Fx-8350 + R9 290x
If I waited a few months and ordered the 290x, would my FX-8350 bottleneck it? If so should I just go with the 280x?
I'm using a 7850 as of now and really want to get a good card this time around.
no it will not bottleneck at all ☺
Games that only take advantage of 1-3 threads, yes, definitely, the likes of BF4 which take advantages of 6-8 threads it'll be fine. You didn't state if you're running it OC'd or stock, though..
It is at a stable oc of 4.6 Ghz
Why would a FX8350 bottleneck a R9-290X  on games that only use 1-3 threads? i dont see that? the amount of threads have nothing to do with that..
Well a bottleneck is when your gpu cannot operate at constant 99% utilisation even though vsync is not enabled, you need really strong per-core performance (on 1-3 threaded applications) to feed a gpu on Titan levels (290x might be above Titan by a bit) which the Piledriver architecture does not offer. It's a fact the FX is going to need heavily threaded applications so that the 290x will be able to throw in the maximum performance it's capable of.
How high of an oc would I need for this to not be a problem? I might possibly upgrade the heatsink (hyper 212 atm) which would allow me to probably get to 4.8-4.9 ghz
I have to admit, the software will be the real bottleneck, as the graphics card can only draw as fast as the CPU can tell it to draw.
Because low threaded games don't allow (indicated bottleneck from the software, not CPU) an 8350 to use all threads, the CPU is only capable of telling the GPU to draw something as fast as it's single cores, which may slow the 290x down more than if more cores were used.
This is why a better CPU will yield better FPS with the same GPU. But with games that only use 1-3 threads, it doesn't accurately represent the computing power of any given CPU.
So, in terms of FPS, a real bottleneck from a CPU would mean a 280x and a 290x + 8350 will result in the same FPS. But that isn't the case (as seen in benchmarks), so we can conclude the 8350 isn't bottlenecking the system. But as aforementioned, the thread usage does hold the CPU back (which holds the fps back a little); in fact, clock for clock a 4350 theoretically will perform as well as a 8350 in a low threaded game. Meaning, again, the software is the bottleneck.
Hahaha you guys are so funny. ''The fx-8350 will bottleneck the R9 290x on 1-3 threaded operations''. Duh, if the operation uses 1-3 threads, you don't even need an R9 290X to run that. You can use an onboard videocard to run those. If a task uses 1-3 cores, it's such a low-performance asking task that you don't need the 8350 and r9 290x.
Some modern game devs are lazy. Take Planetside 2 as an example.
Short ansewr will the R9-290X get bottlenecked by a FX8350 cpu?  NO!
i know what a bottleneck is ☺
Depends on the game. RTS and MMOs will give it the most trouble. Take it how you want from an idiot who impulse bought a 690 for an older 8150 cpu. Waiting for AMD steam roller before I upgrade so i can use more than 40% of my GPU.
Most modern games are programmed in such a way that they primarily utilize only 2 cores. These include high-end games like Battlefield 3, The Witcher 2 etc.
Can anyone tell me how can i know when the processor it makes bottleneck? i am building a pc...and i have the 8350 (but not in use) and i am corious if it makes bottleneck to r9 290x...MisteryAngel...can u give me ur skype? :) if u have and if u want...i really need any informations :) thx
THIS PICKUPLINE HHAHAHA
Bottlenecking is a generally confused and misunderstood phenominon. It seems to me the most common error people make is mistaking system imbalance for bottlenecking.
It's good to balance high end with high end but that has very little to do with bottlenecking until the difference gets quite large.
Check out this video by JayzTwoCents, pretty decent youtuber and a great video on the topic: http://youtu.be/DAgpvWc4VBM
So yeah, MisteryAngel was in there with a succinct and correct answer from the begining.
You people are ridiculous. An FX-8350 will not bottleneck a R9-290X or even a pair of R9-290Xs. If you are using games that only use 2-4 cores they are going to be maxed out at 60 FPS anyway for 1080p. Just from sheer GPU grunt.
As for building for the future of PC gaming, I cannot see why you wouldn't want either 1 or 2 R9-290X graphics cards with an FX-8150 minimum. A pair of these cards will more than likely last a bare minimum of 5 years since the GPU architecture race has come to a slow crawl as of late.
We will likely not see a departure from GCN on AMD's side until at least a year from the posting of this comment. Even then I can't see a massive boost in performance with a smaller fabrication process unless they double the GPU die size of their GPUs. At best if they shrink down to 22nm we may only see a 10-15% performance increase if they keep the same die size.
Just to clarify, the R9-290X is built on a 28nm fabrication process, the same as all current GCN architecture GPUs, but the actual GPU die is about 30% larger than a R9-280X/HD7970 which allows them to get more Pixel shaders, ROPs, and TMUs within a larger package size for more overall performance.
lol
Yes, a 8150 won't bottleneck an expensive gpu at all.
I obviously need dual 690s to play some cpu bound games past medium.
Why are you playing early 2000's CPU dependent games anyway with new hardware? If you are going to play old PC games that were made for the era when CPU power was more important than GPU power, why the fuck are you playing them on new hardware? Build an archaic PC box that plays old games with the hardware they were designed for. Keep it simple Simon.
So Skyrim, FFXIV, and Shogun total war are not modern...?
