I am new to looking glass and am having some issues.
Firstly, I receive the messages:
36621117857 [I] main.c:1515 | lg_run | Host ready, reported version: B2-rc3-0-g82e0b7b6ab
36621117870 [I] main.c:1516 | lg_run | Starting session
and only see the looking glass logo in the client trying to connect again after having quit the client some time ago. Does this have to to something with the Windows session locking out or something?
Secondly I was having bad issues with the mouse cursor. It seems the speed of the mouse in the looking glass client as well as “outside” on the desktop is different e.g. when I position the cursor in the client on the left side of the screen and move it to the right, after going half the way to the right side the cursor of my “desktop” mouse already appears on the right side outside of the client window and takes the focus away from looking glass. To be able to reach an item on the opposite side of the clients window I move the mouse, the mouse leaves the window, and I need to reenter the client window area again from the opposite side.
Lastly after shutting down the VM I cannot reconnect using looking glass. I have to remove Spice and QXL and start over the second monitor again. After readding the devices I can connect using looking glass again.
I am thankful for any advice!
gnif
August 13, 2020, 1:28am
2
Host logs please.
https://looking-glass.hostfission.com/wiki/FAQ#The_mouse_doesn.27t_stay_aligned_with_the_host .
You should not be using QXL at all. Set the video type to none. Looking Glass is not compatible with virtual video devices due to the way that Windows handles the primary device and capture.
If you have further questions please start a new topic as this is not a support thread.
gnif:
Host logs please.
I will provide them but I need some hint where they are. Also do I understand correctly that in the context of Looking Glass the host is the Windows VM with the server application and not the machine hosting the VM Windows guest.
gnif
August 13, 2020, 3:42pm
4
It’s literall documented in the github Readme, the LG Wiki, and the client also informs you as to where it is…
%TEMP%\looking-glass-host.txt
Or
C:\Windows\Temp\looking-glass-host.txt
15178797 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
15180705 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
15188047 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
15189763 [I] app.c:439 | app_main | IVSHMEM Address : 0x28C0000
15191592 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
15193316 [I] app.c:441 | app_main | KVMFR Version : 2
15204014 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
15214426 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
15227561 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
15244892 [I] app.c:504 | app_main | Trying : DXGI
15394672 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
15407533 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
15418346 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
15428446 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
15438892 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
15448812 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
15458744 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
15468624 [I] dxgi.c:395 | dxgi_init | Capture Size : 2560 x 1440
15478687 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
15515200 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
15527227 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
15554923 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
15647569 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
15753766 [I] app.c:237 | captureStart | Using : DXGI
15815298 [I] app.c:245 | captureStart | Capture Size : 14 MiB (14745600)
15844373 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
15869834 [I] app.c:107 | frameThread | Frame thread started
582440384 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
583440861 [I] app.c:202 | frameThread | Frame thread stopped
583484196 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
583485019 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
583486130 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
583486889 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
583487668 [I] dxgi.c:206 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
583522604 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
583523281 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
583523799 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
583524331 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
583524860 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
583525373 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
583525903 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
583526420 [I] dxgi.c:395 | dxgi_init | Capture Size : 2560 x 1440
583526963 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
583527509 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
583528189 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
583528932 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
740897195 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
740897925 [I] app.c:237 | captureStart | Using : DXGI
740898515 [I] app.c:245 | captureStart | Capture Size : 14 MiB (14745600)
740899105 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
740900488 [I] app.c:107 | frameThread | Frame thread started
66991901 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
67119042 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
67171989 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
67204087 [I] app.c:439 | app_main | IVSHMEM Address : 0x2B00000
67237889 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
67268029 [I] app.c:441 | app_main | KVMFR Version : 2
67290771 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
67300379 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
67321209 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
67474113 [I] app.c:504 | app_main | Trying : DXGI
67647769 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
67878133 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
67907106 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
67942852 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
67982187 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
67998612 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
68013126 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
68023661 [I] dxgi.c:395 | dxgi_init | Capture Size : 2560 x 1440
68034252 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
68042699 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
68053468 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
68065286 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
68078255 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
68101714 [I] app.c:237 | captureStart | Using : DXGI
68123393 [I] app.c:245 | captureStart | Capture Size : 14 MiB (14745600)
68132633 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
68141467 [I] app.c:107 | frameThread | Frame thread started
11800143 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
12334359 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
13225662 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
13257817 [I] app.c:439 | app_main | IVSHMEM Address : 0x2A60000
13268394 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
13278277 [I] app.c:441 | app_main | KVMFR Version : 2
13313254 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
13329124 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
13341554 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
13403003 [I] app.c:504 | app_main | Trying : DXGI
13827204 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
13873415 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
13898611 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
13930911 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
13960617 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
14005495 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
14028477 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
14037739 [I] dxgi.c:395 | dxgi_init | Capture Size : 2560 x 1440
14048845 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
14058793 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
14069167 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
14084072 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
14118904 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
14168940 [I] app.c:237 | captureStart | Using : DXGI
14192866 [I] app.c:245 | captureStart | Capture Size : 14 MiB (14745600)
14218595 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
14236014 [I] app.c:107 | frameThread | Frame thread started
37270168 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
38291771 [I] app.c:202 | frameThread | Frame thread stopped
38338031 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
38353313 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
38386589 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
38401637 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
38415658 [I] dxgi.c:206 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
38448060 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
38457675 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
38466054 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
38474298 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
38483063 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
38490849 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
38499457 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
38507512 [I] dxgi.c:395 | dxgi_init | Capture Size : 2560 x 1440
38516202 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
38524274 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
38534933 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
38546179 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
80261148 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
80262074 [I] app.c:237 | captureStart | Using : DXGI
80262415 [I] app.c:245 | captureStart | Capture Size : 14 MiB (14745600)
80263950 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
80264582 [I] app.c:107 | frameThread | Frame thread started
103926480 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
104259589 [I] app.c:202 | frameThread | Frame thread stopped
