Gigabyte MW34SP0 Motherboard
It still seems that sometimes the BMC does not start (no activity on the Ethernet Port). In this case, also the board / BIOS does not start.
Seems to happen when the hardware configuration changes…
Will report back.
I wonder how many people are having problems, because I feel like we are the beta testers for this motherboard right now. It’s been released for over 3 months and still there are problems with it. I also have a Gigabyte X570 Aero that has been far from trouble free - is this par for the course for Gigabyte? I am also wondering if Wendell had problems with his…
I don’t want to be the guy that bitches and whines… but Gigabyte: Fix your sh…stuff!
@TOMO1982 It’s Intel not OEM(hp/dell/…)
Tried the smbus “hack” aswell, made no difference.
So, yep, the BMC/BIOS seems to get stuck after a hardware change. I need to keep the whole thing powered off for a while - some 10…15 minutes. Then it comes back to life…hm…
Other than that, it seems to boot up fine.
Edit:
I’m starting to feel better about the board. This issue with the NICs was really annoying.
Other than that, as long as you don’t change any hardware, things are ok.
I just booted FreeBSD off a USB stick and then rebooted straight back in Linux. No issues.
So, yes, the firmware seems a bit BETA, but once Linux is up and running, I had not problems, so far. I hammered it for a week with a lot of C++ compile sessions and a number of VM and containers incl. quite some PCI passthrough (no GFX - its a server :).
Regarding idle power consumption: This board + i12700 + 128GB ECC is in the same ball park as the old Haswell i4790S + 32GB on an ASUS Gamer Z97 baord. About 36W (primary on 230V) with one active hard disk and 10 NICs (no link execpt for one).
A small request, could someone try to boot FreeBSD 13-STABLE (use the memstick image and select LiveCD) and post dmesg?
http://ftp2.de.freebsd.org/pub/FreeBSD/snapshots/ISO-IMAGES/13.1/FreeBSD-13.1-STABLE-amd64-20230114-b83b87f53e73-253383-memstick.img.xz
I thought I wanted one of these boards but now I’m not sure. Are the issues only present when running 13th gen? For my use case I’m willing to go 12th gen.
No, also with 12th Gen unfortunately.
12th gen, here as well: i7-12700
Haven’t used FreeBSD in a while…let’s see.
It seems to boot ok.
CPU: 12th Gen Intel(R) Core(TM) i7-12700 (2112.00-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x90672  Family=0x6  Model=0x97  Stepping=2
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x121<LAHF,ABM,Prefetch>
  Structured Extended Features=0x239c27eb<FSGSBASE,TSCADJ,BMI1,AVX2,FDPEXC,SMEP,BMI2,ERMS,INVPCID,NFPUSG,RDSEED,ADX,SMAP,CLFLUSHOPT,CLWB,PROCTRACE,SHA>
  Structured Extended Features2=0x98c027bc<UMIP,PKU,OSPKE,WAITPKG,GFNI,VAES,VPCLMULQDQ,TME,RDPID,MOVDIRI,MOVDIR64B>
  Structured Extended Features3=0xfc1cc410<FSRM,MD_CLEAR,PCONFIG,IBT,IBPB,STIBP,L1DFL,ARCH_CAP,CORE_CAP,SSBD>
  XSAVE Features=0xf<XSAVEOPT,XSAVEC,XINUSE,XSAVES>
  IA32_ARCH_CAPS=0x88fd6b<RDCL_NO,IBRS_ALL,SKIP_L1DFL_VME,MDS_NO,TAA_NO>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID,VID,PostIntr
  TSC: P-state invariant, performance statistics
real memory  = 137434759168 (131068 MB)
avail memory = 133489844224 (127305 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <GBT    GBTUACPI>
FreeBSD/SMP: Multiprocessor System Detected: 20 CPUs
FreeBSD/SMP: Non-uniform topology
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
random: unblocking device.
