Looking glass B6 and B7 rc1, not working with new kernels
i have windows 10 in a VM. i cannot seem to get it to work with looking glass. neither B6 nor B7rc1.
here is my xml for the vm:
<domain type='kvm'>
  <name>TESSA3</name>
  <uuid>1f90e23f-b625-47b3-87bf-3d0df13e50e4</uuid>
  <memory unit='KiB'>16777216</memory>
  <currentMemory unit='KiB'>16777216</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <vcpu placement='static'>8</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='4'/>
    <vcpupin vcpu='1' cpuset='20'/>
    <vcpupin vcpu='2' cpuset='5'/>
    <vcpupin vcpu='3' cpuset='21'/>
    <vcpupin vcpu='4' cpuset='6'/>
    <vcpupin vcpu='5' cpuset='22'/>
    <vcpupin vcpu='6' cpuset='7'/>
    <vcpupin vcpu='7' cpuset='23'/>
    <emulatorsched scheduler='fifo' priority='1'/>
    <vcpusched vcpus='0' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='1' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='2' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='3' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='4' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='5' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='6' scheduler='fifo' priority='1'/>
    <vcpusched vcpus='7' scheduler='fifo' priority='1'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-7.0'>hvm</type>
    <loader readonly='no' type='rom'>/usr/share/ovmf/OVMFTESSA3.fd</loader>
    <bootmenu enable='yes'/>
    <smbios mode='host'/>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv mode='custom'>
      <relaxed state='on'/>
      <vapic state='on'/>
      <spinlocks state='on' retries='8191'/>
      <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
      <reset state='on'/>
      <vendor_id state='on' value='randomid'/>
      <frequencies state='on'/>
      <reenlightenment state='on'/>
      <tlbflush state='on'/>
      <ipi state='on'/>
    </hyperv>
    <kvm>
      <hidden state='on'/>
    </kvm>
    <vmport state='on'/>
    <ioapic driver='kvm'/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='off'>
    <topology sockets='1' dies='1' cores='4' threads='2'/>
    <feature policy='disable' name='hypervisor'/>
    <feature policy='require' name='topoext'/>
    <feature policy='require' name='svm'/>
    <feature policy='require' name='apic'/>
    <feature policy='require' name='invtsc'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='yes'/>
    <timer name='hypervclock' present='yes'/>
    <timer name='tsc' present='no' mode='native'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>destroy</on_crash>
  <pm>
    <suspend-to-mem enabled='no'/>
    <suspend-to-disk enabled='no'/>
  </pm>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
    <disk type='file' device='cdrom'>
      <driver name='qemu' type='raw'/>
      <source file='/root/virtio-win.iso'/>
      <target dev='sdb' bus='sata'/>
      <readonly/>
      <address type='drive' controller='0' bus='0' target='0' unit='1'/>
    </disk>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0xf'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x7' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x9'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0xc'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0xd'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x5'/>
    </controller>
    <controller type='pci' index='7' model='pcie-root-port'>
      <target chassis='7' port='0xe'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x6'/>
    </controller>
    <controller type='pci' index='8' model='pcie-root-port'>
      <target chassis='8' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='9' model='pcie-root-port'>
      <target chassis='9' port='0x1a'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
    </controller>
    <controller type='pci' index='10' model='pcie-root-port'>
      <target chassis='10' port='0x18'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='11' model='pcie-root-port'>
      <target chassis='11' port='0x19'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
    </controller>
    <controller type='pci' index='12' model='pcie-root-port'>
      <target chassis='12' port='0x1b'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x3'/>
    </controller>
    <controller type='pci' index='13' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </controller>
    <controller type='sata' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <address type='pci' domain='0x0000' bus='0x0b' slot='0x00' function='0x0'/>
    </controller>
    <controller type='usb' index='0' model='qemu-xhci'>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <input type='mouse' bus='ps2'/>
