I’m trying to decide what to get for a new desktop. Seems like a standard form factor like mini-ITX would work best for future proofing, but having trouble finding a combination I like. Last desktop has lasted me many years, and I want to get many years out of the next one too.
Lots of brain dump below as I was trying to clarify my thoughts and options.
I’m primarily interested in mini-ITX options, but nothing is decided. I probably will take a while to solidfy a preference and things are always changing.
Thanks for any help.
old desktop
- Lenovo Edge 15 Laptop
- intel i5-480m, 1st Gen, arrandale
- 8GB, maxed out
- expresscard34 slot
- USB 3.1g1 5Gb/s, 2 ports
- doesn’t seem the be enough PCIe bandwidth to support 2x 5Gb/s USB
- 7.5 years old
- can’t boot from eSATA
- have to remove external monitor from top of laptop to power up
- recently started thermal overloading
- often at 90C
- sometimes crash @105C
- disabling boost and limiting CPU to 2GHz and fan full still not good enough to control thermals all the time, and noisy
- cleaned dust and reapplied thermal paste, no difference
- fan exhaust not hot
- heat pipe maybe not conducting well
- crashed too many times, now using older worse laptop
new desktop uses
- linux desktop
- browser
- spreadsheet
- terminal sessions, local/remote
- minor software / scripting
- no games, no AI, so integrated GPU is cheap and acceptable
- KVM
- docker
- kubernetes
- LXC/LXD
- windows dual boot, maybe a couple of times a year for obscure software that requires physical windows box
- linux desktop
reuse
- monitors
- Samsung 860 EVO 500G for boot device
- can get M.2 NVME later
- bulk storage over NFS
minimum
- 6 cores, 12 threads
- 16GB RAM
- probably not overclocked, or maybe just the RAM, depends
- dual monitor
- currently VGA + HDMI
- support 2x HMDI/DP
- maybe support laptop panel too if laptop
maximum
- CPU 65W TDP
want
- 8C/16T or more
- 32GB, maybe 64GB, ECC
- integrated graphics
- cheaper
- less power
- don’t need discrete GPU, no gaming, no AI
- Thunderbolt
- USB 3.1g2 10Gb/s, 4 ports, A & C
- eSATA
- maybe via extra card if mini-ITX
- maybe USB-eSATA dongle
- Port Multiplier support is occasionally useful
- Have express-card with PM support, but nothing has express-card anymore.
- case with structural integrity to support a monitor on top
form factors
- laptop
- mini-ITX
- OEM tiny cases
- micro-ATX
- don’t really want get this big
- may as well put a GPU in the server, but want to be able to crash and burn the desktop without impacting the server or polluting it with package install/uninstalls.
laptop
- i7-8750H 6C/12T
- con: thunderbolt often only bundled with NVidia GPU
- don’t want the expense or power penalty of discrete GPU
mini-ITX
case
- ~InWin Chopin
- pro: small, 3 litre
- con: blocked expansion slot
- con: top mesh can’t hold a monitor, would need a shelf
- probably need replacement low profile fan, maybe Noctua
- haven’t found any similar size cases I like
- ~InWin Chopin
AMD mini-ITX not may options
- 2400G seems best I can get with graphics
- only 4C
- 2700 8C
- no graphics
- MBs, in the past ASUS has apparently supported ECC
- ASUS ROG Strix B450-I
- ASUS ROG Strix X470-I
- Gigabyte B450 I Aorus Pro
Intel
- i7-8700 only 6C
- i7-8700T 25W but can’t find anyway
- MBs
- ASRock H370M ITX/ac
- ASUS ROG Strix H370-I Gaming
- MSI B360I Gaming Pro
RAM usually only 2 slots, 16GB/slot, max 32GB
Thunderbolt
- Usually can’t find on mini-ITX MB
- Can’t find after market TB card with low profile
- Still seems to require some kind of MB connector
OEM tiny desktops, approx 1-1.5 litre
- Usually i7-8700T, 6C/12T max, 32GB max, 25W TDP
- Lenovo Thinkcentre M920 Tiny
- Thunderbolt advertised but not purchasable (yet?)
- HP Elitebook 400 G4
- ASRock Jupiter, but can’t find in AU
- ASUS ~VivoMini VC65-C1, 2 litre
- con: expensive compared to mini-ITX
Just as well I have an even older laptop I can use until I find a solution I like.
