Okay when I have my Tesla K40 in at the same time I have a Sata Drive plugged in, it won’t boot into windows even if the installation is on a NVME m.2
it won’t post with above 4G decoding is disabled so its enabled
complete system specs
3800XT
AX370 Gaming 5 (non K)
2x8GB 3200
500GB WD m.2
Vega64
Tesla K40
PS2 keyboard
USB mouse
windows 10 Pro
CSM is enabled and UEFI only mode
The sata drives have no smart errors and work perfectly fine when the K40 isn’t installed
I get a code 10 insufficient system resources exist to complete the API on the device manager for the K40
going to swap out my vega64 with a GT730 see what happens
same results
okay I disabled CSM per this serve the home guide and the Tesla no longer has code 10 and renders fine
will shutdown and attach sata devices to see if it’ll boot
after attaching sata devices infinite boot persists
it successfully boots into windows with the 3TB drive attached but can’t access the drive and its at constant 100% usage
I suspect its because its GPT
so the AX370 gaming 5 probably just can’t handle all the bar space even with Above 4G decoding