    <input type='keyboard' bus='ps2'/>
    <input type='keyboard' bus='virtio'>
      <address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
    </input>
    <graphics type='spice' port='5901' autoport='no' listen='0.0.0.0'>
      <listen type='address' address='0.0.0.0'/>
      <image compression='off'/>
      <gl enable='no'/>
    </graphics>
    <sound model='ich9'>
      <audio id='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
    </sound>
    <audio id='1' type='spice'/>
    <video>
      <model type='none'/>
    </video>
    <hostdev mode='subsystem' type='pci' managed='yes'>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x41' slot='0x00' function='0x0'/>
      </source>
      <boot order='1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0c' slot='0x00' function='0x3'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x0a' slot='0x10' function='0x6'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x45' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x05' slot='0x00' function='0x0'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x45' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
    </hostdev>
    <redirdev bus='usb' type='spicevmc'>
      <address type='usb' bus='0' port='2'/>
    </redirdev>
      <address type='usb' bus='0' port='3'/>
    </redirdev>
    <memballoon model='none'/>
    <shmem name='looking-glass'>
      <model type='ivshmem-plain'/>
      <size unit='M'>32</size>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
    </shmem>
  </devices>
</domain>
here is the host logs. i initially tried b7rc1 to match my client and then ive reverted to b6 in attempt make it work.
i have the ini set to explicitly use dxgi, because its supposed to be the reliable method.
00:00:00.016 [I]              time.c:85   | windowsSetTimerResolution      | System timer resolution: 499.9 μs
00:00:00.019 [I]               app.c:861  | app_main                       | Looking Glass Host (B7-rc1)
00:00:00.021 [I]           cpuinfo.c:38   | cpuInfo_log                    | CPU Model: AMD Ryzen Threadripper 1950X 16-Core Processor
00:00:00.023 [I]           cpuinfo.c:39   | cpuInfo_log                    | CPU: 1 sockets, 4 cores, 8 threads
00:00:00.026 [I]           ivshmem.c:132  | ivshmemInit                    | IVSHMEM 0* on bus 0x0, device 0x4, function 0x0
00:00:00.035 [I]               app.c:879  | app_main                       | IVSHMEM Size     : 32 MiB
00:00:00.035 [I]               app.c:880  | app_main                       | IVSHMEM Address  : 0x2A10000
00:00:00.036 [I]               app.c:881  | app_main                       | Max Pointer Size : 1024 KiB
00:00:00.036 [I]               app.c:882  | app_main                       | KVMFR Version    : 20
00:00:00.037 [I]               app.c:901  | app_main                       | Trying           : DXGI
00:00:00.042 [I]              dxgi.c:506  | dxgi_init                      | Device Name       : \\.\DISPLAY1
00:00:00.042 [I]              dxgi.c:507  | dxgi_init                      | Device Description: AMD Radeon RX 5700
00:00:00.043 [I]              dxgi.c:508  | dxgi_init                      | Device Vendor ID  : 0x1002
00:00:00.044 [I]              dxgi.c:509  | dxgi_init                      | Device Device ID  : 0x731f
00:00:00.044 [I]              dxgi.c:510  | dxgi_init                      | Device Video Mem  : 8151 MiB
00:00:00.045 [I]              dxgi.c:511  | dxgi_init                      | Device Sys Mem    : 0 MiB
00:00:00.045 [I]              dxgi.c:512  | dxgi_init                      | Shared Sys Mem    : 8190 MiB
00:00:00.125 [I]              dxgi.c:624  | dxgi_init                      | Feature Level     : 0xc100
00:00:00.126 [I]              dxgi.c:625  | dxgi_init                      | Capture Size      : 1920 x 1080
00:00:00.127 [I]              dxgi.c:626  | dxgi_init                      | AcquireLock       : enabled
00:00:00.127 [I]              dxgi.c:627  | dxgi_init                      | Debug mode        : disabled
00:00:00.132 [I]              dxgi.c:730  | dxgi_init                      | Bits Per Color    : 8
00:00:00.132 [I]              dxgi.c:731  | dxgi_init                      | Color Space       : DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
00:00:00.133 [I]              dxgi.c:732  | dxgi_init                      | Min/Max Luminance : 0.500000/270.000000
00:00:00.133 [I]              dxgi.c:733  | dxgi_init                      | Frame Luminance   : 270.000000
00:00:00.134 [I]              dxgi.c:740  | dxgi_init                      | Source Format     : DXGI_FORMAT_B8G8R8A8_UNORM
