.
Okt 31 17:57:32 machine systemd-logind[2196]: Watching system buttons on /dev/input/event8 (Razer Razer DeathAdder Essential Keyboard)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Keyboard (/dev/input/event8)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "evdev keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "libinput keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "system-keyboard"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Keyboard'
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 31 paused 0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Keyboard: always reports core events
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "Device" "/dev/input/event8"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "_source" "server/udev"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event8  - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event8  - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event8  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input30/event8"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Keyboard" (type: KEYBOARD, id 13)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "xkb_layout" "de"
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 575c898, mp1 intr enabled? yes, bl ready? no
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: gfx off
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Prep Reset
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 17:57:32 machine systemd-logind[2196]: Watching system buttons on /dev/input/event9 (Razer Razer DeathAdder Essential Consumer Control)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Consumer Control (/dev/input/event9)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 32 paused 0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "Device" "/dev/input/event9"
Okt 31 17:57:32 machine systemd-logind[2196]: Watching system buttons on /dev/input/event10 (Razer Razer DeathAdder Essential System Control)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event9  - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event9  - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event9  - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: needs a virtual subdevice
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input31/event9"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: MOUSE, id 14)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "AccelerationScheme" "none"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) selected scheme none/0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration factor: 2.000
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration threshold: 4
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: returning pre-existing fd for /dev/input/event9 13:73
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "_source" "_driver/libinput"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: is a virtual subdevice
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: KEYBOARD, id 15)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential System Control (/dev/input/event10)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "evdev keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "libinput keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "system-keyboard"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential System Control'
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 33 paused 0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential System Control: always reports core events
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "Device" "/dev/input/event10"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event10 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event10 - Razer Razer DeathAdder Essential System Control: device is a keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event10 - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.0009/input/input32/event10"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential System Control" (type: KEYBOARD, id 16)
Okt 31 17:57:32 machine systemd-logind[2196]: Watching system buttons on /dev/input/event12 (Razer Razer DeathAdder Essential)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event12)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput keyboard catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: Applying InputClass "system-keyboard"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 34 paused 0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: always reports core events
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "Device" "/dev/input/event12"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event12 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event12 - Razer Razer DeathAdder Essential: device is a keyboard
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event12 - Razer Razer DeathAdder Essential: device removed
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.000A/input/input34/event12"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: KEYBOARD, id 17)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event11)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event7)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev pointer catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput pointer catchall"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 55 paused 0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "Device" "/dev/input/event7"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event7  - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event7  - Razer Razer DeathAdder Essential: device is a pointer
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) event7  - Razer Razer DeathAdder Essential: device removed
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.0008/input/input29/event7"
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: MOUSE, id 20)
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: (accel) selected scheme none/0
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: (accel) acceleration factor: 2.000
Okt 31 17:57:32 machine /usr/lib/gdm-x-session[3169]: (**) Razer Razer DeathAdder Essential: (accel) acceleration threshold: 4
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 17:57:32 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: psp mode1 succeeded
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: memsize: 1ff0
Okt 31 17:57:32 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 17:57:33 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 17:57:34 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP bootloader flags? 0, timeout: no
Okt 31 17:57:34 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP mode1 reset successful
Okt 31 17:57:34 machine systemd[1]: machine-qemu\x2d1\x2dgaming\x2dclone.scope: Succeeded.
Okt 31 17:57:34 machine systemd-machined[2197]: Machine qemu-1-gaming-clone terminated.
Okt 31 17:57:35 machine audit[2264]: VIRT_CONTROL pid=2264 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=stop reason=shutdown vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=-1 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:38 machine gnome-shell[3312]: Ignoring excess values in shadow definition
Okt 31 17:57:41 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 17:57:41 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:57:48 machine systemd[3150]: Started Application launched by gnome-shell.
Okt 31 17:57:49 machine audit[4169]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4169 subj==unconfined comm=495043204C61756E6368
Okt 31 17:57:49 machine rtkit-daemon[2548]: Supervising 5 threads of 1 processes of 1 users.
Okt 31 17:57:49 machine rtkit-daemon[2548]: Successfully made thread 4192 of process 4078 owned by '1000' RT at priority 10.
Okt 31 17:57:49 machine rtkit-daemon[2548]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 17:57:50 machine audit[4169]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4169 subj==unconfined comm=495043204C61756E6368
Okt 31 17:57:50 machine rtkit-daemon[2548]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 17:58:04 machine systemd[3150]: Started Application launched by gnome-shell.
Okt 31 17:58:04 machine dbus-daemon[3206]: [session uid=1000 pid=3206] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.78' (uid=1000 pid=4400 comm="gnome-terminal --window " label="unconfined")
Okt 31 17:58:04 machine systemd[3150]: Created slice apps.slice.
Okt 31 17:58:04 machine systemd[3150]: Created slice apps-org.gnome.Terminal.slice.
Okt 31 17:58:04 machine systemd[3150]: Starting GNOME Terminal Server...
Okt 31 17:58:04 machine dbus-daemon[3206]: [session uid=1000 pid=3206] Successfully activated service 'org.gnome.Terminal'
Okt 31 17:58:04 machine systemd[3150]: Started GNOME Terminal Server.
Okt 31 17:58:04 machine systemd[3150]: Started VTE child process 4412 launched by gnome-terminal-server process 4405.
Okt 31 17:58:04 machine systemd[3150]: gnome-launched-org.gnome.Terminal.desktop-4400.scope: Succeeded.
Okt 31 17:58:08 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=01:00:5e:00:00:01:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Okt 31 17:58:09 machine dbus-daemon[2193]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.164' (uid=0 pid=4417 comm="sudo tee /sys/bus/pci/devices/0000:0b:00.0/remove " label="unconfined")
Okt 31 17:58:09 machine systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 31 17:58:09 machine audit[4418]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4418 subj==unconfined comm="(fprintd)"
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 17:58:09 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 17:58:09 machine dbus-daemon[2193]: [system] Successfully activated service 'net.reactivated.Fprint'
Okt 31 17:58:09 machine systemd[1]: Started Fingerprint Authentication Daemon.