104521738 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
104522054 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
104522323 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
104522587 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
104522860 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
104523124 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
104523396 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
104523664 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
104523945 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
104524223 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
104524620 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
104524998 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
104526457 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
104527215 [I] app.c:237 | captureStart | Using : DXGI
104527511 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
104527802 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
104528304 [I] app.c:107 | frameThread | Frame thread started
11678369796 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
11678646037 [I] app.c:202 | frameThread | Frame thread stopped
11678707578 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
11678708377 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
11678709053 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
11678709685 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
11678710298 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
11678711035 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
11678711661 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
11678712260 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
11678712892 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
11678713607 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
11678714377 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
11678715280 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
11678718500 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
11678725120 [I] app.c:237 | captureStart | Using : DXGI
11678725641 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
11678726213 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
11678727029 [I] app.c:107 | frameThread | Frame thread started
12555640877 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
12555703083 [I] app.c:202 | frameThread | Frame thread stopped
12555743794 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
12555744469 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
12555745041 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
12555745613 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
12555746214 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
12555746780 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
12555747482 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
12555747847 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
12555748110 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
12555748427 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
12555748806 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
12555749164 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
12555751195 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
12555752260 [I] app.c:237 | captureStart | Using : DXGI
12555752563 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
12555752845 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
12555754100 [I] app.c:107 | frameThread | Frame thread started
16257810548 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
16257810943 [I] app.c:202 | frameThread | Frame thread stopped
16257892108 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
16257892483 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
16257892793 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
16257893052 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
16257893365 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
16257893621 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
16257893936 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
16257894201 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
16257894520 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
16257894837 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
16257895177 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
16257895600 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
16257896878 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
16257899315 [I] app.c:237 | captureStart | Using : DXGI
16257899580 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
16257899859 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
16257900357 [I] app.c:107 | frameThread | Frame thread started
17514881215 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
17514914031 [I] app.c:202 | frameThread | Frame thread stopped
17514959595 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
17514959924 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
17514960191 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
17514960460 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
17514960731 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
17514960996 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
17514961322 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
17514961591 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
17514961866 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
17514962143 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
17514962496 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
17514962874 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
17514964168 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
17514965803 [I] app.c:237 | captureStart | Using : DXGI
17514966129 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
17514966418 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
17514967011 [I] app.c:107 | frameThread | Frame thread started
31454949 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
31613563 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
31727211 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
31771398 [I] app.c:439 | app_main | IVSHMEM Address : 0x2980000
31909994 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
32020484 [I] app.c:441 | app_main | KVMFR Version : 2
33681311 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
33891269 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
33971602 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
34019389 [I] app.c:504 | app_main | Trying : DXGI
34072276 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
34106980 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
34142571 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
34176333 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
34230810 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
34311820 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
34340069 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
34361005 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
34377949 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
34397575 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
34414936 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
34441525 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
34457018 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
34480049 [I] app.c:237 | captureStart | Using : DXGI
34489005 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
34499021 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
34508114 [I] app.c:107 | frameThread | Frame thread started
15068661 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
15089993 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
15115319 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
15148207 [I] app.c:439 | app_main | IVSHMEM Address : 0x2940000
15166514 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
15182609 [I] app.c:441 | app_main | KVMFR Version : 2
15210816 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
15228824 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
15294275 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
15390172 [I] app.c:504 | app_main | Trying : DXGI
15449974 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
15497130 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
15557610 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
15595495 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
15669036 [I] dxgi.c:206 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
15758047 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
15774966 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
15793065 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
15803081 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
15824356 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
15832920 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
15840768 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
15848698 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
15856779 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
15864719 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
15875528 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
15886690 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
19908915 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
19934155 [I] app.c:237 | captureStart | Using : DXGI
19944149 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
19954893 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
19965209 [I] app.c:107 | frameThread | Frame thread started
35954867 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
36820752 [I] app.c:202 | frameThread | Frame thread stopped
36844812 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
36858437 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
36888011 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
36907591 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
36924401 [I] dxgi.c:206 | dxgi_init | https:// 36992557f[I] platform.c:292 t app_init . | System timer resolution: 48.82 ns
/ 36994524 [I] / app.c:428 | app_main d | Looking olass Host (B2-rc3-0-g82e0b7b6ab)
wnloads/psexec
37000396 [E] ivshmem.c:126 | ivshmemOpen | DeviceIoControl Failed: 0x00000224 (An attempt was made to attach to a device that was already attached to another device.)