00:00:00.243 [I]              dxgi.c:766  | dxgi_init                      | Capture Format    : DXGI_FORMAT_B8G8R8A8_UNORM
00:00:00.243 [I]              dxgi.c:813  | dxgi_init                      | Output Size       : 1920 x 1080
00:00:00.244 [I]              dxgi.c:814  | dxgi_init                      | Copy backend      : Direct3D 11
00:00:00.245 [I]              dxgi.c:815  | dxgi_init                      | Damage-aware copy : enabled
00:00:00.252 [I]               app.c:445  | captureStart                   | ==== [ Capture Start ] ====
00:00:00.252 [I]               app.c:932  | app_main                       | Using            : DXGI Direct3D 11
00:00:00.253 [I]               app.c:933  | app_main                       | Capture Method   : Asynchronous
00:00:00.257 [I]               app.c:768  | lgmpSetup                      | Max Frame Size   : 14 MiB
00:00:00.258 [I]               app.c:455  | captureStop                    | ==== [ Capture Stop ] ====
00:15:07.590 [I]          platform.c:565  | exitEventCallback              | Received exit event
00:15:07.596 [I]               app.c:1078 | app_main                       | Host application exited
[I]    917310605              time.c:85   | windowsSetTimerResolution      | System timer resolution: 499.9 μs
[I]    917311261               app.c:771  | app_main                       | Looking Glass Host (B6)
[I]    917311708           cpuinfo.c:37   | lgDebugCPU                     | CPU Model: AMD Ryzen Threadripper 1950X 16-Core Processor
[I]    917312200           cpuinfo.c:38   | lgDebugCPU                     | CPU: 1 sockets, 4 cores, 8 threads
[I]    917313452           ivshmem.c:132  | ivshmemInit                    | IVSHMEM 0* on bus 0x0, device 0x4, function 0x0
[I]    917317017               app.c:788  | app_main                       | IVSHMEM Size     : 32 MiB
[I]    917317396               app.c:789  | app_main                       | IVSHMEM Address  : 0x2C30000
[I]    917317767               app.c:790  | app_main                       | Max Pointer Size : 1024 KiB
[I]    917318123               app.c:791  | app_main                       | KVMFR Version    : 19
[I]    917318509               app.c:809  | app_main                       | Trying           : DXGI
[I]    917321528              dxgi.c:390  | dxgi_init                      | Device Name       : \\.\DISPLAY1
[I]    917321937              dxgi.c:391  | dxgi_init                      | Device Description: AMD Radeon RX 5700
[I]    917322348              dxgi.c:392  | dxgi_init                      | Device Vendor ID  : 0x1002
[I]    917322720              dxgi.c:393  | dxgi_init                      | Device Device ID  : 0x731f
[I]    917323082              dxgi.c:394  | dxgi_init                      | Device Video Mem  : 8151 MiB
[I]    917323450              dxgi.c:395  | dxgi_init                      | Device Sys Mem    : 0 MiB
[I]    917323799              dxgi.c:396  | dxgi_init                      | Shared Sys Mem    : 8190 MiB
[I]    917374733              dxgi.c:503  | dxgi_init                      | Feature Level     : 0xc100
[I]    917375130              dxgi.c:504  | dxgi_init                      | Capture Size      : 1920 x 1080
[I]    917375511              dxgi.c:505  | dxgi_init                      | AcquireLock       : enabled
[I]    917375886              dxgi.c:506  | dxgi_init                      | Debug mode        : disabled
[I]    917376934              dxgi.c:598  | dxgi_init                      | Source Format     : DXGI_FORMAT_B8G8R8A8_UNORM
[I]    917377413              dxgi.c:640  | dxgi_init                      | Request Size      : 1920 x 1080
[I]    917378280              dxgi.c:658  | dxgi_init                      | Output Size       : 1920 x 1080
[I]    917378670              dxgi.c:666  | dxgi_init                      | Copy backend      : Direct3D 11
[I]    917379074              dxgi.c:667  | dxgi_init                      | Damage-aware copy : enabled
[I]    917379449               app.c:834  | app_main                       | Using            : DXGI Direct3D 11
[I]    917379834               app.c:835  | app_main                       | Capture Method   : Asynchronous
[I]    917382466               app.c:687  | lgmpSetup                      | Max Frame Size   : 14 MiB
[I]    917382936               app.c:385  | captureStop                    | ==== [ Capture Stop ] ====
it should be noted that adding virtio as a display allows looking-glass b7rc1 to work, but this makes windows disable the navi10 gpu.