Okt 31 17:58:09 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:58:14 machine audit[4417]: USER_AUTH pid=4417 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine dbus-daemon[2193]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.166' (uid=0 pid=4417 comm="sudo tee /sys/bus/pci/devices/0000:0b:00.0/remove " label="unconfined")
Okt 31 17:58:14 machine dbus-daemon[2193]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:58:14 machine audit[4417]: USER_ACCT pid=4417 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine audit[4417]: CRED_REFR pid=4417 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine audit[4417]: USER_START pid=4417 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine sudo[4417]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:58:14 machine sudo[4417]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/devices/0000:0b:00.0/remove
Okt 31 17:58:14 machine sudo[4417]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 17:58:14 machine sudo[4417]: pam_unix(sudo:session): session closed for user root
Okt 31 17:58:14 machine audit[4417]: USER_END pid=4417 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine audit[4417]: CRED_DISP pid=4417 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:14 machine kernel: vfio-pci 0000:0b:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
Okt 31 17:58:14 machine kernel: pci 0000:0b:00.0: Removing from iommu group 25
Okt 31 17:58:17 machine gnome-shell[3312]: Some code accessed the property 'discreteGpuAvailable' on the module 'appDisplay'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
Okt 31 17:58:18 machine systemd[3150]: Started Application launched by gnome-shell.
Okt 31 17:58:18 machine systemd[3150]: Started VTE child process 4433 launched by gnome-terminal-server process 4405.
Okt 31 17:58:18 machine systemd[3150]: gnome-launched-org.gnome.Terminal.desktop-4427.scope: Succeeded.
Okt 31 17:58:23 machine /usr/lib/gdm-x-session[3169]: (EE) event2  - Gaming Keyboard: client bug: event processing lagging behind by 26ms, your system is too slow
Okt 31 17:58:38 machine systemd[1]: fprintd.service: Succeeded.
Okt 31 17:58:38 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 17:58:39 machine audit[247]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=247 subj==unconfined comm="kworker/u64:1"
Okt 31 17:58:45 machine /usr/lib/gdm-x-session[3169]: (EE) event2  - Gaming Keyboard: client bug: event processing lagging behind by 23ms, your system is too slow
Okt 31 17:58:55 machine dbus-daemon[2193]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.172' (uid=0 pid=4449 comm="sudo tee /sys/bus/pci/drivers/vfio-pci/remove_id " label="unconfined")
Okt 31 17:58:55 machine dbus-daemon[2193]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:58:55 machine audit[4449]: USER_ACCT pid=4449 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:55 machine audit[4449]: CRED_REFR pid=4449 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:55 machine audit[4449]: USER_START pid=4449 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:55 machine sudo[4449]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:58:55 machine audit[4449]: USER_END pid=4449 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:55 machine audit[4449]: CRED_DISP pid=4449 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:58:55 machine sudo[4449]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/drivers/vfio-pci/remove_id
Okt 31 17:58:55 machine sudo[4449]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 17:58:55 machine sudo[4449]: pam_unix(sudo:session): session closed for user root
Okt 31 17:59:12 machine dbus-daemon[2193]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.173' (uid=0 pid=4452 comm="sudo tee /sys/bus/pci/drivers/amdgpu/new_id " label="unconfined")
Okt 31 17:59:12 machine audit[4452]: USER_ACCT pid=4452 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:12 machine audit[4452]: CRED_REFR pid=4452 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:12 machine dbus-daemon[2193]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:59:12 machine sudo[4452]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:59:12 machine sudo[4452]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/drivers/amdgpu/new_id
Okt 31 17:59:12 machine sudo[4452]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 17:59:12 machine audit[4452]: USER_START pid=4452 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:12 machine sudo[4452]: pam_unix(sudo:session): session closed for user root
Okt 31 17:59:12 machine audit[4452]: USER_END pid=4452 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:12 machine audit[4452]: CRED_DISP pid=4452 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:14 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:86:dd SRC=2a02:8109:a1c0:09cc:e228:6dff:fe41:1229 DST=2a02:8109:a1c0:09cc:a059:83ce:63fa:9b79 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=38148 DPT=80 WINDOW=14400 RES=0x00 SYN URGP=0
Okt 31 17:59:15 machine systemd-timesyncd[2017]: Timed out waiting for reply from [2a01:4f8:241:460a::118]:123 (2.manjaro.pool.ntp.org).
Okt 31 17:59:15 machine systemd-timesyncd[2017]: Initial synchronization to time server [2a01:4f8:c0c:1eb0::1]:123 (2.manjaro.pool.ntp.org).
Okt 31 17:59:17 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:86:dd SRC=2a02:8109:a1c0:09cc:e228:6dff:fe41:1229 DST=2a02:8109:a1c0:09cc:a059:83ce:63fa:9b79 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=38148 DPT=80 WINDOW=14400 RES=0x00 SYN URGP=0
Okt 31 17:59:22 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=192.168.178.25 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=26790 DF PROTO=TCP SPT=39335 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Okt 31 17:59:25 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=192.168.178.25 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=26791 DF PROTO=TCP SPT=39335 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Okt 31 17:59:25 machine dbus-daemon[2193]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.174' (uid=0 pid=4455 comm="sudo tee /sys/bus/pci/rescan " label="unconfined")
Okt 31 17:59:25 machine dbus-daemon[2193]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:59:25 machine audit[4455]: USER_ACCT pid=4455 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:25 machine audit[4455]: CRED_REFR pid=4455 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:25 machine sudo[4455]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 17:59:25 machine sudo[4455]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/rescan
Okt 31 17:59:25 machine sudo[4455]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 17:59:25 machine audit[4455]: USER_START pid=4455 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: [1002:731f] type 00 class 0x030000
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: reg 0x10: [mem 0xb0000000-0xbfffffff 64bit pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: reg 0x18: [mem 0xc0000000-0xc01fffff 64bit pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: reg 0x20: [io  0xd000-0xd0ff]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: reg 0x24: [mem 0xfcc00000-0xfcc7ffff]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: reg 0x30: [mem 0xfcc80000-0xfcc9ffff pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: PME# supported from D1 D2 D3hot D3cold
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:03.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: Adding to iommu group 25
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: BAR 0: assigned [mem 0xb0000000-0xbfffffff 64bit pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: BAR 2: assigned [mem 0xc0000000-0xc01fffff 64bit pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: BAR 5: assigned [mem 0xfcc00000-0xfcc7ffff]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: BAR 6: assigned [mem 0xfcc80000-0xfcc9ffff pref]
Okt 31 17:59:25 machine kernel: pci 0000:0b:00.0: BAR 4: assigned [io  0xd000-0xd0ff]
Okt 31 17:59:25 machine kernel: amdgpu 0000:0b:00.0: enabling device (0400 -> 0403)
Okt 31 17:59:25 machine kernel: [drm] initializing kernel modesetting (NAVI10 0x1002:0x731F 0x1002:0x0B36 0xC1).
