Fx-8350 + R9 290x
So,in fact...how can i know WHEN the bottleneck is made? i saw the video from zero_sum but...my english is not that good :) ...i just want to know exactly...i can see the bottleneck from GPU Usage? from a programe wich showing the FPS degrees and ect. ? when the program showing GPU 99%,95,80,75 etc?
Before everyone has a heart attack because i can give an opinion of a 1k gpu on a 200 cpu. Go with the 8350. Because games are heading away from being poorly threaded. On average like 1-2 of 10 games will be poorly coded and you may just have to lower the settings.
Now you are taking this in a different direction, WTF? Now you are saying that games will be better optimized for CPU. That is the point I made from the start with the consoles.
Go through my posts. I never once said go Intel nor said not to go 8350. I just told him there would games like RTSs, MMOs and some gives which are poorly coded and run like shit.
Yeah there are games that are poorly coded and run like that. In that case they may run faster on Intel since they have better single thread performance, but that is no reason to say the 8350 will bottleneck the 290x. The 8350 is just fine and fucking dandy.
Good, now we can both be rational again. I was just saying what I see on my end. Which in some games it does happen. I wish it didn't but I won't lie, and I still recommend the 8350.
You are aware that FFXIV is not a modern game, it's coded around 7 year old hardware ported over from the PS3? You can't honestly expect me to think that game is modern when the hardware it's designed for was designed and bult in 2006.
Batojiri, it seems you know much things...can u give me ur skype if u want? i really need help with informations about 8350 :) i already have it but not in use..
I'm sorry but I do not use skype.
My opinion;
If a 8350 does not bottleneck 2 7970's (tested), I don't see what chance a single 290x has. And ya, not even on a game that uses 1 core.
And if it uses 4 cores, then a 8350 can even balance 2 290x's.
Np Batojiri :) i understand, Egnappahz can you make a video with ur machine? 2x 7970 and 8350 with crysis 3 everything on very high + AA x16/msaa x 8? i wanna see the FPS and everything like degrees and gpu usage, thank you
I saw one site try to use rage3d to benchmark the 280's... i laughed and didn't bother reading the rest of the review.
...rage is a game that hates 7xxx series amd cards and I dont think it will ever be fixed :(
You know XIV was released in 2011 and failed. Then pulled back into development and re-released in September of 2013.
ultimate amd system really, unless you get more grahix cards.
I'm not to sure if you miscounted the roman numeral but here ya go.
http://en.wikipedia.org/wiki/Final_Fantasy_XIV
a nice link to prove that as false. Even says windows as the only platform. It wasn't til ARR tin september 2013 it moved from PC to PS3.
For some reason, I trust this guy. I don't know why...
I'm taking bets none of those tests had the FX-8350 Windows 7 load balancing and CPU core parking hotfixes applied.
Why don't you go ahead and say they were done at an Intel headquarters while you're at it.
some more benchmarks.
one two three four five
http://www.tomshardware.com/reviews/windows-7-hotfix-bulldozer-performance,3119-4.html
I'll humor the hot fixes while I'm at it.
