NAS Review Notes: Minisforum N5 MAX (AMD Strix Halo)
Test date: 2026-05-27
Reviewer: Wendell’s infrastructure team
Host OS: Proxmox VE 9.1.1 (pve-manager/9.1.1) on Debian 13 “Trixie”
Kernel: 6.17.2-1-pve
Hardware: Minisforum N5 MAX with AMD RYZEN AI MAX+ 395 w/ Radeon 8060S
1. Executive Summary
The Minisforum N5 MAX is a compact desktop-class NAS/home-server platform built around AMD’s Strix Halo APU. It combines a 16-core/32-thread Zen 5 CPU with a Radeon 8060S integrated GPU (40 CUs) sharing 64 GB of LPDDR5X memory, plus a hybrid storage architecture supporting 5x SATA HDDs and up to 5x NVMe drives. This review covers the system as configured for a homelab AI inference server with Proxmox VE.
Bottom line: The N5 MAX is an unusual but compelling NAS platform. The Strix Halo APU gives it GPU compute capabilities no other NAS on the market can touch, making it uniquely suited for hybrid storage + AI workloads. However, the unified memory architecture (60 GB shared between CPU and GPU) requires careful partitioning, and the Realtek NICs are a downgrade from the Intel x550 many NAS enthusiasts prefer.
Also, checkout the Proxmox setup guide to host VMs, including an AI-capable LXC that runs docker.
2. Hardware Specifications (Verified)
Platform
Component Specification Verified
Motherboard Minisforum N5 MAX (proprietary) :white_check_mark:
APU AMD RYZEN AI MAX+ 395 w/ Radeon 8060S :white_check_mark:
CPU Cores/Threads 16 cores / 32 threads :white_check_mark:
CPU Boost Clock Up to 5.19 GHz (single-core) :white_check_mark:
CPU Base Clock 625 MHz (2.0 GHz cpufreq floor) :white_check_mark:
Memory 64 GB LPDDR5X-8534 (soldered, unified CPU/GPU) :white_check_mark: ~60.5 GB usable
GPU Radeon 8060S, 40 Compute Units, PCI ID 1002:1586 :white_check_mark:
GPU Architecture gfx1151 (RDNA 3.5) :white_check_mark:
NPU AMD XDNA 2, PCI 91:00.1 :white_check_mark:
Storage (as tested)
Device Model Capacity Interface Type
sda Seagate Exos X16 ST14000NM001G 14 TB SATA 6 Gb/s 7200 RPM HDD
sdb Seagate Exos X16 ST14000NM001G 14 TB SATA 6 Gb/s 7200 RPM HDD
sdc Seagate Exos X16 ST14000NM001G 14 TB SATA 6 Gb/s 7200 RPM HDD
sdd Seagate Exos X16 ST14000NM001G 14 TB SATA 6 Gb/s 7200 RPM HDD
sde Seagate Exos X16 ST14000NM001G 14 TB SATA 6 Gb/s 7200 RPM HDD
nvme1n1 Toshiba KXG50PNV2T04 (XG5) 2 TB NVMe x4 OS + LVM
nvme0n1 AirDisk 128GB SSD 128 GB NVMe (MAXIO MAP1202) Spare
nvme2n1 Intel Optane P1600X 118 GB NVMe ZFS member
nvme3n1 Intel Optane P1600X 118 GB NVMe ZFS member
Total raw storage: ~70 TB HDD + ~2.3 TB NVMe
Network
Interface Controller Speed Status
nic0 (enp49s0) Realtek RTL8127 (10ec:8127) 1 GbE (link up) Active (vmbr0 bridge)
nic1 (enp50s0) Realtek RTL8127 (10ec:8127) 1 GbE Down (no cable)
vmbr0 Bridge over nic0 10 Gb/s reported by ethtool Active
Thunderbolt 5 Intel JHL9580 Barlow Ridge Up to 80 Gb/s Present (not tested)
Note on networking: The N5 MAX is advertised with dual 10GbE. The Realtek RTL8127 controllers are 2.5 GbE-capable chips. The vmbr0 bridge reports 10 Gb/s which may reflect the system’s PCIe link rate rather than the actual PHY speed. Further testing with iperf3 is recommended.
