Decided to change the bottom and remove the rez as it wouldn’t have done much and I can fill and bleed the loop pretty easily with the quick disconnect.
Now 100% hard tube
Now 100% hard tube
Just ordered a GTX 1070ti, only really game at 1440p for now and my panel is only 60hz (LG 43 4k run as 2 3840x1080 panels)
Did a leak test this morning before bed, have 1 spot i need to check the fittings on, but should be a quick fix. A few more parts should be arriving and the build should maybe be up this weekend, depends on school work.
Need to bleed the loop more and this loop design is a pita for filling and bleeding but so be it
Suffer for performance, I say!
I had to rotate my whole S340 case with the pump going to get all the air pockets out of the 280mm rad, so boy do I understand this pain.
The worst part is now I’m bound to do it again in future builds
Oh and if you could get a secondary light source and stop using the flash it’d be a lot prettier IMO.
Eh it’s just quick and dirty progress pictures I’ll take better ones when complete
Few more small things I need to put in the bottom
Still need to take some more pictures, Got the OC on the cpu to 3.9, need to still drop the volts to lowest possible but still pretty low on the power.
OC on the 1070ti is @ 1.9, but need to tweak this more as well, just did a quick OC
CPU max temp under prime95 load is like 60c and fans only ramping to 950ish RPM when running at the load.
Will be upgrading to x399m and 1950x in the near future was going to get 2nd gen TR but $600 was to good of a deal for 1950x
Take better pictures this time
Fine Ill use my old D40 DSLR instead of my shitty phone
Currently working with EK on an part they said would fit the X399m when it first came out that actually doesn’t. So far while the process is time consuming (back and forth) they seem to be taking care of me.
So wont be able to water cool the VRM unless I try to do a custom block thing. Still working on that part of the project.
Rez is still up in the air, I want to have one but will probably try my hand at making one or try and sucker a co-worker with a lazer to cut me some.
So I have a bit of a change of case coming, so its putting my project on hold. I ordered a cerberus case so that will be its new home.
So ended up with 120x30(350w) and 92x45(220w) only for rad space have 120 blowing air on vrm
Need to order new pump top but that should be it so probably 1 more week. Ram should be here tomorrow
Updated Pricing for new build so far
arts List:
Case
Cerberus Case:$250
Replacment USB 3.0 Header Cable $8
Components
CPU: TR 1950x $600 (sale after TR2xxx Launch)
Ram 4x16GB Crucial ECC 2666 (CT16G4WFD8266) $711
Motherboard: Asrock x399m $340
GPU: Zotac GTX 1070Ti $450
Storage
Samsung 970 Pro 512GB $198
Samsung 960 Evo 1TB $360 (Price I paid awhile ago)
EK M2. NVMe Heatsink Nickel x2 $30
NIC: Asus ROG 10G Expresss // (Got a year or so ago) $100.00
Fans: 3xNoctua NF-A12x15 PWM $60
1xNoctua NF-A9x14 PWM $16
PSU: SilverStone SFX 700W 80+Plat $145
CableMod Custom Cables
24Pin $42
8Pin EPS $22
8Pin PCIE$22
Radiators
HWLabs Black Ice Nemesis 120GTS $35
HWLabs Black Ice Nemesis M92GTX $35
Pump/Rez
EK-XRES 100 DDC MX - Acetal $50
EK-XTOP DDC 3.2 PWM Elite(Sleeved) $122
(Could be cheaper, but using pump I had already)
WaterBlock:
EK-Supremacy sTR4 - Nickel Plexi $90
Thermal Grizzly Hydronaut (Included in block)
Fittings
Not completeed yet
Total Cost: $3,051 + XXX
You could definatly drop the price a bit from where my build is, but some parts are older and I put the price I paid when I got them and some parts were upgraded from older builds so the cost to mod to how I wanted it was a bit more expensive then just buying it already the way it would be.
https://pcpartpicker.com/list/CNdcmq
Still working on that PCPartPicker link
Forgot to post a picture, really need to take a better one, its going to go to air once AM4 Zen2 plus comes out and moves its life over to my wife owning it
No longer water, due to Radeon 7 Gpu uprgrad coming soon
Optane drive did make it in finally like 1 year later
Ordered some things to go back to water in an upgrade build when it happens (not sure when 100%)
Mainly new case Lian Li PC-010wx and EKWB for Radeon7
New build is coming together waiting on parts tho
Case: Lian Li PC-010 WX
Mobo: Asrock x570 Taichi
CPU: R9 3900x
Ram: G.SKILL Trident Z Neo 32GB (2 x 16GB) DDR4 3600 - F4-3600C16D-32GTZNC
GPU: Radeon VII
Storage:Samsung 970 Pro 512GB // Samsung 960 Evo 1TB
Not 100% on which storage will come over from 1950x build and what will stay. As well as what all of my WC parts will be used and if I will need to order new ones to maximize cooling (MIght want to get a 280mm instead of using two of the 240s I already have) Case eneded up being used due to it being backordered pretty sure its discontinued tho so Ordered that off Ebay last night ened up saving like $80 over waiting for new
So made some decisions on storage gonna move both over minus optane (gonna leave that for wife or move to server) And get her a 970 evo 500gb for boot/os