ioapic0 <Version 2.0> irqs 0-119
Launching APs: 1 17 19 16 18 12 3 7 5 15 6 9 11 13 10 8 4 14 2
random: entropy device external interface
kbd0 at kbdmux0
efirtc0: <EFI Realtime Clock>
efirtc0: registered as a time-of-day clock, resolution 1.000000s
smbios0: <System Management BIOS> at iomem 0x43c0d000-0x43c0d01e
smbios0: Version: 3.4, BCD Revision: 3.4
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS,SHA1,SHA256>
acpi0: <GBT GBTUACPI>
acpi0: Power Button (fixed)
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 19200000 Hz quality 950
Event timer "HPET" frequency 19200000 Hz quality 350
Event timer "HPET1" frequency 19200000 Hz quality 340
Event timer "HPET2" frequency 19200000 Hz quality 340
Event timer "HPET3" frequency 19200000 Hz quality 340
Event timer "HPET4" frequency 19200000 Hz quality 340
Event timer "HPET5" frequency 19200000 Hz quality 340
Event timer "HPET6" frequency 19200000 Hz quality 340
Event timer "HPET7" frequency 19200000 Hz quality 340
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
apei0: <ACPI Platform Error Interface> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
igb0: <Intel(R) I350 (Copper)> mem 0x52b00000-0x52bfffff,0x52e0c000-0x52e0ffff at device 0.0 on pci1
igb0: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb0: Using 1024 TX descriptors and 1024 RX descriptors
igb0: Using 8 RX queues 8 TX queues
igb0: Using MSI-X interrupts with 9 vectors
igb0: Ethernet address: a0:36:9f:11:4e:14
igb0: netmap queues/slots: TX 8/1024, RX 8/1024
igb1: <Intel(R) I350 (Copper)> mem 0x52a00000-0x52afffff,0x52e08000-0x52e0bfff at device 0.1 on pci1
igb1: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb1: Using 1024 TX descriptors and 1024 RX descriptors
igb1: Using 8 RX queues 8 TX queues
igb1: Using MSI-X interrupts with 9 vectors
igb1: Ethernet address: a0:36:9f:11:4e:15
igb1: netmap queues/slots: TX 8/1024, RX 8/1024
igb2: <Intel(R) I350 (Copper)> mem 0x52900000-0x529fffff,0x52e04000-0x52e07fff at device 0.2 on pci1
igb2: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb2: Using 1024 TX descriptors and 1024 RX descriptors
igb2: Using 8 RX queues 8 TX queues
igb2: Using MSI-X interrupts with 9 vectors
igb2: Ethernet address: a0:36:9f:11:4e:16
igb2: netmap queues/slots: TX 8/1024, RX 8/1024
igb3: <Intel(R) I350 (Copper)> mem 0x52800000-0x528fffff,0x52e00000-0x52e03fff at device 0.3 on pci1
igb3: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb3: Using 1024 TX descriptors and 1024 RX descriptors
igb3: Using 8 RX queues 8 TX queues
igb3: Using MSI-X interrupts with 9 vectors
igb3: Ethernet address: a0:36:9f:11:4e:17
igb3: netmap queues/slots: TX 8/1024, RX 8/1024
pcib2: <ACPI PCI-PCI bridge> at device 1.1 on pci0
pci2: <ACPI PCI bus> on pcib2
igb4: <Intel(R) I350 (Copper)> mem 0x52400000-0x524fffff,0x5270c000-0x5270ffff at device 0.0 on pci2
igb4: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb4: Using 1024 TX descriptors and 1024 RX descriptors
igb4: Using 8 RX queues 8 TX queues
igb4: Using MSI-X interrupts with 9 vectors
igb4: Ethernet address: a0:36:9f:1d:21:80
igb4: netmap queues/slots: TX 8/1024, RX 8/1024
igb5: <Intel(R) I350 (Copper)> mem 0x52300000-0x523fffff,0x52708000-0x5270bfff at device 0.1 on pci2
igb5: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb5: Using 1024 TX descriptors and 1024 RX descriptors
igb5: Using 8 RX queues 8 TX queues
igb5: Using MSI-X interrupts with 9 vectors
igb5: Ethernet address: a0:36:9f:1d:21:81
igb5: netmap queues/slots: TX 8/1024, RX 8/1024
igb6: <Intel(R) I350 (Copper)> mem 0x52200000-0x522fffff,0x52704000-0x52707fff at device 0.2 on pci2
igb6: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb6: Using 1024 TX descriptors and 1024 RX descriptors
igb6: Using 8 RX queues 8 TX queues
igb6: Using MSI-X interrupts with 9 vectors
igb6: Ethernet address: a0:36:9f:1d:21:82
igb6: netmap queues/slots: TX 8/1024, RX 8/1024
igb7: <Intel(R) I350 (Copper)> mem 0x52100000-0x521fffff,0x52700000-0x52703fff at device 0.3 on pci2
igb7: EEPROM V1.67-0 Option ROM V20-b5-p13 eTrack 0x80001109
igb7: Using 1024 TX descriptors and 1024 RX descriptors
igb7: Using 8 RX queues 8 TX queues