USB
Bus Speed Controller
USB 2.0 480 Mbps AMD xHCI
USB 3.2 Gen2x2 20 Gbps AMD xHCI
USB4 v2 (via TB5) Up to 80 Gbps Intel JHL9580
PCIe Topology
00:00.0 Host bridge: AMD Strix/Strix Halo Root Complex
00:01.1 PCIe USB4 Bridge
00:02.1-6 GPP Bridges (x4/x8/x16 slots)
00:08.1-3 Internal GPP Bridges
31:00.0 Realtek RTL8127 (nic0)
32:00.0 Realtek RTL8127 (nic1)
33:00.0 MAXIO MAP1202 NVMe (AirDisk 128GB)
34:00.0 Intel Optane P1600X (nvme2n1, 118GB)
35:00.0 Intel Optane P1600X (nvme3n1, 118GB)
36:00.0 Toshiba XG5 NVMe (nvme1n1, 2TB)
37:00.0 JMicron JMB58x AHCI (5x SATA)
38:00.0 Intel JHL9580 Thunderbolt 5
90:00.0 AMD Strix Halo Radeon 8060S
90:00.4 AMD USB 3.1 xHCI
92:00.0 AMD USB 3.1 xHCI
92:00.5 AMD USB4 Host Router
3. Software Stack
Host OS
Component Version
Proxmox VE pve-manager/9.1.1
Kernel 6.17.2-1-pve
Base OS Debian 13 “Trixie”
GPU Driver amdgpu (kernel module)
ROCm Userspace Not installed on host (containerized)
Container Runtime Docker 29.5.1 (inside LXC)
Virtualization
Resource Configuration
LXC Containers 1 (CT 100: strix-ai)
VMs 0
Container OS Ubuntu 24.04 LTS
Container RAM 32 GB
Container CPU 8 cores
GPU Passthrough /dev/dri/* + /dev/kfd bind mounts
AI Inference Stack
Component Details
Primary Inference Lemonade Server (Package lemonade-server · GitHub)
Benchmark Engine vLLM (rocm/vllm:latest)
Best Performing Model Qwen3-30B-A3B-Q8_0 GGUF (MoE, 3B active)
Model Storage NFS mount from Synology NAS (34 TB pool)
4. GPU Compute Performance
Benchmark Results
All benchmarks run on Strix Halo Radeon 8060S (40 CUs, gfx1151) via ROCm stack.
vLLM Benchmarks (HuggingFace format models)
Model Dtype Throughput VRAM Notes
Llama-3.2-1B float32 15.45 tok/s 0.18 GiB Smoketest
Llama-3.2-3B float32 6.10 tok/s 13.6 GiB Comfortable fit
Llama-3.1-8B-Instruct float16 3.86 tok/s 15.0 GiB Needs fp16 to fit
Lemonade Server Benchmarks (llama.cpp backend, GGUF models)
Model Quant Prompt Processing Generation VRAM
Qwen3-30B-A3B Q8_0 ~175-208 tok/s ~62 tok/s ~31 GiB
Key Findings
  • MoE efficiency is dramatic: The Qwen3-30B-A3B (3B active params) achieves 62 tok/s vs 3.86 tok/s for a dense 8B model - a 16x throughput improvement.
  • GPU memory is the hard constraint: At 30 GiB GPU-visible (default UMC partition), models over ~30 GiB won’t load. The Qwen3.6-35B-A3B-FP8 at 35 GiB requires UMC repartitioning.
  • ROCm compatibility requires workarounds: The HSA_OVERRIDE_GFX_VERSION=11.0.0 env var is needed to map gfx1151 to gfx1100 kernel code paths.
  • float32 is required for vLLM: bfloat16 causes GPU hangs on this kernel/driver combo.
5. Unified Memory Architecture (UMC Partitioning)
The Strix Halo’s defining feature is its unified memory: 60 GB of LPDDR5X shared between CPU and GPU. The default BIOS partition splits this roughly 50/50.
Default Allocation
Domain Memory Accessible By
CPU (system RAM) ~30 GiB CPU only
GPU (dedicated VRAM) 2 GiB GPU only
GPU (GTT/borrowed) ~28 GiB GPU only
Total GPU-visible ~30 GiB GPU only
Configurable Allocation
The UMC partition can be adjusted via:
  1. BIOS settings - Look for “UMC Partition” or “Memory Partition” options
  2. Kernel parameters - amdgpu.gttsize, ttm.pages_limit, amd_iommu=off
Scenario CPU GPU Use Case
Default (50/50) ~30 GiB ~30 GiB Balanced home server
AI Focused ~8 GiB ~52 GiB Large LLMs (35B+)
AI + Frigate NVR ~16 GiB ~44 GiB Hybrid workloads
Minimal GPU ~48 GiB ~12 GiB CPU-heavy NAS
6. Thermal and Power
Note: Full thermal and power testing requires sustained load testing. Preliminary observations:
  • The N5 MAX uses active cooling (fan). At idle, the system is quiet.