host log looks fine, show your client log
./looking-glass-client -f /dev/kvmfr0 -c 10.13.74.200 -p 5901 -F  -g auto input:rawMouse=yes
00:00:00.000 [I]              main.c:1860 | main                           | Looking Glass (B7-rc1-34-ge25492a3a3)
00:00:00.000 [I]              main.c:1861 | main                           | Locking Method: Atomic
00:00:00.000 [I]           cpuinfo.c:38   | cpuInfo_log                    | CPU Model: AMD Ryzen Threadripper 1950X 16-Core Processor
00:00:00.000 [I]           cpuinfo.c:39   | cpuInfo_log                    | CPU: 1 sockets, 6 cores, 12 threads
00:00:00.042 [I]              main.c:1185 | lg_run                         | Using font: /usr/share/fonts/truetype/dejavu/DejaVuSansMono.ttf
00:00:00.043 [I]           ivshmem.c:137  | ivshmemOpenDev                 | KVMFR Device     : /dev/kvmfr0
00:00:00.046 [I]             audio.c:159  | audio_init                     | Using AudioDev: PipeWire
00:00:00.046 [I]                ps.c:245  | purespice_connect              | Connecting to socket 10.13.74.200:5901
00:00:00.064 [I]               rsa.c:178  | rsa_encryptPassword            | Using Nettle
00:00:00.065 [I]                ps.c:268  | purespice_connect              | Connected
00:00:00.065 [I]      channel_main.c:167  | onMessage_mainName             | Guest name: TESSA3
00:00:00.065 [I]      channel_main.c:183  | onMessage_mainUUID             | Guest UUID: 1f90e23f-b625-47b3-87bf-3d0df13e50e4
00:00:00.084 [I]                ps.c:644  | ps_connectChannel              | INPUTS channel connected
00:00:00.084 [I]           channel.c:323  | onMessage_notify               | [notify] keyboard channel is insecure
00:00:00.084 [I]               egl.c:289  | egl_initialize                 | Double buffering is off
00:00:00.084 [I]              main.c:1139 | tryRenderer                    | Using Renderer: EGL
00:00:00.085 [I]               x11.c:232  | x11CheckEWMHSupport            | EWMH-compliant window manager detected: Openbox
00:00:00.085 [I]               x11.c:497  | x11Init                        | X11 XInput 2.0 in use
00:00:00.111 [I]               x11.c:1501 | x11GetEGLDisplay               | Using eglGetPlatformDisplayEXT
00:00:00.245 [I]               egl.c:773  | egl_renderStartup              | Multisampling enabled, max samples: 4
00:00:00.246 [I]               egl.c:856  | egl_renderStartup              | Single buffer mode
00:00:00.248 [I]               egl.c:883  | egl_renderStartup              | EGL     : 1.5
00:00:00.248 [I]               egl.c:884  | egl_renderStartup              | Vendor  : AMD
00:00:00.248 [I]               egl.c:885  | egl_renderStartup              | Renderer: AMD Radeon RX 5700 (radeonsi, navi10, LLVM 15.0.6, DRM 3.59, 6.12.5-mathew2214-mk1)
00:00:00.248 [I]               egl.c:886  | egl_renderStartup              | Version : OpenGL ES 3.2 Mesa 24.2.4-1~bpo12+1
00:00:00.248 [I]               egl.c:887  | egl_renderStartup              | EGL APIs: OpenGL OpenGL_ES
00:00:00.249 [I]               egl.c:958  | egl_renderStartup              | Debug messages disabled, enable with egl:debug=true
00:00:00.283 [I]           eglutil.c:35   | swapWithDamageInit             | Using EGL_KHR_swap_buffers_with_damage
00:00:00.477 [I]              main.c:1492 | lg_run                         | ================================================================================
00:00:00.477 [I]              main.c:1493 | lg_run                         | The host application seems to not be running
00:00:00.477 [I]              main.c:1494 | lg_run                         | Waiting for the host application to start...
