I feel in love with the Jonsbo N1 a while ago for the design and functionality, and the 1x 2.5 and 5x 3.5 in small case. Since then I’ve been toying around with a setup in my head that should be highspeed, zfs, and not way too expensive. Feel a bit ashamed that I didn’t think of oldschool case modding and cheating.
Anyways, here’s something to work from.
Jonsbo N1 $150
ASRock A320M-ITX or similar motherboard with 1x m.2 and can take 64GB ECC $140
AMD RYZEN 3 PRO 4350GE, AMD Ryzen 3 PRO 2200GE, or similar $140
64GB RAM DDR4 ECC UDIMM 2x32GB $320 used from ebay
IBM M5110 8 port 6GB raid flashed as IT $25 used from ebay
Something low profile talking 10GB $30 used from ebay
NGFF M.2 Key M to PCIe x4 Gen3 32Gbps Extender Cable Adapter R42SF $25
Total: $830-ish
Now comes the tricky part. Cut out room for a low profile pcie card at the back of the case. Drill a hole, straighten the bracket on the card, fasten it with a nut and bolt.
IBM/Lenovo ServeRAID M5110, Dell perc H200, Dell perc H310, Dell perc H710, HP have a couple too, and a bunch more raid controllers all use similar sas controllers (LSI SAS2008-SAS2308) that can be flashed with the LSI SAS 9207-8i firmware that allows JBOD/IT mode if the original firmware don’t. A lot of them comes preflashed and dirt cheap on ebay.
Thanks for pointing out. Why making it easy, AMD? But for this I found a bunch of used Ryzen 3 Pro 4350G that have ECC support for $140. Ryzen 3 PRO 2200GE has a similar price.
Not remotely as fun, but a SUPERMICRO MBD-X10SDV-4C-TLN2F might actually be the best alternative. $700 +$200 for 2x32GB DDR4 ECC RDIMM. The ECC udimms breaks the former setup.
Xeon D are neat little things and a lot of value if you can snag a good deal. I managed to snag an AsrockRack D-1541 board back in 2019 for like $500 new and have yet to find a similar deal on that SKU or higher. Obnoxiously expensive for what they are though if they’re not on sale. At $700 a D-1521 board isn’t that great of value in my book. Also found this for the US folk SuperMicro X10SDV-4C-TLN2F, Mini-ITX,Xeon D-1521. with active fan & I/O shield 672042197606 | eBay
That case is not something designed for this product but something generic right? I’m saying this because I have a Saturn Mantiz Pro eGPU enclosure inside the same form factor. Don’t get me wrong this thing is a beefy aluminum case and it looks nice.
Finishing off this. 2FA was totally right, a board with a D-1541 like the SuperMicro X10SDV-4C-TLN2F is the right way to go. That board checks all the marks, ecc, 6 sata, and 10GB network.
Jonsbo N1 $150
SuperMicro X10SDV-4C-TLN2F $250 used from ebay
64GB 4X16GB DDR4-17000R 2133Mhz ECC Reg $110 used from ebay
SFX power supply, about 300W less known brand $50
Total: $560-ish
Then comes the price of 1x ssd and 5x hdd. But a similar NAS from QNAP or Synology is at least $900-1000, and this can run zfs.