  • The Strix Halo APU has a configurable TDP. The N5 MAX implementation appears to allow sustained boost.
  • The 5x Exos X16 HDDs are enterprise-grade 7200 RPM drives that generate significant heat and noise in operation, however thermals and noise were well-managed in-situ on this platform.
  • The Intel Optane P1600X drives run cool (medium power, low heat).
7. Hardware Compatibility Notes
What Works
  • Proxmox VE 9.1.1: Full compatibility. All devices detected.
  • amdgpu kernel driver: Loads and initializes correctly. 40 CUs detected.
  • ROCm/KFD: /dev/kfd present, KFD topology shows 80 SIMDs, 40 CUs.
  • NVMe: All 4 NVMe slots detected (Toshiba XG5, MAXIO, 2x Intel Optane).
  • SATA: JMicron JMB58x AHCI controller works. 5x Exos X16 detected.
  • USB: All USB controllers functional. USB4 v2 via Thunderbolt 5 present.
  • Thunderbolt 5: Intel JHL9580 Barlow Ridge detected. Only Basic eGPU testing performed.
What You Should Know
  • Realtek NICs: The RTL8127 controllers work but are not Intel x550/x710 level of quality. Performance testing with iperf3 is recommended.
  • VAAPI video decode: The radeonsi_drv_video.so driver exists but va_openDriver() fails. VCN firmware may need an update.
  • Compute partitioning sysfs: The amdgpu.user_partt_mode parameter exists but the runtime compute_partition sysfs file is not exposed on this kernel.
  • LPDDR5X soldered: Memory is not upgradable. 64 GB is the only option.
8. Comparison to Alternatives
Feature Minisforum N5 MAX Typical DIY NAS Synology DS1823xs+
CPU 16C/32T Zen 5 + GPU Varies (e.g., Intel i5-13500) Intel Xeon D-1622
GPU Radeon 8060S (40 CUs) None or basic iGPU None
RAM 64 GB LPDDR5X (soldered) Upgradable 32 GB ECC
Max HDDs 5x SATA + 5x NVMe Varies 8x SATA
Network 2x 10GbE + TB5 Varies 2x 10GbE
AI Inference Excellent (GPU) Poor (CPU only) None
Power ~120W-200W (est.) Varies ~80W
Price $$$$$ $$$ $$$$+
9. Recommendations
Ideal Use Cases
  • AI inference server with NAS capabilities
  • Homelab cluster node for GPU-accelerated workloads
  • Hybrid storage + compute appliance
Less Ideal For
  • Pure file server - overkill, better options at lower price
  • High-density storage - only 5x 3.5" bays
  • Production NAS - Realtek NICs and soldered RAM are concerns
Configuration Tips
  1. Repartition UMC for your workload (see Section 5)
  2. Use the 2 TB NVMe for OS + LVM, leave HDDs for bulk storage
  3. Consider ZFS on the 5x Exos drives with the Optanes as SLOG/cache
  4. Containerize GPU workloads - don’t install ROCm on the Proxmox host
  5. The Thunderbolt 5 port is ideal for direct-attach backup or high-speed peripheral connectivity
10. Raw Test Data
CPU Info
16 cores / 32 threads, 1 socket, 1 NUMA node
CPU max: 5187 MHz, CPU min: 625 MHz
# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Root Complex (rev 02)
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo IOMMU (rev 02)
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo PCIe USB4 Bridge (rev 02)
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge (rev 02)
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge (rev 02)
00:02.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge
00:02.6 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge (rev 02)
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge
00:03.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo GPP Bridge (rev 02)
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Internal GPP Bridge to Bus [C:A]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Internal GPP Bridge to Bus [C:A]
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo Internal GPP Bridge to Bus [C:A]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Strix Halo Data Fabric; Function 7
31:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. Device 8127 (rev 05)
32:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. Device 8127 (rev 05)
33:00.0 Non-Volatile memory controller: MAXIO Technology (Hangzhou) Ltd. NVMe SSD Controller MAP1202 (DRAM-less) (rev 01)
34:00.0 Non-Volatile memory controller: Intel Corporation Optane NVME SSD P1600X Series
