Howdy !
So, i know i'm not an active member of the community, but i just give up to try to solve my problem alone.
I have a desktop computer in a very bad shape. I build it at a time where money felt endless, and now i can't get it up to date, or solve some overheating issue.
And before i get a "Switch to Linux", i have a couple of server and desktop on linux, but this is the big one, and i need it to play/VR/Adobe video editor.
So here is my probleme, pretty randomly, i will get a BSOD with a "random" error (it's not always the same) and the computer will reboot. This have start a couple month ago. i was looking for the cause of most of this, and usually fall on driver issue. I start to uninstall driver after driver, removing devices after devices while never getting result. I try the driver check utility in windows, but it was crashing the computer at initialization. Finally, Yesterday i give up and start a full, and clean installation. I've only install the basic driver and still haven't finish to get it as i like, but i got a BOSD, same kind of error.
If any of you is really good with windows ( and i'm sure they are in this community ) and have time to help someone who wish to throw is computer by the windows, please do !
I leave you with the last BSOD log and the config. Thank you a lot !
System Information (local)
Computer name: TESLA
Windows version: Windows 8.1 , 6.3, build: 9600
Windows dir: C:\Windows
Hardware: ASUSTeK COMPUTER INC., RAMPAGE IV EXTREME
CPU: GenuineIntel Intel(R) Core(TM) i7-3970X CPU @ 3.50GHz Intel586, level: 6
12 logical processors, active mask: 4095
RAM: 17114972160 bytes total
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 26/08/2016 12:03:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082616-8218-01.dmp
This was probably caused by the following module: tcpip.sys (tcpip+0x6C935)
Bugcheck code: 0x1E (0xFFFFFFFFC000001D, 0xFFFFF801D6089935, 0xFFFFD000204F1C68, 0xFFFFD000204F1470)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\drivers\tcpip.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote TCP/IP
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
On Fri 26/08/2016 09:44:31 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082616-9421-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14E2A0)
Bugcheck code: 0xA (0xFFFFE018588668B0, 0x2, 0x1, 0xFFFFF8037D8F83C3)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Thu 25/08/2016 19:22:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082516-8375-01.dmp
Bugcheck code: 0x109 (0xA3A01F591737960C, 0xB3B72BDF69B4D85F, 0xFFFFF801B320C952, 0x1)
Error: CRITICAL_STRUCTURE_CORRUPTION
Bug check description: This indicates that the kernel has detected critical kernel code or data corruption.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Thu 25/08/2016 18:15:50 GMT your computer crashed
crash dump file: C:\Windows\Minidump\082516-11343-01.dmp
Bugcheck code: 0xD1 (0xFFFFF80214E0C982, 0x2, 0x8, 0xFFFFF80214E0C982)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
Computer setup
16Gb of corsair DDR3 4X4G
i7-3970X a 4.3 ghz
GTX 780 EVGA hydroCopper
GTX 590 with a waterblock but unplug and pci-e disable with a dip-switch (to much heat)
RaidR SSD 240g (OS) UEFI (Marvell raid 0 of the 2 internal 120g ssd)
WD Velociraptor 1TB (Data) Plugged on the direct sata port (no controller)
Xonar DSX
Rampage 4 EXTREME
Corsair AX860 power supply
3 1080p screen (2 DVI+ 1 DP)
USB Device
Corsair K70 Black
logitech G502
HTC vive
Tritton Pro+ Headset (i know but i can't leave without the separated vocal chat thing)
Hercules Camera
Aquastream Pump Ultra
Nvidia stereo controller.
EDIT :
26/08 I've run Smart and memtest86 without any error. i'v run chkdsk /F and sfc without any error