00:00:29.479 [I]              main.c:1499 | lg_run                         | ================================================================================
00:00:29.479 [I]              main.c:1513 | lg_run                         | Check the host log in your guest at %ProgramData%\Looking Glass (host)\looking-glass-host.txt
00:00:29.479 [I]              main.c:1514 | lg_run                         | Continuing to wait...
00:00:32.487 [I]           channel.c:269  | channel_internal_disconnect    | INPUTS channel disconnected
00:00:32.487 [I]           channel.c:269  | channel_internal_disconnect    | MAIN channel disconnected
00:00:32.487 [I]                ps.c:330  | purespice_disconnect           | Disconnected
this is with the navi10 being passed. if i remove the gpu and use virtio for VM video, then looking-glass works perfectly. this is why i believe my client is perfectly fine, and the windows-side of LG is the problem.
today, i am backing up my VM and reformatting and reinstalling windows 10. doubt itll change anything, but with windows you never know.
Update: nothing has changed. Reinstalling windows did not fix it.
update: found this is my dmesg
kernel 6.12.6, debian bookworm.
[Fri Dec 20 17:36:44 2024] kvmfr: loading out-of-tree module taints kernel.
[Fri Dec 20 17:36:44 2024] kvmfr: creating 0 static devices
[Fri Dec 20 17:36:44 2024] Hotplug memory [0x384810000000-0x384812000000] exceeds maximum addressable range [0x0-0xaffffffffff]
[Fri Dec 20 17:36:44 2024] kvmfr: kvmfr_pci_probe: failed to remap pages! ret = -22
[Fri Dec 20 17:36:44 2024] kvmfr: kvmfr_module_init: module loaded
update: reverting to Linux 6.4 works fine.
conclusion: looking-glass B7rc1 is incompatible with Linux 6.12.
Did you ever configure kvmfr with a specific size?
sudo rmmod kvmfr
sudo modprobe kvmfr static_size_mb=32
(where 32 is the size of your ivshmem device that you posted earlier)
It loaded fine on Linux 6.12 here when that number was set correctly, so…
i use insmod to load the module. adding that parameters yields in my kernel logs:
[Sat Dec 21 10:16:25 2024] kvmfr: loading out-of-tree module taints kernel.
[Sat Dec 21 10:16:25 2024] kvmfr: creating 1 static devices
[Sat Dec 21 10:16:25 2024] Hotplug memory [0x384810000000-0x384812000000] exceeds maximum addressable range [0x0-0xaffffffffff]
[Sat Dec 21 10:16:25 2024] kvmfr: kvmfr_pci_probe: failed to remap pages! ret = -22
[Sat Dec 21 10:16:25 2024] kvmfr: kvmfr_module_init: module loaded
Debian bookworm, Linux 6.12.6
i cannot recreate the same output using Linux 6.4.
What changed between 6.4 and 6.12 that could be causing this?
update, even after updating ovmf and the entire debian system to the latest bookworm packages, this issue persists.