35:00.0 Non-Volatile memory controller: Intel Corporation Optane NVME SSD P1600X Series
36:00.0 Non-Volatile memory controller: Toshiba Corporation XG5 NVMe SSD Controller
37:00.0 SATA controller: JMicron Technology Corp. JMB58x AHCI SATA controller
38:00.0 PCI bridge: Intel Corporation JHL9580 Thunderbolt 5 80/120G Bridge [Barlow Ridge Host 80G 2023] (rev 84)
39:00.0 PCI bridge: Intel Corporation JHL9580 Thunderbolt 5 80/120G Bridge [Barlow Ridge Host 80G 2023] (rev 84)
39:01.0 PCI bridge: Intel Corporation JHL9580 Thunderbolt 5 80/120G Bridge [Barlow Ridge Host 80G 2023] (rev 84)
39:02.0 PCI bridge: Intel Corporation JHL9580 Thunderbolt 5 80/120G Bridge [Barlow Ridge Host 80G 2023] (rev 84)
39:03.0 PCI bridge: Intel Corporation JHL9580 Thunderbolt 5 80/120G Bridge [Barlow Ridge Host 80G 2023] (rev 84)
3a:00.0 USB controller: Intel Corporation JHL9580 Thunderbolt 5 80/120G NHI [Barlow Ridge Host 80G 2023] (rev 84)
65:00.0 USB controller: Intel Corporation JHL9580 Thunderbolt 5 80/120G USB Controller [Barlow Ridge Host 80G 2023]
90:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Strix Halo [Radeon Graphics / Radeon 8050S Graphics / Radeon 8060S Graphics] (rev c1)
90:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller [Rembrandt/Strix]
90:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Strix/Krackan/Strix Halo CCP/ASP
90:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Strix Halo USB 3.1 xHCI
90:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
90:00.7 Signal processing controller: Advanced Micro Devices, Inc. [AMD] Sensor Fusion Hub
91:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Strix/Strix Halo PCIe Dummy Function
91:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] Strix/Krackan/Strix Halo Neural Processing Unit (rev 11)
92:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Strix Halo USB 3.1 xHCI
92:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Strix Halo USB 3.1 xHCI
92:00.5 USB controller: Advanced Micro Devices, Inc. [AMD] Strix Halo USB4 Host Router
TODO
Memory Info
MemTotal: 63407216 kB (~60.5 GB)
LPDDR5X-8534, Micron Technology
2 channels (A and B) populated
TODO
Performance
The performance is here at the end of the how-to for the type of performance you can expect with various quants of Qwen3.6 (both 27b dense and 35b MoE):
This product will probably make a few hundred people happy.
Minisforums showed of a Strix Halo ITX board at CES 2026. That product would probably make a lot of people very happy with having a bigger say in how the I/O is used for a home server.
Had a quick lookup for an EU price. :money_with_wings:
I’ll pass :roll_eyes:
Interesting little box but I’m more interested in who it’s meant for exactly or where along my journey would I have been looking for the N5 Max. I actually almost skipped the video piece for this but I’m glad I didn’t. A suspicious NAS, wearing a turban and sporting a handlebar mustache, might be curious if I saw it in the dinning car of the Orient Express… but it wasn’t what I was looking for tonight.
The wide ranging philosophical musings the NAS inspired spoke directly to the kinds of things I’ve been working on this year. Hosting local Ai, self hosting services, taking back control of one’s data, adversity as a catalyst and motivation to take up tools and make things useful to ourselves and possibly others, experiment with things/test ideas, use information to empower ourselves. :star_struck: or at least I think I heard endorsements for a lot of my plans in there…:face_with_raised_eyebrow: In any case I’m reinvigorated to continue my home lab projects and keep the momentum going by building upon them–after a nap.
The N5 Max at €2719 compared to their own 64 GB MS-01 MAX at €2679 the price is good IMO if one likes the I/O. But one could get the GMKtec-EVO-X2 for €1899. All being 64GB models. None of them really make sense compared to the at this point hypothetical AI Max+ 395 ITX/ATX board. I can bring my own case and standardised PSU.