Okt 31 17:59:25 machine kernel: amdgpu 0000:0b:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Okt 31 17:59:25 machine kernel: [drm] register mmio base: 0xFCC00000
Okt 31 17:59:25 machine kernel: [drm] register mmio size: 524288
Okt 31 17:59:25 machine kernel: [drm] add ip block number 0 <nv_common>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 1 <gmc_v10_0>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 2 <navi10_ih>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 3 <psp>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 4 <smu>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 5 <gfx_v10_0>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 6 <sdma_v5_0>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 7 <vcn_v2_0>
Okt 31 17:59:25 machine kernel: [drm] add ip block number 8 <jpeg_v2_0>
Okt 31 17:59:25 machine kernel: amdgpu: ATOM BIOS: 113-D1993701-XT
Okt 31 17:59:25 machine kernel: [drm] VCN decode is enabled in VM mode
Okt 31 17:59:25 machine kernel: [drm] VCN encode is enabled in VM mode
Okt 31 17:59:25 machine kernel: [drm] JPEG decode is enabled in VM mode
Okt 31 17:59:25 machine kernel: [drm] GPU posting now...
Okt 31 17:59:25 machine kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
Okt 31 17:59:25 machine kernel: amdgpu 0000:0b:00.0: amdgpu: VRAM: 8176M 0x0000008000000000 - 0x00000081FEFFFFFF (8176M used)
Okt 31 17:59:25 machine kernel: amdgpu 0000:0b:00.0: amdgpu: GART: 512M 0x0000000000000000 - 0x000000001FFFFFFF
Okt 31 17:59:25 machine kernel: [drm] Detected VRAM RAM=8176M, BAR=256M
Okt 31 17:59:25 machine kernel: [drm] RAM width 256bits GDDR6
Okt 31 17:59:25 machine kernel: [drm] amdgpu: 8176M of VRAM memory ready
Okt 31 17:59:25 machine kernel: [drm] amdgpu: 8176M of GTT memory ready.
Okt 31 17:59:25 machine kernel: [drm] GART: num cpu pages 131072, num gpu pages 131072
Okt 31 17:59:25 machine kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000000000).
Okt 31 17:59:25 machine kernel: [drm] Found VCN firmware Version ENC: 1.10 DEC: 5 VEP: 0 Revision: 13
Okt 31 17:59:25 machine kernel: [drm] PSP loading VCN firmware
Okt 31 17:59:26 machine kernel: [drm] reserve 0x900000 from 0x81fe400000 for PSP TMR
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: RAS: optional ras ta ucode is not available
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: use vbios provided pptable
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: smc_dpm_info table revision(format.content): 4.5
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: SMU is initialized successfully!
Okt 31 17:59:26 machine kernel: [drm] kiq ring mec 2 pipe 1 q 0
Okt 31 17:59:26 machine kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Okt 31 17:59:26 machine kernel: [drm] JPEG decode initialized successfully.
Okt 31 17:59:26 machine kernel: kfd kfd: Allocated 3969056 bytes on gart
Okt 31 17:59:26 machine kernel: Virtual CRAT table created for GPU
Okt 31 17:59:26 machine kernel: amdgpu: Topology: Add dGPU node [0x731f:0x1002]
Okt 31 17:59:26 machine kernel: kfd kfd: added device 1002:731f
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: SE 2, SH per SE 2, CU per SH 10, active_cu_number 40
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring vcn_dec uses VM inv eng 0 on hub 1
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 1 on hub 1
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 4 on hub 1
Okt 31 17:59:26 machine kernel: amdgpu 0000:0b:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 1
Okt 31 17:59:26 machine kernel: [drm] Initialized amdgpu 3.39.0 20150101 for 0000:0b:00.0 on minor 1
Okt 31 17:59:26 machine audit[4455]: USER_END pid=4455 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:26 machine audit[4455]: CRED_DISP pid=4455 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 17:59:26 machine sudo[4455]: pam_unix(sudo:session): session closed for user root
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): EDID vendor "HPN", prod id 13178
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Using hsync ranges from config file
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Using vrefresh ranges from config file
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Printing DDC gathered Modelines:
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "2560x1440"x0.0  295.12  2560 2568 2600 2640  1440 1478 1486 1492 +hsync -vsync (111.8 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: removing GPU device /sys/devices/pci0000:00/0000:00:03.2/0000:09:00.0/0000:0a:00.0/0000:0b:00.0/drm/card1 /dev/dri/card1
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) config/udev: Adding drm device (/dev/dri/card1)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) xfree86: Adding drm device (/dev/dri/card1)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.2/0000:09:00.0/0000:0a:00.0/0000:0b:00.0/drm/card1
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 67 paused 0
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) LoadModule: "modesetting"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Module modesetting: vendor="X.Org Foundation"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         compiled for 1.20.9, module version = 1.20.9
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         Module class: X.Org Video Driver
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         ABI class: X.Org Video Driver, version 24.1
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): using drv /dev/dri/card1
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): Using 24bpp hw front buffer with 32bpp shadow
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): RGB weight 888
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): Default visual is TrueColor
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (**) modeset(G0): Cannot use glamor with 24bpp packed fb
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): ShadowFB: preferred YES, enabled FORCE
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): Double-buffered shadow updates: off
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (**) modeset(G0): Display dimensions: (710, 400) mm
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (**) modeset(G0): DPI set to (36, 48)
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Loading sub module "fb"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) LoadModule: "fb"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Loading /usr/lib/xorg/modules/libfb.so
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Module fb: vendor="X.Org Foundation"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         compiled for 1.20.9, module version = 1.0.0
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         ABI class: X.Org ANSI C Emulation, version 0.4
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Loading sub module "shadow"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) LoadModule: "shadow"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Loading /usr/lib/xorg/modules/libshadow.so
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) Module shadow: vendor="X.Org Foundation"
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]:         compiled for 1.20.9, module version = 1.1.0
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): Backing store enabled
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): Silken mouse disabled
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (==) modeset(G0): DPMS enabled
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: (II) modeset(G0): Damage tracking initialized
Okt 31 17:59:26 machine /usr/lib/gdm-x-session[3169]: xf86: found device 2
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): EDID vendor "HPN", prod id 13178
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Using hsync ranges from config file
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Using vrefresh ranges from config file
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Printing DDC gathered Modelines:
