Do you live near a micro center because they have some very good deals on cpu motherboard combos
I have zero preference in CPUs.
I use what's available.
That's kinda how I've been my whole life, but I think this e3-1231v3 Might just do the trick.
I don't, the nearest computer store is 3 hours away
hey remeber that you dont need z97 with a xeon since you cant overcloxk xeons. h97 is usually cheaper
id go with the 8250 You'd get the most out of it for less. Also, switching to intel would mean you have to buy a new motherboard and reinstall your OS.
My 8350 took me pretty far too. And a lot of games are being optimized for more cores. You don't have to sweat about per-core performance considering they're spreading the load to multiple threads, so they're each gonna have a lighter load.
he stated in his original post that his motherboard is dead as well so he would need to buy a new motherboard ether way
My bad, I just skimmed the op. Shoot, id go ahead and get an i5.
An i7 if he wants to be able to use 8 threads at once