igb7: Using MSI-X interrupts with 9 vectors
igb7: Ethernet address: a0:36:9f:1d:21:83
igb7: netmap queues/slots: TX 8/1024, RX 8/1024
vgapci0: <VGA-compatible display> port 0x4000-0x403f mem 0x6000000000-0x6000ffffff,0x4000000000-0x400fffffff at device 2.0 on pci0
vgapci0: Boot video device
xhci0: <Intel Alder Lake USB 3.2 controller> mem 0x6001120000-0x600112ffff at device 20.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
pci0: <memory, RAM> at device 20.2 (no driver attached)
pci0: <serial bus> at device 21.0 (no driver attached)
pci0: <simple comms> at device 22.0 (no driver attached)
ahci0: <Intel Alder Lake AHCI SATA controller> port 0x4090-0x4097,0x4080-0x4083,0x4060-0x407f mem 0x53500000-0x53501fff,0x53503000-0x535030ff,0x53502000-0x535027ff at device 23.0 on pci0
ahci0: AHCI v1.31 with 8 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich6: <AHCI channel> at channel 6 on ahci0
ahcich7: <AHCI channel> at channel 7 on ahci0
ahciem0: <AHCI enclosure management bridge> on ahci0
pcib3: <ACPI PCI-PCI bridge> at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
igc0: <Intel(R) Ethernet Controller I225-V> mem 0x53300000-0x533fffff,0x53400000-0x53403fff at device 0.0 on pci3
igc0: Using 1024 TX descriptors and 1024 RX descriptors
igc0: Using 4 RX queues 4 TX queues
igc0: Using MSI-X interrupts with 5 vectors
igc0: Ethernet address: 74:56:3c:0f:00:5e
igc0: netmap queues/slots: TX 4/1024, RX 4/1024
pcib4: <ACPI PCI-PCI bridge> at device 28.6 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> at device 0.0 on pci4
pci5: <ACPI PCI bus> on pcib5
vgapci1: <VGA-compatible display> port 0x3000-0x307f mem 0x51000000-0x51ffffff,0x52000000-0x5203ffff at device 0.0 on pci5
pcib6: <ACPI PCI-PCI bridge> at device 29.0 on pci0
pci6: <ACPI PCI bus> on pcib6
igc1: <Intel(R) Ethernet Controller I225-V> mem 0x53000000-0x530fffff,0x53100000-0x53103fff at device 0.0 on pci6
igc1: Using 1024 TX descriptors and 1024 RX descriptors
igc1: Using 4 RX queues 4 TX queues
igc1: Using MSI-X interrupts with 5 vectors
igc1: Ethernet address: 88:c9:b3:bf:70:cb
igc1: netmap queues/slots: TX 4/1024, RX 4/1024
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
hdac0: <Intel Alder Lake HDA Controller> mem 0x6001138000-0x600113bfff,0x6001000000-0x60010fffff at device 31.3 on pci0
pci0: <serial bus> at device 31.5 (no driver attached)
acpi_button0: <Sleep Button> on acpi0
cpu0: <ACPI CPU> on acpi0
acpi_button1: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
acpi_syscontainer0: <System Container> on acpi0
acpi_syscontainer1: <System Container> on acpi0
atrtc0: <AT realtime clock> at port 0x70 irq 8 on isa0
atrtc0: Warning: Couldn't map I/O.
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
atrtc0: non-PNP ISA device will be removed from GENERIC in FreeBSD 14.
hwpstate_intel0: <Intel Speed Shift> on cpu0
hwpstate_intel1: <Intel Speed Shift> on cpu1
hwpstate_intel2: <Intel Speed Shift> on cpu2
hwpstate_intel3: <Intel Speed Shift> on cpu3
hwpstate_intel4: <Intel Speed Shift> on cpu4
hwpstate_intel5: <Intel Speed Shift> on cpu5
hwpstate_intel6: <Intel Speed Shift> on cpu6
hwpstate_intel7: <Intel Speed Shift> on cpu7
hwpstate_intel8: <Intel Speed Shift> on cpu8
hwpstate_intel9: <Intel Speed Shift> on cpu9
hwpstate_intel10: <Intel Speed Shift> on cpu10
hwpstate_intel11: <Intel Speed Shift> on cpu11
hwpstate_intel12: <Intel Speed Shift> on cpu12
hwpstate_intel13: <Intel Speed Shift> on cpu13
hwpstate_intel14: <Intel Speed Shift> on cpu14
hwpstate_intel15: <Intel Speed Shift> on cpu15
hwpstate_intel16: <Intel Speed Shift> on cpu16
hwpstate_intel17: <Intel Speed Shift> on cpu17
hwpstate_intel18: <Intel Speed Shift> on cpu18
hwpstate_intel19: <Intel Speed Shift> on cpu19
Timecounter "TSC" frequency 2111989039 Hz quality 1000
Timecounters tick every 1.000 msec
hdacc0: <Realtek ALC897 HDA CODEC> at cad 0 on hdac0
hdaa0: <Realtek ALC897 Audio Function Group> at nid 1 on hdacc0
pcm0: <Realtek ALC897 (Rear Analog)> at nid 20 and 24,26 on hdaa0
pcm1: <Realtek ALC897 (Front Analog)> at nid 27 and 25 on hdaa0
Trying to mount root from ufs:/dev/ufs/FreeBSD_Install [ro,noatime]...
