Hi all,
i bought a 2 port kvm switch from the store and it worked well with my logitech setup but after switching to Glorious GMMK2 96% and a Model I i get Problems.
When i plug the keyboard into usb3 ports everything works like a charm. But when using the hid labeled ports it works most oft the times only for a few seconds. After that no keys are recognized anymore. When i unplug it and replug it it is most of the time working again for a few seconds. When i‘m lucky it remains stable even on a hdi port but as soon as i switch inputs it brakes again.
I have the two on one dp1.4 version with 5gbps and connected are a mac and a windows pc.
Is there a way to get it running because i would like to hide the switch below the desk but therefore switching input via keyboard has to work.
Edit: a further problem not sure if it is related. When the computer is shutdown the rgb backlight on the keyboard stays on when using a hid port. When using the usb3 port the rgb backlight goes off as desired.