This looks like a great NAS wendell. I wanted to ask you opinion about using it in a car for sensor data collection instead of an all-SSD Flashstor? Only 5 SSDs, but I was wondering if we could write something clever to constantly move data to spinning disks while the SSDs are filling? There is also the question of how well spinning disks will cope with being on a bumpy ride? Any [expert] thoughts?
I see the point you’re trying to make here. But consumers are being mislead: it’s not a NAS (network attached storage) device.
It’s an all-out local AI server :roll_eyes:
And b/c it has AI in the product name, you pay a significant premium for the privilege :face_with_symbols_on_mouth:
Wow, more $ to spend.
Spinning HDDs in a car? Unlikely to end well. Certainly no chance with 3.5” desktop/server class HDDs - they were never designed to be moved in operation.
Even 2.5” laptop class HDDs are unlikely to cope well with things like potholes or speed bumps.
Then there’s the mechanical design of the N5 as well. Again, not designed for this, so expect early failure due to mechanical stress. It’s a bit pricey to take the risk, at least on my budget, but perhaps you are wealthy enough for that risk level.
N5 MAX owner here (the review thread’s setup guide is what sold me on Proxmox on this box). I’m running Proxmox VE 9.x with a ZFS raidz2 array and have been fighting something I want to check against other owners’ machines before I conclude it’s platform-specific.
Symptom I have been dealing with: HDD drives periodically drop off the bus mid-operation and ZFS logs faults/resilvers. dmesg shows the mainline JMB585 quirk active (ahci ...: controller can't do 64bit DMA, forcing 32bit), so this is current best-available software — the kernel side is already doing everything upstream knows to do for this chip.
The drive details themselves disagree with a “bad drives” label. Two of my WD140EFGX 14TBs came out of a prior NAS with 2+ years of clean service and zero SMART media errors, and both were dead within weeks inside the N5 MAX.
Across the four drives I put in the n5: 21,242 total SATA PhyRdy→PhyNRdy link-drop transitions recorded in the drives’ own GP log 0x11 — with zero drive-side CRC/ICRC interface errors on every drive.
One 4.5-hour window in my kernel journal contains 36,029 port retrain events across the JMB585’s ports.
On a controlled pair: two brand-new replacement drives sat in the chassis running a continuous verification pass for ~151 hours and each accumulated ~417,000 link-drop transitions in that window — roughly 2,760 forced link collapses per hour.
Media error counters stayed at zero throughout the collapses — this is a link/servo interaction problem, not media wear, and the pool absorbing faults on parity doesn’t make the underlying event any less violent for the drives’ heads.
What I’d love from other N5 MAX (or JMB585-based) owners — two read-only commands, please run them and paste output:
# drive-resident link counters (substitute your disk; on Proxmox use -d sat if needed)
smartctl -l sataphy /dev/sdX
# host-side link events in the journal
dmesg | grep -iE 'ata[0-9]+.*(SContext|SError|hardreset|exception Emask|down)'
Still running mine:
root@pvestrix:~# smartctl -l sataphy /dev/sda
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.17.13-18-pve] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
root@pvestrix:~# smartctl -l sataphy /dev/sdb
root@pvestrix:~# smartctl -l sataphy /dev/sdc
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
root@pvestrix:~# smartctl -l sataphy /dev/sdd
root@pvestrix:~# smartctl -l sataphy /dev/sde
root@pvestrix:~# dmesg | grep -iE 'ata[0-9]+.*(SContext|SError|hardreset|exception Emask|down)'
No output. This has been running 24/7 since the video. I even used it to help someone recover 40tb of data from another nas so it has gotten quite a workout.
my uname -a is currently Linux pvestrix 6.17.13-18-pve #1 SMP PREEMPT_DYNAMIC PMX 6.17.13-18 (2026-07-15T10:30Z) x86_64 GNU/Linux
I am running amd_iommu=off with aspm disabled (pcie power management). And the dma patch. Is it possible the kernel you’re running had a regression?
The symptoms do seem vaguely jmicron related… maybe a bug in the quirk? given I’m also on probably an older kernel at this point. This one should be in the repo though.
Thanks for jumping in. Just pulled the deltas off the my n5:
ASPM: already out. lspci -vvv -s 37:00.0 shows the JMB585 link at LnkCtl: ASPM Disabled — so the PCIe power-management difference between your box and mine doesn’t apply, mine is like yours here.
DMA quirk: active and was from day one — ahci 0000:36:00.0: controller can't do 64bit DMA, forcing 32bit in every boot’s dmesg.
