I recently moved house & decided that it was time for a good solid desk after many flimsy Ikea styled ones over the years. I considered buying one, but then thought, why not build one to suit my needs exactly.
I started a few days ago & this is my progress so far.
I wanted plenty of room, as my previous desks have always felt cluttered. This one measures 1800x920mm. (6ft x 3ft).
I plan to move my gaming rig into the desk in a few months once I collect the various parts I still need to change it over to water cooling.
updated System is now running, these are the specs: AS Rock Z170 extreme 7+ Motherboard Intel 6700K, currently @ 4.6, just using the auto OC feature in the bios. EK Supremacy waterblock fitted. 16GB 2666 Hyper X savage DDR4 2 x Gigabyte G1 Gaming 980 Ti- with EK full water blocks Samsung 850 EVO 1TB SSD & 256GB 950 NVME EK Xres 140 pump/res combo EK 540mm Radiator with 3 180mm fans Case fans are BeQuiet! 140mm Pure wings (4 of those) There is also a Noctua 120mm fan under the motherboard to add some ventilation there. PSU EVGA P2 1200w Monitor is the Asus PB279Q 27" 4K 60hz Razer Deathstalker keyboard & Naga mouse
Oh I'm definitely following this. I assume you are going to turn the cabinet part on the left side of the desk into the actual PC case itself? Are you going to put some glass over that top part so we can see the rig in action?
I went with the standard desk height of 700mm (27"). I did consider making it adjustable, but thought I'd keep it simple for the first time.
I used to work with a guy who has a shed full of Mackay Cedar, his father used to make furniture from it, but the dust from it killed him, nasty stuff when it's in your lungs apparently.
Really? I've never heard of cedar being specifically more or less harmful than any other form of wood dust. I know you probably shouldn't breath it in. Although I am a smoker so I probably have no room to talk lol
Is that cabinet going to be the actual case, or simply contain the case?
The top fans are just for air flow for anything not water cooled. The rads I was thinking can go in the bottom section, I have plenty of room there, so probably a couple of 480s.
I prefer the look of hard tubing, so will give that a go.
I'm trying to keep the top clutter free, but would like to try & do something creative with the reservoir. I'll see what my options are once it starts taking shape.
The 'Mackay Cedar' in Australia has a pretty toxic sawdust if inhaled into the lungs, many woodturners / woodworkers will wear a specially filtered respirator when machining Mackay Cedar.
Mackay Cedar is a rainforest timber, but when sanded, and polished it possesses a 'silky' finish, and is prized by many woodworkers in spite of its toxic sawdust.
