Index
- Front IO
- CPU Water Block
- PSU mounting bracket
- Parts Test
- Peltier Block
- Motherboard Tray
- Fan Vents
- Case skeliton
Now with LAN-Syndicate 2016 over, it's now time to build a more LAN friendly rig. MM 1.2 worked out okay, but now it's time to build something more practical. With my limited work space, building an all-acrylic case was the only option; but now I found a place I can do some metal work, so it's going to finally have a metal skeleton this time.
So ultimately I still want both the video card and the mother board being vertical (enjoy the view of both + avoid pooling water in case of leak), but to avoid wasting vertical space I'll use a riser cable to put the GPU behind the motherboard instead of on top.
For the first 6 months it's just going to be parts collection and another year to put it all together. Just as a preview; my build is going to involve 2 pumps 2 radiators (a 2 fan and a 3 fan rad.), a peltier plate and 3 water blocks. I'm going to try keeping it within the 9" x 14" x 22" luggage limitation which will be interesting to say the least.
I'll be updating the parts collection as they come in.
Yay, more parts came in: Got aluminum bars for the mother board base & case chassis, threading rivets, pcb boards fittings, temp & flow sensors, pass through plug parts, peltier, pump and fittings. TIG welding the aluminum is going to be interesting....
Unfortunately the pump threading wasn't NPT 1/4", but NPT 1/2", but that nothing some acrylic and NPT pipe tap can't fix. On a side note, who ever came up with the NPT pipe standards must have been high on something, 1/2" is more like 0.8" diameter.