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz eP)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "2560x1440"x0.0  295.12  2560 2568 2600 2640  1440 1478 1486 1492 +hsync -vsync (111.8 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x720"x0.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1440x900"x0.0   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
Okt 31 17:59:27 machine /usr/lib/gdm-x-session[3169]: (II) AMDGPU(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz e)
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 17:59:27 machine gnome-shell[3312]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 17:59:32 machine kernel: [drm] free PSP TMR buffer
Huh, this time it reset successfully. Was there anything you did differently this time other than shutdown instead of reboot?
This was even weirder then you think!
After you wrote me it did reset successfully I checked and turned on the vm again. It did start for a second time this time around.However after shutting it down my complete session was stuck. I could not even move the not-vm-bound mouse anymore and had to reboot.
After a reboot I have a successful first vm start again and then no signal on the second try. Since it did not reset again, here is the output for that:
Part1:
Okt 31 18:18:04 machine kernel: virbr0: port 2(vnet0) entered learning state
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: enabling device (0400 -> 0403)
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 18:18:05 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:18:06 machine kernel: virbr0: port 2(vnet0) entered forwarding state
Okt 31 18:18:06 machine kernel: virbr0: topology change detected, propagating
Okt 31 18:18:06 machine NetworkManager[2216]: <info>  [1604164686.6515] device (virbr0): carrier: link connected
Okt 31 18:18:07 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 18:18:07 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 18:18:08 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x19@0x270
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x1b@0x2d0
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x25@0x400
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x26@0x410
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.0: vfio_ecap_init: hiding ecap 0x27@0x440
Okt 31 18:18:10 machine kernel: vfio-pci 0000:0b:00.1: enabling device (0000 -> 0002)
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Razer Razer DeathAdder Essential
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "54"
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) event8  - Razer Razer DeathAdder Essential: device removed
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) UnloadModule: "libinput"
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:72
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Razer Razer DeathAdder Essential Keyboard
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "33"
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) event9  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:73
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Razer Razer DeathAdder Essential Consumer Control
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "32"
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: not releasing fd for 13:74, still in use
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) event10 - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 18:18:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:74
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Razer Razer DeathAdder Essential System Control
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "35"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event11 - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) UnloadModule: "libinput"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:75
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "34"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event13 - Razer Razer DeathAdder Essential: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:77
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Gaming Keyboard
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "26"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event2  - Gaming Keyboard: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:66
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Gaming Keyboard Mouse
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "27"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event3  - Gaming Keyboard Mouse: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:67
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Gaming Keyboard Consumer Control
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "28"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: not releasing fd for 13:68, still in use
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event4  - Gaming Keyboard Consumer Control: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:68
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: removing device Gaming Keyboard System Control
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "29"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event5  - Gaming Keyboard System Control: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:69
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (**) Option "fd" "30"
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) event6  - Gaming Keyboard: device removed
Okt 31 18:18:11 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: releasing fd for 13:70
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 18:18:11 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:18:12 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 18:18:12 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:14 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00070000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 18:18:14 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 18:18:14 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:18:16 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=disk reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-disk="?" new-disk="/mnt/secondssd/Virtualization/libvirt/images/gaming-clone.qcow2" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=net reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-net="?" new-net="52:54:00:bf:2b:a7" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.0" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=pci device="0000:0b:00.1" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device="003.004" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device="003.003" exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=dev reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 bus=usb device=555342207265646972646576 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=shmem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 size=33554432 path=/dev/shm/looking-glass exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=mem reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-mem=0 new-mem=30720000 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_RESOURCE pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm resrc=vcpu reason=start vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 old-vcpu=0 new-vcpu=12 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:17 machine audit[2287]: VIRT_CONTROL pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=start reason=booted vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=4257 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:18:30 machine pulseaudio[3310]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Okt 31 18:18:30 machine pulseaudio[3310]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Okt 31 18:18:30 machine pulseaudio[3310]: E: [alsa-sink-ALC1220 Analog] alsa-sink.c: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Okt 31 18:18:44 machine systemd-timesyncd[2038]: Timed out waiting for reply from [2a03:4000:41:47b::1]:123 (2.manjaro.pool.ntp.org).
Okt 31 18:18:54 machine systemd-timesyncd[2038]: Timed out waiting for reply from [2a01:4f8:c2c:b3d6::1]:123 (2.manjaro.pool.ntp.org).
