Before we get into this, I just want to point credit where credit is due, so first off, I would like to thank @wendell because, without his Guide and Video, I wouldn’t have even know this was possible, and I would have just spend over $600 CAD on new NVMe’s for no reason if I wasn’t able to get this working. (I guess it pays to do your research before buying hardware)
Next I would like to thank the people on /r/linuxquestions and /r/pop_os who were helping me out though this entire process start to finish.
We can’t forget about jdfthetech from the LTT Forums who also just happened to be up all night and was able to give me some tips that got me back on track.
And Finally, I want to thank everyone who contributes to the ArchWiki, without that place, I would have been absolutely lost and would have switched back to Windows
Now, onto the Guide.
First, you want to make a Pop_OS! 20.04 USB Installer
Once that’s done, we want to configure your BIOS for a Linux install, if you haven’t already.
Change OS option if you have it to “other OS”
Make sure SATA Mode is AHCI (it will not work otherwise)
Disable Fastboot
Save and Restart
Boot to your POP_OS! 20.04 USB
Once booted in the Pop_OS! USB
Setup language, keyboard, and do not continue any further once it asks how to install.
open terminal and let’s elevate as root
sudo -i
Now check your devices to see which drives you’re using.
lsblk
Write down the device names that you want for your RAID (you will need these a lot)
sudo gdisk /dev/DEVICE_NAME
First Drive
You want this one to be your EFI partition and your for the RAID capacity
So for the EFI partition, enter as followed as it asks
n
enter
enter
1024M
ef00
Next create the EXT4 Partition that will be used for the RAID
n
enter
enter
enter
8300
Write the changes
w
y
Check for EFI Partition
lsblk
Format the EFI you just created from FAT16 to FAT32 (@jdfthetech Edit)
mkfs.fat -F 32 /dev/YOUR_DEVICE_PARTITION
Continue partitioning every other drive as follows
sudo gdisk /dev/EVERY_OTHER_DEVICE
Make the Boot Partition on every drive
n
enter
enter
1024M
8300
Make the rest of the drive capacity the EXT4 partition for your RAID
n
enter
enter
enter
8300
Write the changes
w
y
Continue until all drives you want in your RAID are partitioned.
Now we can make the RAID (0/1/5/6/10)
X = RAID level
Y = Number of drives total for the RAID
mdadm --create /dev/md0 --verbose --level=X --raid-devices=Y /dev/YOUR_DEVICE_1_EXT4_PARTITION_2 /dev/YOUR_DEVICE_2_EXT4_PARTITION_2
Make note that you are adding the SECOND PARTITION of each drive for the RAID, not the devices itself, make sure to add the partition at the end and then continue adding to the end of that command for total number of every drive you’re using in your RAID
Check RAID status
cat /proc/mdstat
If you selected anything other than RAID0, it will take awhile to build the volume.
Keep checking with “cat /proc/mdstat” until it’s done
Once Completed, we can now create the partitions needed on the RAID
sudo gdisk /dev/md0
We want to make a swap partition as our first partition on the new RAID volume, now keep in mind these don’t need to be exact, but it’s in good practice to stay with the rule of thumb for capacity needed to how much RAM you have
I’m going to start this list off at 8GB of RAM, because if you have less than 8GB, you should probably be upgrading your RAM and not making a RAID boot setup lol
First Number is how much RAM you HAVE, Second number is how much CAPACITY that the SWAP should be
8GB - 3GB
12GB - 3GB
16GB - 4GB
24GB - 5GB
32GB - 6GB
64GB - 8GB
128GB - 11GB
For me, I have 32GB of RAM, 1GB is 1024MB, I need a 6GB SWAP, 1024 x 6, is 6144MB, so I’m going to be entering 6144MB, change your value to meet your specs
n
enter
enter
6144M
8200
Now partition the rest of the RAID
n
enter
enter
enter
8300
Write the changes
w
y
Now we can finally move to Pop_OS Installer and configure the partitions.
