regular maintance on a Volvo is pretty expensive,
because accesibility around the engine is very limited.
The pcv system for example is burried deep inside the engine bay.
And pretty difficult to acces.
But if you don´t service the pcv system in time.
Then at some point it may clog up, and then you will blow some seals.
That is a very weak point on the volvo´s.
Look his tests are cool but they aren’t entirely accurate. And at that point consifer your paying twice for a marginal increase at best
IMHO you’ll have way better results changing twice as often with the Pennzoil than changing once a year with amsoil.
That and it depends on the filter. Going that long requires a larger heavier duty synthetic filter. Because if you fill the standard size one up its all bypass and then that gunk is immersed by amsoils good properties. these are tests that dude can’t perform my dude
like i said, i change at 5k. the amsoil filter is about 2x the length of the stock. i may go longer depending on what i get from blackstone on my next change
So you change the twice as expensive oil. Very frequently. Not even realizing the benefits you are paying double for. Come on bro I know we love our cars but sometimes just reevaluate the choice. Lol.
I suppose oil is cheap
Idk changed every 3k to 5k Pennzoil ultra plat. 5 QTS is 23.97 here… Plop on a 7 dollar wix xp… Got 400k out of an engine. Never saw a need for amsoil except in the transmission fluid and brake lines (syn dot 4)
i also live where it gets down to -40 in winter. trans fluid (well, the last drain and fill) and PTU oil are amsoil. will be flushing out the brakes with amsoil. rear diff will be amsoil whever i get around to sucking that stuff out. may go to a wix filter if i continue with 5k
Amsoil is great in long service life stuff and I would use it on that part of the power train.
Engine oil. Men at -40F it doesn’t realistically matter if you can flow a few centimeters more. Its fucking -40 lol
I just take the pragmatic engineer approach to it. Get the cheaper. Change it more often than the manual. Never worry.
It gets down in temp here in the mtns too. That’s why their transmission fluid is great. No slip or skip when super cold. Which is nice. Ford transmission are nice but picky
Then dont change. Take what’s rated or move over to the waterless. The waterless is a lifetime coolant. Never has to be changed because the cause of corrosion has been removed. No water
Supposed to be yeah but there have been issues. Ford tech make you loco lol talked about it. I’d just roll waterless my dude. I changed once. Never changed again since 130k… Checked it every 60k still perfect. No more pressure on the lines either. Like its been fantastic.
P-OAT was created to be a better corrosion inhibitor vs glycol as when mixed with water if something is lightly acidic it prevents this
However if its a waterless coolant or has no water then there is no need for P-OAT or expensive corrosion inhibitors. I think the whole thing has been a dumb mess and customers are the beta test hence I opted out