Okt 31 18:18:54 machine systemd-timesyncd[2038]: Initial synchronization to time server [2606:4700:f1::123]:123 (2.manjaro.pool.ntp.org).
Okt 31 18:18:58 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=01:00:5e:00:00:01:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Okt 31 18:19:08 machine kernel: virbr0: port 2(vnet0) entered disabled state
Okt 31 18:19:08 machine audit: ANOM_PROMISCUOUS dev=vnet0 prom=0 old_prom=256 auid=4294967295 uid=1000 gid=992 ses=4294967295
Okt 31 18:19:08 machine kernel: device vnet0 left promiscuous mode
Okt 31 18:19:08 machine NetworkManager[2216]: <info>  [1604164748.8558] device (vnet0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Okt 31 18:19:08 machine NetworkManager[2216]: <info>  [1604164748.8561] device (vnet0): released from master device virbr0
Okt 31 18:19:08 machine gnome-shell[3326]: Removing a network device that was not added
Okt 31 18:19:08 machine dbus-daemon[2215]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=2216 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Okt 31 18:19:08 machine gnome-shell[3326]: JS ERROR: TypeError: this._devices[section] is undefined
                                          _connectionRemoved@resource:///org/gnome/shell/ui/status/network.js:1925:27
Okt 31 18:19:08 machine systemd[1]: Starting Network Manager Script Dispatcher Service...
Okt 31 18:19:08 machine dbus-daemon[2215]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Okt 31 18:19:08 machine systemd[1]: Started Network Manager Script Dispatcher Service.
Okt 31 18:19:08 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 18:19:09 machine kernel: usb 3-6.2: reset low-speed USB device number 3 using xhci_hcd
Okt 31 18:19:09 machine kernel: input: Gaming Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.0/0003:1017:2010.000C/input/input36
Okt 31 18:19:09 machine kernel: hid-generic 0003:1017:2010.000C: input,hidraw1: USB HID v1.10 Keyboard [Gaming Keyboard] on usb-0000:05:00.3-6.2/input0
Okt 31 18:19:09 machine kernel: input: Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input37
Okt 31 18:19:09 machine kernel: input: Gaming Keyboard Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input38
Okt 31 18:19:09 machine upowerd[2547]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2
Okt 31 18:19:09 machine kernel: input: Gaming Keyboard System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input39
Okt 31 18:19:09 machine kernel: input: Gaming Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input40
Okt 31 18:19:09 machine kernel: hid-generic 0003:1017:2010.000D: input,hiddev1,hidraw2: USB HID v1.10 Mouse [Gaming Keyboard] on usb-0000:05:00.3-6.2/input1
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard Mouse (/dev/input/mouse0)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) No input driver specified, ignoring this device.
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) This device may have been added with another device file.
Okt 31 18:19:09 machine kernel: usb 3-6.3: reset full-speed USB device number 4 using xhci_hcd
Okt 31 18:19:09 machine systemd-logind[2218]: Watching system buttons on /dev/input/event5 (Gaming Keyboard System Control)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard System Control (/dev/input/event5)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard System Control: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard System Control: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard System Control: Applying InputClass "system-keyboard"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Gaming Keyboard System Control'
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 30 paused 0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard System Control: always reports core events
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event5"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "_source" "server/udev"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event5  - Gaming Keyboard System Control: is tagged by udev as: Keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event5  - Gaming Keyboard System Control: device is a keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event5  - Gaming Keyboard System Control: device removed
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input39/event5"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard System Control" (type: KEYBOARD, id 9)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "xkb_layout" "de"
Okt 31 18:19:09 machine systemd-logind[2218]: Watching system buttons on /dev/input/event2 (Gaming Keyboard)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard (/dev/input/event2)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard: Applying InputClass "system-keyboard"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Gaming Keyboard'
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 32 paused 0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard: always reports core events
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event2"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event2  - Gaming Keyboard: is tagged by udev as: Keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event2  - Gaming Keyboard: device is a keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event2  - Gaming Keyboard: device removed
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.0/0003:1017:2010.000C/input/input36/event2"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard" (type: KEYBOARD, id 10)
Okt 31 18:19:09 machine systemd-logind[2218]: Watching system buttons on /dev/input/event4 (Gaming Keyboard Consumer Control)
Okt 31 18:19:09 machine systemd-logind[2218]: Watching system buttons on /dev/input/event6 (Gaming Keyboard)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard Consumer Control (/dev/input/event4)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: Applying InputClass "system-keyboard"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Gaming Keyboard Consumer Control'
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 33 paused 0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: always reports core events
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event4"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event4  - Gaming Keyboard Consumer Control: is tagged by udev as: Keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event4  - Gaming Keyboard Consumer Control: device is a keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event4  - Gaming Keyboard Consumer Control: device removed
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) libinput: Gaming Keyboard Consumer Control: needs a virtual subdevice
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input38/event4"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard Consumer Control" (type: MOUSE, id 11)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "AccelerationScheme" "none"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: (accel) selected scheme none/0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: (accel) acceleration factor: 2.000
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Consumer Control: (accel) acceleration threshold: 4
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: returning pre-existing fd for /dev/input/event4 13:68
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "_source" "_driver/libinput"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) libinput: Gaming Keyboard Consumer Control: is a virtual subdevice
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard Consumer Control" (type: KEYBOARD, id 12)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard Mouse (/dev/input/event3)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: Applying InputClass "evdev pointer catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: Applying InputClass "libinput pointer catchall"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Gaming Keyboard Mouse'
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 34 paused 0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: always reports core events
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event3"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event3  - Gaming Keyboard Mouse: is tagged by udev as: Mouse
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event3  - Gaming Keyboard Mouse: device is a pointer
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event3  - Gaming Keyboard Mouse: device removed
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input37/event3"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard Mouse" (type: MOUSE, id 13)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: (accel) selected scheme none/0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: (accel) acceleration factor: 2.000
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Gaming Keyboard Mouse: (accel) acceleration threshold: 4
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Gaming Keyboard (/dev/input/event6)
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 35 paused 0
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event6"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event6  - Gaming Keyboard: is tagged by udev as: Keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event6  - Gaming Keyboard: device is a keyboard
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) event6  - Gaming Keyboard: device removed
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.2/3-6.2:1.1/0003:1017:2010.000D/input/input40/event6"
Okt 31 18:19:09 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Gaming Keyboard" (type: KEYBOARD, id 14)
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.000E/input/input42
Okt 31 18:19:09 machine kernel: hid-generic 0003:1532:006E.000E: input,hidraw4: USB HID v1.11 Mouse [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input0
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential Keyboard as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input43
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 18:19:09 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input44
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential System Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input45
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input46
Okt 31 18:19:09 machine kernel: hid-generic 0003:1532:006E.000F: input,hidraw5: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input1
Okt 31 18:19:09 machine kernel: input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.0010/input/input47
Okt 31 18:19:10 machine upowerd[2547]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3
Okt 31 18:19:10 machine kernel: hid-generic 0003:1532:006E.0010: input,hidraw6: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:05:00.3-6.3/input2
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/mouse2)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) No input driver specified, ignoring this device.