37000971 [E] app.c:433 | app_main | Failed to open the IVSHMEM device
37022700 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
37032027 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
37039941 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
37072920 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
37080976 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
37088966 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
37097518 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
37105957 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
37114626 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
37123645 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
37134863 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
37146733 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
37159495 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
37170724 [I] app.c:237 | captureStart | Using : DXGI
37178948 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
37187605 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
37208820 [I] app.c:107 | frameThread | Frame thread started
13537901 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
13589419 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
14011625 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
14021591 [I] app.c:439 | app_main | IVSHMEM Address : 0x2B60000
14046096 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
14058165 [I] app.c:441 | app_main | KVMFR Version : 2
14080264 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
14108048 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
14237130 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
14618400 [I] app.c:504 | app_main | Trying : DXGI
14698696 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
14767941 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
14820141 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
14850856 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
14868312 [I] dxgi.c:206 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
14942005 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
15002283 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
15048983 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
15116038 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
15132456 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
15161173 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
15183877 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
15275030 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
15324143 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
15379843 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
15439223 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
15516680 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
16202189 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
16278303 [I] app.c:237 | captureStart | Using : DXGI
16286167 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
16295021 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
16303486 [I] app.c:107 | frameThread | Frame thread started
18454136 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
18582697 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
18690642 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
18779240 [I] app.c:439 | app_main | IVSHMEM Address : 0x2A20000
18826423 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
18840187 [I] app.c:441 | app_main | KVMFR Version : 2
18857540 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
18869336 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
18903142 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
18929211 [I] app.c:504 | app_main | Trying : DXGI
18991990 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
19018265 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
19060194 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
19096018 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
19147032 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
19170149 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
19190358 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
19207329 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
19235387 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
19251855 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
19273075 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
19312705 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
19359667 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
19386677 [I] app.c:237 | captureStart | Using : DXGI
19398463 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
19423576 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
19435248 [I] app.c:107 | frameThread | Frame thread started
14284379 [I] platform.c:292 | app_init | System timer resolution: 48.82 ns
14342905 [I] app.c:428 | app_main | Looking Glass Host (B2-rc3-0-g82e0b7b6ab)
17157457 [I] app.c:438 | app_main | IVSHMEM Size : 32 MiB
17363046 [I] app.c:439 | app_main | IVSHMEM Address : 0x2990000
17374835 [I] app.c:440 | app_main | Max Pointer Size : 64 KiB
17876836 [I] app.c:441 | app_main | KVMFR Version : 2
17899275 [I] app.c:489 | app_main | Max Frame Size : 15 MiB
17969045 [I] app.c:504 | app_main | Trying : NVFBC (NVidia Frame Buffer Capture)
18104375 [E] wrapper.cpp:60 | NvFBCInit | Failed to load NvFBC64.dll: 0x0000007e (The specified module could not be found.)
18119717 [I] app.c:504 | app_main | Trying : DXGI
18274061 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
18507427 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
18520272 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
18530830 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
18541844 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
18577163 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
18623229 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
18705964 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
18716123 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
18726832 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
18741753 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
18923441 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
19044091 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
19068785 [I] app.c:237 | captureStart | Using : DXGI
19081791 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
19095419 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
19107266 [I] app.c:107 | frameThread | Frame thread started
392657752 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
393450297 [I] app.c:202 | frameThread | Frame thread stopped
393500789 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
393501520 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
393502208 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
393502819 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
393503439 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
393504042 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
393504669 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
393505362 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
393505994 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
393506625 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
393507495 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
393508417 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
393511233 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
393513062 [I] app.c:237 | captureStart | Using : DXGI
393513605 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
393515987 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
393517048 [I] app.c:107 | frameThread | Frame thread started
404555490 [I] app.c:253 | captureRestart | ==== [ Capture Restart ] ====
405515461 [I] app.c:202 | frameThread | Frame thread stopped
405530906 [E] dxgi.c:190 | dxgi_init | Failed to open the desktop: 0x00000005 (Access is denied.)
