I already talked about this a little over on another topic, but it is off topic.
I have files on my NTFS drive and these I want to transfer to another drive because I should use Linux and that supposedly hasn’t good enough support for NTFS.
I have an already formatted XFS HDD where all the files fit in.
The files that I already moved have a newer creation date than modified date. In Linux it shows creation date as “unknown” in the NTFS drive.
I want to preserve all meta data as it would be easier to find files. When sorting by age.
I have an M.2 usb adapter but the Windows bootloader isn’t recognized for some reason (using back panel and USB3 cable). I also have a SATA adapter to USB.
On your Arch Linux system do sudo pacman -S ntfs-3g to have decent ntfs support. It won’t be perfect, but it will work. As far as I know, the birth time is filesystem specific, so when copying the files to XFS they technically have a new birth time.
If you were using btrfs, I would have suggested ntfs2btrfs.
I did it here
Otherwise follow what Adubs suggested with rsync
Having gone through this process, I’d highly recommend you get a second storage drive and have rescuezilla create a copy of your data so that you have any data loss
GNU cp has an -a archive flag too to “preserve attributes”. Rsync is fancier though. And you’d want proper handling for symbolic and hard links inside the target file system and I bet rsync is the only one that may have an option for this.