ugen0.1: <Intel XHCI root HUB> at usbus0
uhub0 on usbus0
uhub0: <Intel XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
ses0 at ahciem0 bus 0 scbus8 target 0 lun 0
ses0: <AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses0: SEMB SES Device
ada0 at ahcich4 bus 0 scbus4 target 0 lun 0
ada0: <WDC WD7500AACS-00D6B0 01.01A01> ATA8-ACS SATA 2.x device
ada0: Serial Number WD-WCAU41638184
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 715404MB (1465149168 512 byte sectors)
ada1 at ahcich5 bus 0 scbus5 target 0 lun 0
ada1: <WDC WD8002FRYZ-01FF2B0 01.01H01> ACS-2 ATA SATA 3.x device
ada1: Serial Number VK0PH5ZY
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 7630885MB (15628053168 512 byte sectors)
ses0: pass0,ada0 in 'Slot 04', SATA Slot: scbus4 target 0
ada2 at ahcich6 bus 0 scbus6 target 0 lun 0
ada2: <WDC WD8002FRYZ-01FF2B0 01.01H01> ACS-2 ATA SATA 3.x device
ada2: Serial Number VK0PJ9LY
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 7630885MB (15628053168 512 byte sectors)
ses0: pass1,ada1 in 'Slot 05', SATA Slot: scbus5 target 0
ada3 at ahcich7 bus 0 scbus7 target 0 lun 0
ada3: <WDC WD8002FRYZ-01FF2B0 01.01H01> ACS-2 ATA SATA 3.x device
ada3: Serial Number VK0PLT7Y
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 7630885MB (15628053168 512 byte sectors)
ses0: pass2,ada2 in 'Slot 06', SATA Slot: scbus6 target 0
ses0: pass3,ada3 in 'Slot 07', SATA Slot: scbus7 target 0
uhub0: 24 ports with 24 removable, self powered
Root mount waiting for: usbus0
usb_msc_auto_quirk: UQ_MSC_NO_GETMAXLUN set for USB mass storage device SanDisk Cruzer Fit (0x0781:0x5571)
usb_msc_auto_quirk: UQ_MSC_NO_PREVENT_ALLOW set for USB mass storage device SanDisk Cruzer Fit (0x0781:0x5571)
usb_msc_auto_quirk: UQ_MSC_NO_SYNC_CACHE set for USB mass storage device SanDisk Cruzer Fit (0x0781:0x5571)
ugen0.2: <SanDisk Cruzer Fit> at usbus0
umass0 on uhub0
umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.00, addr 1> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0xc100
umass0:9:0: Attached to scbus9
da0 at umass-sim0 bus 0 scbus9 target 0 lun 0
da0: <SanDisk' Cruzer Fit 1.00> Removable Direct Access SPC-4 SCSI device
da0: Serial Number 4C530000241006115284
da0: 40.000MB/s transfers
da0: 29340MB (60088320 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
ugen0.3: <vendor 0x046a product 0x0023> at usbus0
ukbd0 on uhub0
ukbd0: <vendor 0x046a product 0x0023, class 0/0, rev 2.00/2.20, addr 2> on usbus0
kbd1 at ukbd0
ig4iic0: <Intel Alder Lake-S I2C Controller-0> at device 21.0 on pci0
ig4iic0: Using MSI
iicbus0: <Philips I2C bus (ACPI-hinted)> on ig4iic0
ichsmb0: <Intel Alder Lake SMBus controller> port 0xefa0-0xefbf mem 0x6001140000-0x60011400ff at device 31.4 on pci0
smbus0: <System Management Bus> on ichsmb0
acpi_wmi0: <ACPI-WMI mapping> on acpi0
acpi_wmi0: cannot find EC device
acpi_wmi0: Embedded MOF found
ACPI: \134_SB.WFDE.WQCC: 1 arguments were passed to a non-method ACPI object (Buffer) (20201113/nsarguments-361)
acpi_wmi1: <ACPI-WMI mapping> on acpi0
acpi_wmi1: cannot find EC device
acpi_wmi1: Embedded MOF found
ACPI: \134_SB.WFTE.WQCC: 1 arguments were passed to a non-method ACPI object (Buffer) (20201113/nsarguments-361)
lo0: link state changed to UP
igc0: link state changed to UP
debugnet_any_ifnet_update: Bad dn_init result from igc0 (ifp 0xfffff80106d7b000), ignoring.
