L1's Garage
Only downside in my opinion is that it´s not really a good looking car.
This one meets the BMW/Mini spec from models with the same engine as my car (Peugeot 408 THP), also many others.
Same weight as always, 5w30.
Then it should be fine. :slight_smile:
I use Champion oil in my Volvo.
It was the only oil i could get at a local shop that meets spec.
i just order amsoil, but im in the US
Yeah i guess i will just order oil the next time as well.
Because i paid like €20,- / L at the local shop for Champion.
And that is a bit expensive for my liking.
I mean Castrol or Kroon oil is like €55 / 5L or so.
i pay ~$80 for 6 qts, plus filter. but filter is $15, supposed to last 15k
That’s not too bad.
Basically my Volvo needs a regular oil service every 15K km’s.
I probablly gonna do a full service just before the winter season.
i do changes on 5000 miles. filter supposed to last 15000 miles. ford recommends 10000 miles… but fuck that shit
Oh things have changed from the 3k oil change lol
I know the chemistry and additives longer polymer chains etc…closer tolerances etc… still…
Yeah not a bad idea change a bit earlier indeed.
But it probably also depends on the engine.
I mean those modern ecoboost engines likely burn some oil anyways.
But older engines are probably not that sensitive.
Oil shmoil
If it fits, it ships!
/s
As long as it’s not the bottom of the barrel stuff I’ve never had an issue with using whatever was readily available.
There’s quite the variety of oils here, but almost everything is like “DEXOS 2! VW! Fiat!”
im not ecoboost. just duratec.
ford also says “oh, you don’t need to change the ptu fluid”
https://www.amsoil.com/p/sae-5w-30-ls-synthetic-european-motor-oil-ael/
BMW LL-04 there it is, that one would work for my car.
Here’s the one i got:
Well yeah that is Ford now days i guess… :woman_facepalming:
they at least put a drain plug in. i have to fill it thru the vent tube.
Well at least you can do it yourself then.
I can’t really do much on my car myself.
Because i simply don´t have the tools or a car lift.
But simple things like checking fluids etc i can do that myself.
But things like full service etc i have to go to a garage.
And yeah in regards to a Volvo a service isn´t really cheap.
But yeah that are normal regular costs for driving a car. :slight_smile:
i use ramps in the driveway. no lift. don’t need to may specialized tools either