Select Custom Install
Select the EFI partition on FIRST drive by device number, they don’t always appear in order
Select /boot/efi
Make sure the format is fat32
Select the BOOT partition that you made on the SECOND drive by device number, it’s not always the second drive in the list)
(sometimes won’t be listed in order, check device number)
Select Custom
input into the box /boot
Make sure the format is set to EXT4
Select the SMALL partition on the RAID array
Select SWAP
Select the LARGE partition on the RAID Array
Select / (for Root)
Make sure the format is EXT4
You may be able to use other formats, I have not tried and can not guarantee if it will work using this process.
Now you can finally select the orange button at the bottom right and Install Pop_OS! (sometimes it will fail at the end, just ignore this)
Once completed (or failed), go back into terminal and we need to mount the RAID
mount /dev/md0p2 /mnt
Mount the Boot Partition
mount /dev/YOUR_SECOND_DEVICE_BOOT_PARTITION /boot
Mount the EFI partition
mount /dev/YOUR_FIRST_DEVICE_EFI_PARTITION /boot/efi
Change the directory now to the RAID
cd /mnt
Now we can install mdadm on the RAID (may already be installed, but try anyway)
mount --bind /dev dev
mount --bind /proc proc
mount --bind /sys sys
chroot .
apt install mdadm
Now check mdadm configuration to make sure the RAID UUID is there
/cat /etc/mdadm/mdadm.conf
If it is not there, check the UUID manually
mdadm --detail /dev/md0
Copy the UUID and now we can edit the mdadm.conf
nano /etc/mdadm/mdadm.conf
Under where it says “# definitions of existing MD arrays”
Type in and paste your UUID
ARRAY /dev/md/0 metadata=1.2 UUID=YOUR_RAID_UUID name=pop-os:0
CTRL X to Save
Y
Enter
Now we need to update your changes
update-initramfs -u
Make sure it scans the changes
mdadm --detail --scan >>/etc/mdadm/mdadm
Tell the system it needs to boot the RAID (change the X to the level of RAID you are using)
echo raidX >> /etc/modules
Now just make sure the /boot and /boot/efi partitions are still mounted, mine unmounted at this point for some reason
lsblk
if you do not see anything that says /boot or /boot/efi, you need to remount them.
Remount the Boot Partition
sudo mount /dev/YOUR_SECOND_DEVICE_BOOT_PARTITION /boot
Remount the EFI partition
sudo mount /dev/YOUR_FIRST_DEVICE_EFI_PARTITION /boot/efi
With /boot and /boot/efi remounted, we can finish it off
lsinitramfs /boot/initrd.img |grep mdadm
You need internet for this last step, so connect Wifi if you’re not using Ethernet, and you should try to install grub2 in case it failed to install during the Pop_OS! Install.
So the last step here is to install grub, and then update grub, even if it shows issues, it should be fine as the other files will be there from the Pop_OS! Installer
apt install grub2-common -y
(you may get an error, ignore this)
update-grub2
Exit chroot by typing in
exit
Exit root by typing in
exit
Now reboot the computer
poweroff --reboot
Everything should go fine and you should now be booting into a clean install of Pop_OS! 20.04 on your new RAID Array operating just like a normal install.
From this point on, you just need to remember to never touch the drives separately, if you ever have to enter commands and it’s telling you to direct toward your boot drive, this will always be /dev/md0 (or whatever you called your RAID array), never use the devicenames we were using earlier to create the raid, if anything on those changes, it could corrupt the entire RAID resulting in full data loss.
I hope this helps anyone who wants to setup RAID0 for a blazing fast boot drive to get the most FPS possible, or a safe and secure RAID1 for those with your mission critical files, or even a RAID5/6/10 for those who wanted a little of both.
I started learning mdadm straight out of windows with very little Linux Knowledge at 6pm April 24th, it’s now 6am April 26th. It has been 36 hours straight, and I slept at my desk for 4 hours, no one has any excuse for not being able to learn something new.
It’s time I get some much needed sleep.
