I was thinking 21:9 too, but cost is a limiting factor. I also like using two monitors and I’m not sure if I could do an UW with another monitor stacked on top of it.
Ah, for me, it’s more about screen real estate. Since I’ve written code to allow Kwin to tile windows, I don’t have to worry about snapping and whatnot. I just want display space.
So needless to say I completely forgot about this.
Anyways, I’m really bad at reviewing peripherals, so
DPI is definitely fine. Glad I went with a 27" for 1440p.
Stand is pretty garbage. It’s stable, but short and only has tilt adjustment. I swapped the stand with one from an ASUS PB238Q to bring it up to a good height.
Screen came with janky settings, was set to warm tone + HDR + black adjustment + weird gamma. Changed it all and it’s good. Not as good as the LG 4K next to it, but definitely still good.
Bezel is thin, about 5/16" from the edge of the last pixel to the outer edge of the monitor.
I can’t test HDR or Freesync because my newest GPUs are 980 Tis
Granted if you are going UW (which still sounds nice even after this monitor) then none of the above really matters much.
Yes, it’s pretty nice. Colors are vibrant without being oversaturated, my unit has minimal IPS backlight bleed, the build quality seems good, and I don’t seem to get eye strain using it. I didn’t even really calibrate it, I didn’t change the RGB settings at all.
It seems to have a lot of menu options too, there are multiple profiles that can be saved, color balance can be changed, gamma, brightness, refresh rate, response time, et cetera. It also has reticle options those that like to cheat in an FPS.
No worries. It’s a damn good monitor, but I really would prefer something less expensive. I’m still leaning towards that 38in acer uw.
Kinda got a hardon for it.
And with my 2 weeks officially in, I’ve got a set time frame for figuring out my display setup, so I’m going to have to pull the trigger soon. Assuming I don’t work something out to hang on to the ones I have.
I’ve been looking for 1440p monitor now for a while. My current options are this,priced around 300€ in Finland (didn’t notice anyone recommending this):
And that Dell U2719D I linked earlier. Unfortunately neither has freesync and both are 60hz panels. That BenQ is quite old model already, but according to this review it should probably be ok even today.
I would probably go for Pixio monitor if they were available in EU. Really hard to find IPS montior with freesync and high refresh rate that would also be affordable.
The pixio px329 just came in yesterday and for the price it’s pretty damn good. Still have to do some more testing with Nvidia card and freesync but overall I don’t think you will be disappointed. Stand is a regular stand with no movement .
doesn’t check your freesync box, but it’s 10-bit and overclockable to 75hz if you drop it down to 8-bit.
personally using the U2717D which Dell sent as a replacement for my U2715H. Despite being an intended replacement, Dell cut corners and it’s an inferior panel (color repro, input lag). Supposedly, the U2719D resolved the aforementioned shortcomings.
Nixeus 1440p ips
I have it, its okay and super cheap
Although if you plan on gaming with it I do not recommend anything but 1080p, I actually regret the purchase
I think overall the colors are great. Right next to those Samsung’s I linked I can’t tell much of a difference. Although disclaimer my eyes are not super calibrated for that type of stuff . So take my word with however much salt you need to. I have not messed anymore with freesync. I will try and get back with you tonight or tomorrow.