That leaves two real deltas between your working setup and mine:
IOMMU: I’m running with AMD-Vi on (stock Proxmox, nothing in the cmdline disabling it). You’re at amd_iommu=off. I’m waiting for minisforum to respond to support request about this issue before I let the device damage any more of my HDDs (I pulled all the HDDs out for now).
Kernel: I’m on 7.0.14-14-pve (pve-manager 9.2.11) — so not older than yours.
Appreciate you taking a look on the device you have.
I said I’d pulled the drives and was waiting on Minisforum before letting the box near another HDD. They’ve now answered in writing, and I think the exchange is worth laying out for anyone else on the fence about this machine. The reponse turns my open question into a concrete one you’re uniquely positioned to settle,
The correspondence, briefly:
I opened a support ticket describing the link-drop damage (raw numbers are in my earlier posts on this thread).
Their R&D center replied. Verbatim:
"This issue is an AMD issue, and it is not related to the SATA controller. It is the previously mentioned SOP of ‘v2 (amd_iommu=pgtbl_v2)’ or ‘iommu=pt’.
Using the official system will not cause this problem.
Upgrading to the latest official kernel will also not cause this problem."
Their cited explanation is this upstream patch:
— note it’s posted to the linux-ide (SATA maintainers’) list, its “Closes:” report names the JMB585’s broken 64-bit DMA as an ingredient, and its text puts the defective root-port configuration in “the BIOS on these systems,” which on this box is MiniForum’s own firmware (AMI 1.04).
Their support desk separately declined any remedy, stating the issue “does not fall under a product quality problem.” Same company, same day. I’ll let those two emails argue with each other.
What matters for this thread is the technical claim inside their R&D reply: that the failure mode only exists in the IOMMU-translated default configuration — which is exactly my configuration and not yours — and that `iommu=pt` or `amd_iommu=pgtbl_v2` prevents it. Between your box and mine the difference is essentially one boot parameter: you run `amd_iommu=off`; I ran stock Proxmox, AMD-Vi enabled, default domain Translated, nothing IOMMU-related on the cmdline.
So the direct question: would you be willing to validate my issue by making that one change?
Removing `amd_iommu=off` puts your system in the configuration I measured — and you should expect that configuration to cause the harm my dataset documents: forced SATA link drops at roughly 2,700 transitions per hour per drive under sustained load, drives dropped mid-operation with failed resets, port-disable events with kernel I/O errors.
If their email is right, your Phy counters stay boring. If my drives’ experience repeats on your box, that is a defect demonstrated in the cleanest possible way — by the reviewer, on their own hardware.
I’d caution:
Not on your working array. A sacrificial disk group only — cheap used drives, anything whose loss you’d shrug off. If the config does what the theory says, that disk is the price of the experiment and nothing else should be connected.
Measure with the same two read-only commands from my first post, before and after the run: `smartctl -l sataphy` on the test disk + the dmesg ATA grep. Even 30–60 minutes of sequential load is enough — in a failing config, counters start climbing fast; healthy stays in single digits.
The paired test worth doing while you’re there: add `iommu=pt` with the sacrificial disk and run the same measurement. That’s a direct test of their prevention claim, and a clean result there would be just as useful to everyone watching this box as a dirty one.
If the thought of “not on my machine, not my problem” is happening — fair, and your existing clean-counter post is still useful data on this thread. But if you are curious, let me know what the numbers say.
This is a lot of words to ask if I can reproduce the bug, and the answer is yes, but your verbose thing is a combination of things that don’t quite paint the full picture.
There is some unusual combination of kernel version, patch, and config because the patch with default iommu setup I understood to resolve the dma transfer issue by just not doing that type of dma transfer with this device in any dma scenario?
I’d have to dig into it for deeper specifics but either the workaround patch doesn’t cover every situation or the kernel you’re on has an incomplete patch or botched backport patch…
I absolutely can reproduce corruption with this controller, but it is a known/fixable software thing. I’m saying your situation may have an incompletely applied fix, or the backported fix assumes a different default iommu posture (assuming its backported)?
ps iommu=pt is generally desirable if you need iommu, imho, so the assumption that iommu=pt is perhaps not an unreasonable one.
Yes, I have narrowed it to that specific setting that I was unaware needed to be set in proxmox since this is my first dive into using proxmox. I am currently testing that setting to “off” as you have configured but will also set to “pt” because the latest flavors of the week for these strix boxes is using the NPU to help prefill.