uhid0 on uhub0
uhid0: <vendor 0x046a product 0x0023, class 0/0, rev 2.00/2.20, addr 2> on usbus0
 or paste code here
Well shucks. I really want a board that I can use desktop cpu, ECC memory and IPMI. I’m building a new truenas box and really only want to 2-3 jails with 1-2 users at a time. Epyc is overkill and I was hoping desktop to save on the power since I don’t really need cast off enterprise.
Well the board works fine aslong as you use nic’s from QVL list apparently and disable PXE boot in BIOS… I do not experience 10-15 min wait times mtk do.
Running i5 12500 cpu myself and crucial memsticks which is not on the QVL.
crucial memstick’s i run are MTA18ASF4G72AZ-3G2R
Can I ask how long does everyone have to wait for the BMC to come online after connecting the power?
Haven’t timed it.
But maybe 3-5min… Just assuming it’s doing hardware checks.
Also if fans do not spin down and then up and then down, you know you have to toggle power. For me atleast.
For me it was like 1-2 minutes, if it’s not dead again.
That sounds pretty much like what I was looking at. I cant find the board for purchase inside the US though. I’ve almost talked myself into just going epyc again. I have the funds but didn’t want to spend it their. If I could save money going desktop cpu Im game.
Two days ago our RMA / replacement board finally arrived after two weeks.
Just connected power and ethernet, BMC started up fine, got an IP(v4) address. Updating the firmware update in the browser was easy. Installed the i5 13600k as well as 64 gigs of Kingston RAM (same as @mtk). Installed everything else and it was working as expected.
After some hassle with the operating system and finding out the iGPU of 13th gen is not supported (although it’s the same as 12th gen?) switched to a 12600k instead.
By this point I was quite happy, although the fan control is kinda… well it s***s for a workstation. The only available temp sensor is the cpu, so basically no way to control the system fans.
After initial setup was done I moved the system to it’s rack and well… It’s dead again.
I plugged everything in, no changes exept a new USB device at the front. The system started up but I could not screw it into the rack yet, so I pressed the power button and the system went down.
Some minutes later I unplugged the system and put it on top of the rack. Plugged everything back in, it tried to start up (BIOS set to start after power failure) but now it’s dead again. The BMC LED is blinking in 5 second intervals just like with the old board.
It really looks like plugging the power too early after power down (maybe under 15 minutes?) will kill the BMC.
Can I ask what company you bought or got the RMA from?
What OS doesn’t support the 13th Gen iGPU?
This was my experience and I am hoping they finally fix this (assuming it can be fixed with an update). I am still waiting for my RMA to arrive, Mindfactory.de says it should be in stock on th 24th, so hopefully I get it before next weekend…
Can you remember what exactly you did when clearing the cmos when it worked?
I unplugged the system over night and tried booting this morning without success.
Unplugged it again, waited some time and set the cmos jumper. Set it back after about 15 minutes later and plugged the system back in. Still the same. I’m really curious what the dealer will tell me this time, after we had to wait two weeks for the replacement last time.
The dealer is Jacob.
We decided to go with Truenas Scale since it seemed to tick most of the boxes. But as it turns out there’s some details, especially hardware support.
At this point I’d go with about any other recent board, but unfortunately ddr 4 ecc support seems to be very limited and we have no other use for the sticks.
I would reconnect the power, the mobo would switch on and I would see the BMC ready LED flash on and off (5 seconds each) and the orange light on the MAN port wasn’t on and I would just move the CMOS reset jumper to the reset position - it would instantly power off and when the jumper is removed from the reset position it would power on and then it would work.
Truenas Scale is what I wanted to use :roll_eyes:
@happyone - did you try this for 13th Gen iGPU problem?