This has nothing to do with LG. It’s an issue between OVMF and QEMU that is triggered by mapping IVSHMEM. The TL;DR is that this issue has been addressed by libvirt 9.5 and QEMU 8.2, and if you’re running older revisions, either revert (not upgrade) OVMF to earlier than 202211 or limit the QEMU physical address with a parameter. See physical address space in qemu | 🇺🇦 kraxel’s news for details of the issue and mitigations.
Thanks. Ill look into that. But im confused how it can be an ovmf and qemu issue when the only difference (between workimg and not working) is kernel version? What about new kernels breaks older ovmf/qemu compatibility with LG?
Debian “stable” having outdated bugs strikes yet again?
The memory addressing scheme was changed in OVMF and the IVSHMEM device is being mapped in an address far too high for DMA buffer mappings.
Newer kernel versions are correctly refusing to map memory for DMA usage that is mapped into a region that is unsafe for such usage. It was a bug to not prevent this.
The solution is to either downgrade OVMF, or set the CPU host max physical bits in QEMU to limit the upper address range that OVMF will use when assigning memory regions.
After upgrading my Ubuntu 24.04 system (which updates the kernel to 6.11.0-17) I’m having a problem with DKMS compiling the module for kvmfr. This is with no other relevant or meaningful updates to libvirt or OVMF, so pretty sure those aren’t the issue. It really does sound like the Looking Glass kvmfr module in version B7-rc1 (referred to as module version 0.0.9) is having problems with newer kernels.
Is there a B8 available, or should users of new kernels switch to the bleeding edge commits?
Here are the contents of my DKMS log:
DKMS make.log for kvmfr-0.0.9 for kernel 6.11.0-17-generic (x86_64)
Fri Feb 14 07:08:44 PM EST 2025
make -C /lib/modules/6.11.0-17-generic/build M=/var/lib/dkms/kvmfr/0.0.9/build modules
make[1]: warning: jobserver unavailable: using -j1.  Add '+' to parent make rule.
make[1]: Entering directory '/usr/src/linux-headers-6.11.0-17-generic'
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
  You are using:           gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
  CC [M]  /var/lib/dkms/kvmfr/0.0.9/build/kvmfr.o
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c: In function ‘mmap_kvmfrbuf’:
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c:167:14: error: implicit declaration of function ‘remap_vmalloc_range’; did you mean ‘ida_alloc_range’? [-Werror=implicit-function-declaration]
  167 |       return remap_vmalloc_range(vma, kbuf->kdev->addr + kbuf->offset,
      |              ida_alloc_range
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c: In function ‘create_static_device_unlocked’:
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c:508:16: error: implicit declaration of function ‘vmalloc_user’ [-Werror=implicit-function-declaration]
  508 |   kdev->addr = vmalloc_user(kdev->size);
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c:508:14: warning: assignment to ‘void *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
/var/lib/dkms/kvmfr/0.0.9/build/kvmfr.c:533:3: error: implicit declaration of function ‘vfree’; did you mean ‘kvfree’? [-Werror=implicit-function-declaration]
  533 |   vfree(kdev->addr);
      |   kvfree
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:244: /var/lib/dkms/kvmfr/0.0.9/build/kvmfr.o] Error 1
make[2]: *** [/usr/src/linux-headers-6.11.0-17-generic/Makefile:1931: /var/lib/dkms/kvmfr/0.0.9/build] Error 2
make[1]: *** [Makefile:224: __sub-make] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-6.11.0-17-generic'
make: *** [Makefile:7: all] Error 2
Please use Bleeding Edge as it contains updates related to building the kernel module on newer kernels. If you use a kernel above version 6.13, you’ll also need to apply this PR to get it to build (the PR should be merged soon, but in case you need it now, you’ll need to apply it yourself). Regarding the next release, the upcoming release is B7, not B8. B7-rc1 is a release candidate of B7. Also, as your issue is different than the OP (you fail to build the module), you should have really opened a new thread instead of hijacking this one.
A post was merged into an existing topic: Looking glass VM to VM not working
