Gigabyte X570 Aorus Elite IOMMU groups?
Thanks. Also noooooooo emoji. Hmm. Frustrating.
Also do you have an SSD? Nvme? If so is trim working?
Im using a samsung 850evo sata ssd for my Manjaro boot drive and a samsung 960evo nvme for windows. The nvme controller is passed through to windows10.
I’m not sure if you ment in the vm or on the host so: Samsung Magician on windows atleast says trim is enabled. On Manjaro running fstrim works which is also on a weekly timer.
Why do you ask?
I just updated my Aorus Elite bios from f4j to f4 and my iommu groups are now terrible, my USB card is no longer in a separate group. I have iommu, acs, and pcie ari all enabled, am I missing something?
Nope, it got worse. Suggest rolling back to abb agesa for now.
Missed your reply, sorry.
Iommu on nvme can bork trim but there’s a workaround.
That’s the weird thing the f4 version is abb but my iommu groups are worse than the f4j version.
Interesting, I would guess that they also changed something in the newer f4 bios. To specify in the threads above, when talking about f4, I was revering to f4j as this was the newest f4 bios at that time. I am still running on f4j. I suggest going back to f4j. ( If you need it i still have the f4j bios file. No guarantees).
If you could give me f4j version file that would be awesome as my backup of that version didn’t seem to work.
Took this from the usb which i used to update my bios so it should work. Again no guarantees but if i have no reason to think it wouldn’t work/brick your motherboard. X570AOEL.F4j.zip (9.3 MB)
Yep, the f4j version has way better iommu groups than the newer f4. All of my pcie devices are in their own groups, thanks again for the file.
Glad it worked. Lets pray for good separation in the next bios version.
I’m currently looking for a new board for a Ryzen 7 3700X. Because I would like to do virtualization with GPU passthrough in the future I’m currently looking for a mainboard with good IOMMU groups and Intel NIC. The Gigabyte Aorus Elite looks very promising for this.
I’m currently very new to the topic IOMMU groups. Is the GPU still in it’s own group or do I’ve to pass the whole PCIe Bus with different devices to the VM? Does anybody have a dump of the IOMMU groups with the new/old firmware to compare it with other boards?
Do you have any experience with gigabyte if they will fix the IOMMU groups with a future update? What is their update policy? I’ve had board which had a tons of issue but the vendor doesn’t release any fixes for this.
The GPU usually is in its own group, sometimes together with their onboard sound chip. You don’t need to pass through the whole bus, just the card + sound.
Got the Aorus Pro and not Elite, but you may find an example useful nonetheless (older firmware). Second GPU got the HDMI sound in another group which you have to pass through together:
IOMMU Group 18:
	03:00.0 VGA compatible controller [0300]: NVIDIA Corporation NV40 [GeForce 6800 GT/GTO/Ultra] [10de:00f9] (rev a2)
IOMMU Group 22:
	0a:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5700 / 5700 XT] [1002:731f] (rev c1)
IOMMU Group 23:
	0a:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
You can use this script to validate your IOMMU groups.
hardwareiommuids.sh.zip (316 Bytes)
Is there an advantage of the pro against the elite regarding IOMMU groups or is this nearly the same firmware? I don’t expect to overclock.
