Headless Duplicati on CentOS (Guide)
This is more or less split from:
My Use Case
I have a CentOS VM that mounts my entire NAS over NFS (read-only) so that it can back it up to various places in various ways. I’m using Duplicati for encrypted, incremental backups to Google Drive. When I set it up, I found the documentation for a headless CentOS install was kind of scattered. As a result, I figured it might be useful to consolidate it here.
Commands
This should work on a vanilla CentOS install (run as root or use sudo).
yum install yum-utils
rpm --import "http://keyserver.ubuntu.com/pks/lookup?op=get&search=0x3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF"
yum-config-manager --add-repo http://download.mono-project.com/repo/centos7/
yum install mono-devel
yum install epel-release
yum install libappindicator
curl -O https://updates.duplicati.com/beta/duplicati-2.0.3.3-2.0.3.3_beta_20180402.noarch.rpm #get updated link from https://www.duplicati.com/download
yum install duplicati*
firewall-cmd --add-port=8200/tcp --permanent
firewall-cmd --reload
echo "[Unit]
Description=Duplicati Backup software
[Service]
ExecStart=/usr/bin/mono /usr/lib/duplicati/Duplicati.Server.exe --webservice-interface=any
Restart=on-failure
RestartSec=30
[Install]
WantedBy=multi-user.target" > /etc/systemd/system/duplicati.service
systemctl enable duplicati
systemctl start duplicati
Web GUI
From there, you can go to http://ipaddress:8200/ and configure your backups with the web gui. It’s pretty self-explanatory, but the official documentation is good from that point if you need help.
I didn’t run into any conflicts with SELinux, but as always, it could rear it’s ugly head if you’re backup up from somewhere it thinks should be protected.
That’s It!
I hope someone finds this useful! Any suggestions for additions/revisions are welcome.
Special thanks to @Ruffalo for turning me on to Duplicati.
If you do run a GUI, you will want to run with “–no-hosted-server --server-url=http://localhost:8200” to get the trayicon. The way Duplicati does it by default is pretty stupid, with the GUI trayicon also running the server.
I suggest setting your upload volume size to at least 250MB just to limit the number of files. I use 500MB myself.
Also there are a number of settings you’ll need for email notifications.
send-mail-from (whatever you want)
send-mail-to (address to send to)
send-mail-username (a Gmail username, not necessarily your main one)
send-mail-password (Gmail application password if you have 2FA setup)
send-mail-url (smtps://smtp.gmail.com for Gmail)
send-mail-level (All to test, then Warning,Error,Fatal)
Are those mail settings also just tagged onto the executable?
ExecStart=/usr/bin/mono /usr/lib/duplicati/Duplicati.Server.exe [email protected]…
Seemed like everything was done that way and not through a config file.
No, you go to Settings, Add Advanced Setting and then select each one from the dropdown. It’s not the most elegant configuration ever.
Got it. Thanks for clarifying.
Thank you this helped me tremendously!
How is this not on the official website???
Again, great work, thank you :blush:
thanks so much, ¡you saved me!, really thanks
