I’m repurposing an old 3960X workstation with 128GB RAM targeting proxmox + virt truenas. My existing Synology NAS has 9 HDD + 2x Gen3 NVME 1TB as SHR2 + cache. I’ll be moving the entire setup to the workstation on a 9300 HBA and wondering if I should use those NVME drives for L2ARC or just use them as zfs mirror general storage on the proxmox side. Opinions? Benchmarks I should run?
L2ARC. No redundancy required, 2TB of MFU/MRU +metadata stuff that doesn’t need to be fetched from HDDs…and a somewhat hand warm cache after a reboot and cold ARC…
be sure to check the official ZFS documentation for parameters regarding the L2ARC, as it is very customizable.
I wrote a guide 2 years ago and I also included some relevant parameters the L2ARC can benefit from…somewhere way down in the second posting. Feed rate and MFU-only can make a big difference in what kind of data you want, nothing worse than hot spot data getting evicted for some undesirable MRU crap all the time.
Tuning is some effort, but I got my money’s worth from my 2x1TB Gen3 drives.
But if you have a good use for a 1TB mirrored NVMe pool…just tell ZFS to remove the CACHE devices and create a new pool if L2ARC isn’t doing as much as you expected. Or just give the pool 1x1TB drive and use the other drive for some VM, boot or scratch/swap drive.
Read caches and their impact are very dependent on what you do. They can be gold or they can be basically useless.
Just wait for L2 to fill up…takes a while for it to reach capacity. I’d try checking or benchmarking after a couple of days with warmed up ARC+L2ARC both at _MAX to get an opinion on the impact.
I had my 2x1TB in a separate pool, then switched to SPECIAL device and put them to work as L2ARC half a year later…for me, L2 was their true purpose after tuning some parameters.
Try out stuff, stick to the one that works best for you.
Appreciate the guide link that’s exactly what I was looking for. My existing NAS has a huge number of tiny files. Prior to adding the cache to the Synology I really couldn’t search properly. My experience with ZFS is pretty limited flash storage and this will be my first go tuning the rust bulk storage behind my NAS.
Could be good to look into zfs special devices too then.
Why? You can set up the zfs pool directly on Proxmox, run samba in a container, run anything else you need for that matter.
I’ve played with L2ARC, but found it didn’t do much unless your ARC is constantly filling up. So it felt very situational (DB with big, hot indexes). Maybe with some tuning it would work well, but I didn’t try that.
Personally I would make a separate pool. If you’re running VMs or DBs, maybe SLOG. Though probably the best thing you can do is make them a ZFS Special Device. That moves all the Metadata (and optionally Small blocks) to the SSDs, which would significantly speed up metadata operations. But it’s permanent, and basically locks those SSDs to the pool. So only proceed if you know what you’re getting into.
While most people will talk about using whole devices, there is no reason to not just make a smallish partition and use that, so you can use the rest of the space for something else. Zfs does not need to run on raw devices, it will create a gpt partition anyway when pointed to use a raw device
True. The only real reason is to snapshot the thing as I bench it in various configs. The PCI devices are passthrough so it’s really the same either way, just proxmox can’t use the pools. I can always flip to that after I get the thing tuned up.
Or a thin-provisioned LVM.
Personally, I think a metadata L2ARC is the sweet spot. I’ve got a USB drive acting as one for my ZFS mirror; even though it’s slow on it’s own, the random speeds are still way better than mechanical, so searching is about an order of magnitude faster, and anecdotally I can hear less drive activity when loading a game or copying a directory with lots of small files.
I’d be curious to see your arc_summary with that.
I’ve only been tracking things casually, so I decided to reboot and see how my activities affect things.
Pool info:
recordsize=1Mcompression=zstd-3l2arc_noprefetch=0- 12TB mirror, of which about 4.6TB compressed / 5TB actual is used
- my Toshiba is rather “crunchy” while my WD is very quiet, so YMMV on that front
Caveats:
- I’d already ran
du -shandfdupes, and enabled prefetching awhile back, which pre-populated the cache a fair bit. - Most of my data rarely changes: archived websites, videos, documents, games. No databases, VM’s, etc.
Startup:
L2ARC size (adaptive): 12.7 GiB
Compressed: 10.3 % 1.3 GiB
Header size: 0.2 % 31.3 MiB
MFU allocated size: 28.0 % 375.5 MiB
MRU allocated size: 90.3 % 1.2 GiB
Prefetch allocated size: 1.4 % 19.1 MiB
Data (buffer content) allocated size: 0.0 % 0 Bytes
Metadata (buffer content) allocated size: 119.7 % 1.6 GiB
L2ARC breakdown: 1.7k
Hit ratio: 30.7 % 523
Miss ratio: 69.3 % 1.2k
L2ARC I/O:
Reads: 2.4 MiB 523
Writes: 376.0 KiB 11
Running Steam and playing Halo 2 MCC for awhile:
Header size: 0.2 % 31.1 MiB
MFU allocated size: 28.0 % 375.1 MiB
MRU allocated size: 90.4 % 1.2 GiB
Prefetch allocated size: 1.4 % 19.0 MiB
L2ARC breakdown: 17.8k
Hit ratio: 13.3 % 2.4k
Miss ratio: 86.7 % 15.4k
L2ARC I/O:
Reads: 10.2 MiB 2.4k
Writes: 5.2 MiB 172
Loading a 72gb directory with over 3000 saved webpages and about 2000 other files into my file browser (thumbnail caching disabled):
Header size: 0.2 % 30.5 MiB
MFU allocated size: 28.0 % 375.4 MiB
Prefetch allocated size: 1.4 % 18.8 MiB
L2ARC breakdown: 28.8k
Hit ratio: 33.4 % 9.6k
Miss ratio: 66.6 % 19.2k
L2ARC I/O:
Reads: 41.5 MiB 9.6k
Writes: 5.5 MiB 187
Just doing my normal stuff: going through a few directories, searching for and watching some saved YouTube videos, playing more Halo 2, etc.:
L2ARC size (adaptive): 12.8 GiB
Header size: 0.2 % 30.7 MiB
MFU allocated size: 22.6 % 303.7 MiB
MRU allocated size: 95.4 % 1.3 GiB
Prefetch allocated size: 1.7 % 22.7 MiB
L2ARC breakdown: 106.3k
Hit ratio: 60.4 % 64.2k
Miss ratio: 39.6 % 42.1k
L2ARC I/O:
Reads: 212.6 MiB 64.2k
Writes: 13.9 MiB 565
Finally, doing another size check with time parallel -v ::: 'du -sh .' 'du -sh --apparent-size .' (took 3m20.751s, data drives were basically idle):
Header size: 0.1 % 17.9 MiB
MFU allocated size: 24.4 % 328.4 MiB
MRU allocated size: 94.9 % 1.2 GiB
Prefetch allocated size: 0.4 % 4.9 MiB
Metadata (buffer content) allocated size: 119.6 % 1.6 GiB
L2ARC breakdown: 366.7k
Hit ratio: 88.1 % 322.9k
Miss ratio: 11.9 % 43.8k
L2ARC I/O:
Reads: 1.0 GiB 322.9k
Writes: 15.2 MiB 656
As much as I like metadata L2ARC, I really wish they would merge Special Failsafe[1] or a similar writethrough scheme.
[1] Special failsafe feature by tonyhutter · Pull Request #16185 · openzfs/zfs · GitHub