The Pro got two PCIe 16x slots with their lanes connected to the CPU instead of the Southbridge. Unfortunately I wasn’t able to find sufficient benchmark data back then to determine the possible performance increase in a VM passthrough scenario like this. If that isn’t a concern for you (remember that you can put the less powerful host GPU in the second slot anyway, so the guest GPU gets full performance) the Elite will probably be sufficient. :slight_smile:
Good news, bios f10a brings us the best iommu seperation I have seen on this board yet :O. Consider me happy. For some comparison:
f10a iommu's
IOMMU Group 0:
	00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 1:
	00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 10:
	00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 11:
	00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 12:
	00:08.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 13:
	00:08.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
IOMMU Group 14:
	00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 61)
	00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 15:
	00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0 [1022:1440]
	00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1 [1022:1441]
	00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2 [1022:1442]
	00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3 [1022:1443]
	00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4 [1022:1444]
	00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5 [1022:1445]
	00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6 [1022:1446]
	00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7 [1022:1447]
IOMMU Group 16:
	01:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a804]
IOMMU Group 17:
	02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57ad]
IOMMU Group 18:
	03:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 19:
	03:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 2:
	00:01.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 20:
	03:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a3]
IOMMU Group 21:
	03:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
	07:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
	07:00.1 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
	07:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 22:
	03:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
	08:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 23:
	03:0a.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:57a4]
	09:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 24:
	04:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM951/PM951 [144d:a802] (rev 01)
IOMMU Group 25:
	05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] [1002:67ef] (rev cf)
	05:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] [1002:aae0]
IOMMU Group 26:
	06:00.0 Ethernet controller [0200]: Intel Corporation I211 Gigabit Network Connection [8086:1539] (rev 03)
IOMMU Group 27:
	0a:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1478] (rev c1)
IOMMU Group 28:
	0b:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1479]
IOMMU Group 29:
	0c:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 [Radeon RX 5700 / 5700 XT] [1002:731f] (rev c1)
IOMMU Group 3:
	00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 30:
	0c:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
IOMMU Group 31:
	0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 32:
	0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
IOMMU Group 33:
	0e:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
IOMMU Group 34:
	0e:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
IOMMU Group 35:
	0e:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
IOMMU Group 36:
	0f:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 37:
	10:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 4:
	00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 5:
	00:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge [1022:1483]
IOMMU Group 6:
	00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 7:
	00:05.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 8:
	00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge [1022:1482]
IOMMU Group 9:
	00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B] [1022:1484]
f5b iommu's
IOMMU Group 0:
	05:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Cape Verde XT [Radeon HD 7770/8760 / R7 250X] [1002:683d]
	05:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] [1002:aab0]
IOMMU Group 1:
IOMMU Group 2:
	0a:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1070 Ti] [10de:1b82] (rev a1)
	0a:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
IOMMU Group 3:
IOMMU Group 4:
IOMMU Group 5:
	0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function [1022:148a]
IOMMU Group 6:
	0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP [1022:1485]
	0c:00.1 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP [1022:1486]
	0c:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller [1022:149c]
	0c:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
	0d:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
	0e:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 7:
IOMMU Group 8:
f4j iommu's
IOMMU Group 0:
IOMMU Group 1:
IOMMU Group 10:
IOMMU Group 11:
IOMMU Group 12:
IOMMU Group 13:
IOMMU Group 14:
IOMMU Group 15:
IOMMU Group 16:
IOMMU Group 17:
IOMMU Group 18:
IOMMU Group 19:
IOMMU Group 2:
IOMMU Group 20:
IOMMU Group 21:
IOMMU Group 22:
IOMMU Group 23:
IOMMU Group 3:
IOMMU Group 4:
IOMMU Group 5:
IOMMU Group 6:
IOMMU Group 7:
IOMMU Group 8:
IOMMU Group 9:
For completeness, to get these groups in the f10a bios I had to change these settings:
SVM -> Enable
iommu -> Enable
ACS Enable -> Enable
Enable AER cap -> Enable (this one is new)
Edit: f10c also confirmed to be good as far as iommu groups are concerned.
Thank you sooooooooooooooo much for the information !!
Guys i just registered to say thank you also for this info. I will follow this forum closely since i see very usefull info here and knowledge people.
Really thx for this info.
I forgot to mention that i have an X570 Pro with this cards on it.
HP P440 4GB FWBC (4x4TB Sas HDD+4x1TB Samsung SSD)
HP 560T SFP+ 2x10GB Fiber
HP 81Q 8Gb 1-port PCIe FC
And im waiting a IBM ServeRAID 16-Port 6Gbps SAS-2 SATA Expansion Adapter
As you understand this info here is damn helpfull.
Guys i want to tell something to all here.
In latest Gigabyte aorus bios there is a new setting that matters Iommu grouping and is called Alternating Routing.
Since i enabled it i have much better iommu grouping and i even managed to bypass things that exist in my 3nd PCIx16 and PCIx1 slots.
This is great addition really and i am damn happy in esxi.
