Next up: GPU screw mount....
update: I ended up ditching having a screw mount being an aluminum bar, I'm just going to have a screw hole in the acrylic frame with a nut to hold it in.
So I've started work on the panels and completed the final aluminum piece (fill port). Next up will completing the case frame, working on the wiring and putting it all together.
Side note: working on the fan controller circuit has been a bit annoying. Any pwm under 20k hz will produce an annoying buzz. Got an arduino to do the fan controlling.
