Theres been a little bit of discussion on the WWDC thread. But With some new features popping up I though it might be worth its own thread. (where’s the Android equivalent btw?)
Apple describe a lot of the new features here OS - iOS 26 - Apple
But some of the privacy facing ones stand out.
Privacy information on the App Store
A new section on each product page on the App Store helps you see a summary of the privacy practices of the app before you download it.15Developers self-report their privacy practices, including data collected by the developer and used to track you across companies, in a simple, easy-to-read format.
App tracking controls and transparency
Developers are now required to get your permission before tracking you. See which apps you have given permission to track in Settings so you can change your preferences.
Approximate location
A new setting lets you choose to share your approximate location, rather than your precise location, with an app.
Limited Photos library access
You can choose to share only selected items with a developer who asks for access to your photos, or you can give access to your entire library.
Recording indicator
iOS displays an indicator whenever an app is using the mic or camera, both in the app and in Control Center.
Upgrade to Sign in with Apple
Developers can offer the option to upgrade existing app accounts to Sign in with Apple so users can enjoy improved privacy, security, and ease of use without setting up a new account.
Of these there’s a few stand out ones to me. In particular the two most noticeable changes that ive seen and used are the improved location controls and the recording indicator.
This I use. On the occasion where an app needs to know you’re rough location (like verifying your in the right country), manually specifying the app to get your approximate location once is really handy.
The other improvement that is more of an awareness one is the recording indicator
TikTok for the example. Top right there’s the little orange dot. That indicates that the microphone is being used. In TikToks situation its using the microphone as soon as you open the app.
Orange is the microphone, green is video/audio. It makes it easy to see apps abusing permissions you’ve given them.
I think the privacy options overall are great improvements.
Theres new app tracking permissions
And things like Sign in with Apple while I think still have some improvement to go are actually quite a good idea, and the updates are improving it well. Anything that adds security built-in is good imo.
On the non privacy side the three big ones for me are Picture in Picture, widgets, and the banner option for phone calls. Long awaited it seems.
Is anyone else running the beta?