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) This device may have been added with another device file.
Okt 31 18:19:10 machine systemd-logind[2218]: Watching system buttons on /dev/input/event10 (Razer Razer DeathAdder Essential Consumer Control)
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.1: refused to change power state from D0 to D3hot
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: SMU response reg: 1, sol reg: 0, mp1 intr enabled? no, bl ready? no
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clear master
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: Clearing scratch regs 6 and 7
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin reset
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: begin psp mode 1 reset
Okt 31 18:19:10 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:19:10 machine systemd-logind[2218]: Watching system buttons on /dev/input/event9 (Razer Razer DeathAdder Essential Keyboard)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Consumer Control (/dev/input/event10)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 54 paused 0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event10"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "_source" "server/udev"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event10 - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event10 - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event10 - Razer Razer DeathAdder Essential Consumer Control: device removed
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: needs a virtual subdevice
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input44/event10"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: MOUSE, id 15)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "AccelerationScheme" "none"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) selected scheme none/0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration factor: 2.000
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration threshold: 4
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: returning pre-existing fd for /dev/input/event10 13:74
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "_source" "_driver/libinput"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) libinput: Razer Razer DeathAdder Essential Consumer Control: is a virtual subdevice
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: KEYBOARD, id 16)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "xkb_layout" "de"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential Keyboard (/dev/input/event9)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "system-keyboard"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Keyboard'
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 57 paused 0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential Keyboard: always reports core events
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event9"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event9  - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event9  - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event9  - Razer Razer DeathAdder Essential Keyboard: device removed
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input43/event9"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Keyboard" (type: KEYBOARD, id 17)
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 18:19:10 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event12)
Okt 31 18:19:10 machine systemd-logind[2218]: Watching system buttons on /dev/input/event11 (Razer Razer DeathAdder Essential System Control)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential System Control (/dev/input/event11)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "system-keyboard"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential System Control'
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 58 paused 0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential System Control: always reports core events
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event11"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event11 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event11 - Razer Razer DeathAdder Essential System Control: device is a keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event11 - Razer Razer DeathAdder Essential System Control: device removed
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.1/0003:1532:006E.000F/input/input45/event11"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential System Control" (type: KEYBOARD, id 18)
Okt 31 18:19:10 machine systemd-logind[2218]: Watching system buttons on /dev/input/event13 (Razer Razer DeathAdder Essential)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event13)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput keyboard catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: Applying InputClass "system-keyboard"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event13 13:77 fd 59 paused 0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: always reports core events
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event13"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event13 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event13 - Razer Razer DeathAdder Essential: device is a keyboard
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event13 - Razer Razer DeathAdder Essential: device removed
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.2/0003:1532:006E.0010/input/input47/event13"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: KEYBOARD, id 20)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event8)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev pointer catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput pointer catchall"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 60 paused 0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "Device" "/dev/input/event8"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event8  - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event8  - Razer Razer DeathAdder Essential: device is a pointer
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) event8  - Razer Razer DeathAdder Essential: device removed
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.3/usb3/3-6/3-6.3/3-6.3:1.0/0003:1532:006E.000E/input/input42/event8"
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: MOUSE, id 21)
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: (accel) selected scheme none/0
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: (accel) acceleration factor: 2.000
Okt 31 18:19:10 machine /usr/lib/gdm-x-session[3184]: (**) Razer Razer DeathAdder Essential: (accel) acceleration threshold: 4
Part2:
Okt 31 18:19:12 machine systemd[3165]: Started Application launched by gnome-shell.
Okt 31 18:19:12 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016080 (0x00070000, masked 0x00000000) did not reach needed value (0x80000000), (line 4242)
Okt 31 18:19:12 machine kernel: vfio-pci 0000:0b:00.0: Navi10: do mode1 reset
Okt 31 18:19:12 machine kernel: vfio-pci 0000:0b:00.0: Navi10: PSP wait
Okt 31 18:19:12 machine audit[4450]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4450 subj==unconfined comm=495043204C61756E6368
Okt 31 18:19:13 machine rtkit-daemon[2576]: Supervising 5 threads of 1 processes of 1 users.
Okt 31 18:19:13 machine rtkit-daemon[2576]: Successfully made thread 4473 of process 4359 owned by '1000' RT at priority 10.
Okt 31 18:19:13 machine rtkit-daemon[2576]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 18:19:13 machine audit[4450]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4450 subj==unconfined comm=495043204C61756E6368
Okt 31 18:19:14 machine rtkit-daemon[2576]: Supervising 6 threads of 2 processes of 1 users.
