Looking for LGA2011 mob with at least 8 sata ports, and an M.2 slot
hey yall. im thinking of upgrading the board in my home server so i can expand storage a bit easier. right now, it has 8 sata ports, and no M.2 slot. im using 6 of the sata ports currently (4 for an array, 1 for a stand alone storage drive, and one for boot) i want to increase my available capacity without having to jump to bigger drives.
do you have any recommendations for boards i should look at?
thanks
This board is pretty much unobtanium these days, but this guy has 10 SATA ports and two NVMe m.2 slots
You could also grab an SAS HBA and add 8 more ports that way, they’re widely available on eBay.
I go this way, but OP should be aware that sas to sata cables are also required.
And I should be aware this is not Actually what the OP was asking for, but…
I would recommend “the art of server” EBay shop (and YT channel)
Selling Something like these:
And cables like this:
i am aware of HBA’s. for my current purposes though, im looking to change out the board.
i see what you mean by unobtanium. luckily i found some boards that fit my bill after messing with my search criteria a bit. thanks for the help though.
there’s a lot of “salvage” x99 boards out there from China, basically put together with weird components removed from non working boards. they always seem to lack a generous amount of DIMM slots for some reason. I guess DIMM slots are expensive, both for the slot, and more-so routing all those traces.
