Tight fit! Looking good!
Yeah gonna have to do a plexy spacer its like 1cm to tall, or might just run no glass on the side, also might swap top fans to noctoua to not have two fan colors
Now just need to get some fluid for it, move nvme drives over, fill and leak test, and set up install
Maybe swap fans too
Filled ran power cables but need 24 pin extension so gonna wait till after my trip but just need that and should be ready for boot
Still have some things i need to update, and need to do a flush, but to busy with class this week to want to mess with it too much.
Pump is currently set to 40% power static, this might also change
Might also change these curves
So I am pretty sure my Chipset is overheating, gonna flip bottom rad fans maybe, or get a water block for it. I did have the fan profile on silent but aparently thats not good enough happend both times not after like 3-4hr gaming session. CPU didnt seem to be that hot (60s) GPU wasnt that bad either tho so I am assuming it was chipset, gonna turn on loggin on HWInfo next time I game just in case and keep and eye on the temp now as well. Seems like X570 chipset cooling in Taichi leaves a bit to be desired.
So not quite Watercooled adventure related, but I ordered some https://www.amazon.com/gp/product/B082DNHT3R/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Here is what Thaiphoon Burner had to say
Kinda funny just wanted to share