Okt 31 18:19:15 machine kernel: vfio-pci 0000:0b:00.0: Navi10: reg 00016061 (0x00000000, masked 0x00000000) did not reach needed value (0x80000000), (line 4251)
Okt 31 18:19:15 machine kernel: vfio-pci 0000:0b:00.0: refused to change power state from D0 to D3hot
Okt 31 18:19:15 machine systemd[1]: machine-qemu\x2d2\x2dgaming\x2dclone.scope: Succeeded.
Okt 31 18:19:15 machine systemd-machined[2219]: Machine qemu-2-gaming-clone terminated.
Okt 31 18:19:15 machine audit[2287]: VIRT_CONTROL pid=2287 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='virt=kvm op=stop reason=destroyed vm="gaming-clone" uuid=818f0a36-cfb5-49f8-ae93-12d6d3c29741 vm-pid=-1 exe="/usr/bin/libvirtd" hostname=? addr=? terminal=? res=success'
Okt 31 18:19:18 machine systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Okt 31 18:19:18 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 18:19:21 machine systemd[3165]: Started Application launched by gnome-shell.
Okt 31 18:19:21 machine dbus-daemon[3220]: [session uid=1000 pid=3220] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.80' (uid=1000 pid=4687 comm="gnome-terminal --window " label="unconfined")
Okt 31 18:19:21 machine systemd[3165]: Starting GNOME Terminal Server...
Okt 31 18:19:21 machine dbus-daemon[3220]: [session uid=1000 pid=3220] Successfully activated service 'org.gnome.Terminal'
Okt 31 18:19:21 machine systemd[3165]: Started GNOME Terminal Server.
Okt 31 18:19:21 machine systemd[3165]: Started VTE child process 4698 launched by gnome-terminal-server process 4691.
Okt 31 18:19:21 machine systemd[3165]: gnome-launched-org.gnome.Terminal.desktop-4687.scope: Succeeded.
Okt 31 18:19:28 machine dbus-daemon[2215]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.175' (uid=0 pid=4708 comm="sudo tee /sys/bus/pci/devices/0000:0b:00.0/remove " label="unconfined")
Okt 31 18:19:28 machine systemd[1]: Starting Fingerprint Authentication Daemon...
Okt 31 18:19:28 machine audit[4709]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_register pid=4709 subj==unconfined comm="(fprintd)"
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Okt 31 18:19:28 machine gnome-shell[3326]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Okt 31 18:19:28 machine dbus-daemon[2215]: [system] Successfully activated service 'net.reactivated.Fprint'
Okt 31 18:19:28 machine systemd[1]: Started Fingerprint Authentication Daemon.
Okt 31 18:19:28 machine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 18:19:34 machine audit[4708]: USER_AUTH pid=4708 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine dbus-daemon[2215]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.177' (uid=0 pid=4708 comm="sudo tee /sys/bus/pci/devices/0000:0b:00.0/remove " label="unconfined")
Okt 31 18:19:34 machine dbus-daemon[2215]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:19:34 machine sudo[4708]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:19:34 machine audit[4708]: USER_ACCT pid=4708 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine audit[4708]: CRED_REFR pid=4708 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine sudo[4708]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/devices/0000:0b:00.0/remove
Okt 31 18:19:34 machine sudo[4708]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 18:19:34 machine audit[4708]: USER_START pid=4708 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine sudo[4708]: pam_unix(sudo:session): session closed for user root
Okt 31 18:19:34 machine audit[4708]: USER_END pid=4708 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine audit[4708]: CRED_DISP pid=4708 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:34 machine kernel: vfio-pci 0000:0b:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
Okt 31 18:19:34 machine kernel: pci 0000:0b:00.0: Removing from iommu group 25
Okt 31 18:19:37 machine gnome-shell[3326]: Ignoring excess values in shadow definition
Okt 31 18:19:51 machine dbus-daemon[2215]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.178' (uid=0 pid=4723 comm="sudo tee /sys/bus/pci/drivers/vfio-pci/remove_id " label="unconfined")
Okt 31 18:19:51 machine dbus-daemon[2215]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:19:51 machine sudo[4723]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:19:51 machine audit[4723]: USER_ACCT pid=4723 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:51 machine audit[4723]: CRED_REFR pid=4723 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:51 machine sudo[4723]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/drivers/vfio-pci/remove_id
Okt 31 18:19:51 machine audit[4723]: USER_START pid=4723 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:51 machine sudo[4723]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 18:19:51 machine sudo[4723]: pam_unix(sudo:session): session closed for user root
Okt 31 18:19:51 machine audit[4723]: USER_END pid=4723 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:51 machine audit[4723]: CRED_DISP pid=4723 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:19:58 machine systemd[1]: fprintd.service: Succeeded.