405531637 [I] dxgi.c:203 | dxgi_init | The above error(s) will prevent LG from being able to capture the secure desktop (UAC dialogs)
405532521 [I] dxgi.c:204 | dxgi_init | This is not a failure, please do not report this as an issue.
405533342 [I] dxgi.c:205 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
405534399 [I] dxgi.c:206 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
405570445 [I] dxgi.c:388 | dxgi_init | Device Descripion: AMD Radeon RX 5700 XT
405571082 [I] dxgi.c:389 | dxgi_init | Device Vendor ID : 0x1002
405571616 [I] dxgi.c:390 | dxgi_init | Device Device ID : 0x731f
405572151 [I] dxgi.c:391 | dxgi_init | Device Video Mem : 8151 MiB
405572695 [I] dxgi.c:392 | dxgi_init | Device Sys Mem : 0 MiB
405573226 [I] dxgi.c:393 | dxgi_init | Shared Sys Mem : 1998 MiB
405573771 [I] dxgi.c:394 | dxgi_init | Feature Level : 0xb100
405574307 [I] dxgi.c:395 | dxgi_init | Capture Size : 1440 x 900
405574867 [I] dxgi.c:396 | dxgi_init | AcquireLock : enabled
405575419 [I] dxgi.c:411 | dxgi_init | Failed to set realtime GPU priority, this is not an error!
405576123 [I] dxgi.c:412 | dxgi_init | To fix this run LG using the PsExec SysInternals tool from Microsoft.
405576896 [I] dxgi.c:413 | dxgi_init | https://docs.microsoft.com/en-us/sysinternals/downloads/psexec
409986518 [I] dxgi.c:517 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
409987705 [I] app.c:237 | captureStart | Using : DXGI
409988289 [I] app.c:245 | captureStart | Capture Size : 5 MiB (5299200)
409988869 [I] app.c:247 | captureStart | ==== [ Capture Start ] ====
409989894 [I] app.c:107 | frameThread | Frame thread started
As @gnif asked you previously, please start a new topic for support and try to avoid hijacking other topics. Thanks for understanding and being a good netizen.
I would suggest updating to Beta 2 RC4, it has been released.
Beta 2 Release Candidate 4
Changes since RC3:
The host application can now install and run as a service removing the need for PsExec or a scheduled task to start the application.
There is now a NSIS installer for the host application which installs the service and will handle seamless upgrades without the need to uninstall prior versions.
The ho…
I see, when I first installed it yesterday RC4 has not been released yet. I did an update and will try it out. It is really awesome that I am now able to see the login screen properly.
I did fix the issue with the mouse not being aligned with the window as described in the FAQ.
The issue that I am unable to reconnect has also been resolved with version RC4.
One issue I encountered is when using fuilscreen mode my mouse is sometimes not able to move all the way across the screen. Sometimes in 2560x1440 fullscreen it keeps stopping around 5cm in front of the screen edge and I need to wiggle it a bit until I am able to move it all the way to the side.
This happens sometimes. While in full screen game view, I usually just turn on capture mode (push Scroll-Lock) which grabs the mouse exclusively for LG, then there are no position errors at the edge of the screen. You can also re-sync the edge calculation by either moving the mouse pointer fully up-down-left-right (which you did), or toggling capture mode (Scroll-Lock on, then off).
Netboy3
August 13, 2020, 10:52pm
10
Another thing I noticed in your host log is that you are passing-through a AMD RX5700XT. AMD GPU’s suffer from a design flaw called a “reset bug”. They will sometimes not wake-up correctly after a VM reboot and you’ll end up with a black screen until you reboot (or suspend) your whole system. I have a AMD RX580 Sapphire and as long as I don’t reboot the VM (I.E. only do proper VM shutdown), I’m OK, but YMMV. Current recommendation is to avoid AMD GPU passthrough and stick to Nvidia GPU’s.
Netboy3:
push Scroll-Lock
Thanks for the tip! I will try it out. Since you seem knowledgeable, please excuse my noobish questions, can you please explain to me how I can figure out if the looking glass refresh rate is keeping pace with the rate at which my GPU can provide new frames? Is there something like an FPS counter?
Thanks, but I am aware of that. I bought my 5700XT since I wanted one of those shiny new AMD cards and learned of the reset bug shortly after. Luckily the patch is working with the model I have. Since I use Manjaro I have the first version of the Navi Reset Patch baked into my Kernel, thanks to the nice devs over at https://forum.manjaro.org/ .
gnif
August 14, 2020, 8:38pm
12
Turn on the FPS display in the client: ./looking-glass-client -k
UPS is how many updates per second are coming in. Note it only sends changed frames, so to see if it’s keeping up you need to run your game/application and see. Static images like the desktop will have a very low UPS as there is nothing much going on.
