Have you had any problems with your system crashing while idle? I have a similar build as yours:
Ryzen 3 1200
Asus Prime X370 Pro
2 x 16GB Crucial ECC DDR4-2400
Mellanox MCX311A SFP+ 10Gbe NIC
Corsair CX450M/EVGA G3 550 (crashes with both)
WD 512GB m.2 PCIe/ADATA 128GB ASX6000 boot drive (crashes with both)
3 x 6TB WD Black RAIDZ1
Ubuntu 16.04
However, the longest time I’ve gone without the system crashing is a little over a week. This system is mostly idle.
Also touching the topic of idle time: have you measured the power consumption during standby, idle and use?
I was planning to build a NAS soon, but I somewhat care about any kind of resource efficiency, so that would be interesting to know.
Do you think it would be possible to have some kind of WakeOnLan setup in which the machine is mostly in standby and only waking up on demand / going to sleep after ~5m of idle time?
I think I’ll have to try the WOL setup and probably will have to send the magic package manually via script/app if I want to use it each time. Wouldn’t hurt to much in my 2 people household though
Had to look that up, you are talking about compression, right?
OK, gonna take a look but I want to be able to edit video from that box so latency is a thing and I was thinking that any kind of compression is probably gonna hurt that. Am I wrong on that one?
Compression speed would depend on the processor, and yours should be fine
It would be easy to test with two datasets, one compressed, the other uncompressed.
Though video doesn’t typically compress all that well- the original encoding probably compressed it as much as it can be
You might also try tweaking record size?
You could just blow away the one that performs less well after
Yeah, like you said, compressing video is not gonna do much.
And I still think that any kind of decompression on read will introduce latency. Just by nature.
The goal is to have a reliable, fast and big storage box. I would think that if I introduce compression, I am compromising the low latency benefit of SSDs for a tiny bit more storage space. That sounds like a bad deal to me.