Okt 31 18:19:58 machine audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Okt 31 18:19:59 machine audit[1840]: NETFILTER_CFG table=filter family=7 entries=0 op=xt_unregister pid=1840 subj==unconfined comm="kworker/u64:18"
Okt 31 18:20:07 machine dbus-daemon[2215]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.179' (uid=0 pid=4730 comm="sudo tee /sys/bus/pci/drivers/amdgpu/new_id " label="unconfined")
Okt 31 18:20:07 machine dbus-daemon[2215]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:20:07 machine sudo[4730]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:20:07 machine audit[4730]: USER_ACCT pid=4730 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:07 machine audit[4730]: CRED_REFR pid=4730 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:07 machine sudo[4730]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/drivers/amdgpu/new_id
Okt 31 18:20:07 machine sudo[4730]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 18:20:07 machine audit[4730]: USER_START pid=4730 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:07 machine sudo[4730]: pam_unix(sudo:session): session closed for user root
Okt 31 18:20:07 machine audit[4730]: USER_END pid=4730 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:07 machine audit[4730]: CRED_DISP pid=4730 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:14 machine dbus-daemon[2215]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.185' (uid=0 pid=4737 comm="sudo tee /sys/bus/pci/rescan " label="unconfined")
Okt 31 18:20:14 machine dbus-daemon[2215]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:20:14 machine sudo[4737]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Okt 31 18:20:14 machine audit[4737]: USER_ACCT pid=4737 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="user" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:14 machine audit[4737]: CRED_REFR pid=4737 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:14 machine sudo[4737]:    user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/tee /sys/bus/pci/rescan
Okt 31 18:20:14 machine sudo[4737]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Okt 31 18:20:14 machine audit[4737]: USER_START pid=4737 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: [1002:731f] type 00 class 0x030000
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: reg 0x10: [mem 0xb0000000-0xbfffffff 64bit pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: reg 0x18: [mem 0xc0000000-0xc01fffff 64bit pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: reg 0x20: [io  0xd000-0xd0ff]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: reg 0x24: [mem 0xfcc00000-0xfcc7ffff]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: reg 0x30: [mem 0xfcc80000-0xfcc9ffff pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: PME# supported from D1 D2 D3hot D3cold
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: 126.024 Gb/s available PCIe bandwidth, limited by 16.0 GT/s PCIe x8 link at 0000:00:03.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: Adding to iommu group 25
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: BAR 0: assigned [mem 0xb0000000-0xbfffffff 64bit pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: BAR 2: assigned [mem 0xc0000000-0xc01fffff 64bit pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: BAR 5: assigned [mem 0xfcc00000-0xfcc7ffff]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: BAR 6: assigned [mem 0xfcc80000-0xfcc9ffff pref]
Okt 31 18:20:14 machine kernel: pci 0000:0b:00.0: BAR 4: assigned [io  0xd000-0xd0ff]
Okt 31 18:20:14 machine kernel: amdgpu 0000:0b:00.0: enabling device (0400 -> 0403)
Okt 31 18:20:14 machine kernel: [drm] initializing kernel modesetting (NAVI10 0x1002:0x731F 0x1002:0x0B36 0xC1).
Okt 31 18:20:14 machine kernel: amdgpu 0000:0b:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
Okt 31 18:20:14 machine kernel: [drm] register mmio base: 0xFCC00000
Okt 31 18:20:14 machine kernel: [drm] register mmio size: 524288
Okt 31 18:20:14 machine kernel: [drm:amdgpu_discovery_reg_base_init [amdgpu]] *ERROR* invalid ip discovery binary signature
Okt 31 18:20:14 machine kernel: [drm:amdgpu_discovery_reg_base_init [amdgpu]] *ERROR* amdgpu_discovery_init failed
Okt 31 18:20:14 machine kernel: [drm] failed to init reg base from ip discovery table, fallback to legacy init method
Okt 31 18:20:14 machine kernel: [drm] add ip block number 0 <nv_common>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 1 <gmc_v10_0>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 2 <navi10_ih>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 3 <psp>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 4 <smu>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 5 <gfx_v10_0>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 6 <sdma_v5_0>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 7 <vcn_v2_0>
Okt 31 18:20:14 machine kernel: [drm] add ip block number 8 <jpeg_v2_0>
Okt 31 18:20:14 machine kernel: amdgpu: ATOM BIOS: 113-D1993701-XT
Okt 31 18:20:14 machine kernel: [drm] VCN decode is enabled in VM mode
Okt 31 18:20:14 machine kernel: [drm] VCN encode is enabled in VM mode
Okt 31 18:20:14 machine kernel: [drm] JPEG decode is enabled in VM mode
Okt 31 18:20:14 machine kernel: [drm] GPU posting now...
Okt 31 18:20:19 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:86:dd SRC=2a02:8109:a1c0:09cc:e228:6dff:fe41:1229 DST=2a02:8109:a1c0:09cc:a059:83ce:63fa:9b79 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=52728 DPT=80 WINDOW=14400 RES=0x00 SYN URGP=0
Okt 31 18:20:22 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:86:dd SRC=2a02:8109:a1c0:09cc:e228:6dff:fe41:1229 DST=2a02:8109:a1c0:09cc:a059:83ce:63fa:9b79 LEN=80 TC=0 HOPLIMIT=64 FLOWLBL=0 PROTO=TCP SPT=52728 DPT=80 WINDOW=14400 RES=0x00 SYN URGP=0
Okt 31 18:20:28 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=192.168.178.25 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=245 DF PROTO=TCP SPT=38293 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Okt 31 18:20:31 machine kernel: [UFW BLOCK] IN=enp4s0 OUT= MAC=b4:2e:99:0e:e3:22:e0:28:6d:41:12:29:08:00 SRC=192.168.178.1 DST=192.168.178.25 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=246 DF PROTO=TCP SPT=38293 DPT=80 WINDOW=14600 RES=0x00 SYN URGP=0
Okt 31 18:20:34 machine sudo[4737]: pam_unix(sudo:session): session closed for user root
Okt 31 18:20:34 machine audit[4737]: USER_END pid=4737 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:34 machine audit[4737]: CRED_DISP pid=4737 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Okt 31 18:20:34 machine kernel: [drm:atom_op_jump [amdgpu]] *ERROR* atombios stuck in loop for more than 20secs aborting
Okt 31 18:20:34 machine kernel: [drm:amdgpu_atom_execute_table_locked [amdgpu]] *ERROR* atombios stuck executing 9386 (len 110, WS 12, PS 8) @ 0x93EB
Okt 31 18:20:34 machine kernel: [drm:amdgpu_atom_execute_table_locked [amdgpu]] *ERROR* atombios stuck executing 9314 (len 37, WS 0, PS 8) @ 0x932D
Okt 31 18:20:34 machine kernel: amdgpu 0000:0b:00.0: amdgpu: gpu post error!
Okt 31 18:20:34 machine kernel: amdgpu 0000:0b:00.0: amdgpu: Fatal error during GPU init
Okt 31 18:20:34 machine kernel: [drm] amdgpu: finishing device.
Okt 31 18:20:34 machine kernel: amdgpu: probe of 0000:0b:00.0 failed with error -22
Ah, it looks like it tripped amdgpu up because you booted the VM while the gpu was still attached to that driver. When you shutdown the VM, amdgpu picked up the device again and it looks like it got stuck.
