Well then that is understandable. Still weird why it did reset that one time and not the other times. If you need me to run more test let me know, I might find a few free minutes to do so!
BTW: gnifs patch did work for my card, I do not know if this is in any way relevant to you.
Thanks for you contribution and this works perfectly on my ASUS RX 5700 XT! However I find that the GPU is no longer turned off after the VM was shutdown as it had before. How can I solve this issue? Thanks.
Good idea, making a kernel module from the patch. Comes a bit to late, I spent many hours today, to build a custom Fedora 33 kernel with the reset bug v2 applied (but at least I know now, how to build a custom kernel). It works very nice, I can start my vm with a radeon rx 5500 xt as often as I want, and always get video. But I still have a problem, thats, why I am posting here. After starting the vm a second time, my hdmi audio is gone (code 10 in a windows vm). Is there still some code missing for the audio part, or do I simply have to find out the device id of the audio part, and add it to the list of Navi devices ?
