Dang that cooler looks really good.
My Lepa 850 was perfect and worked great but It just wasn't enough to run the new build.
I purchased the Lepa G1600-MA which is made by Enermax and uses a Enermax board inside.
Nothing but positive reviews on the G1600 from review sites!
The cooler is huge!
I have about an inch of clearance between my side panel and the top of the cpu cooler.
Enermax psu´s or atleast Psu with an Enermax board inside are just rock sollid.
They are expensive but thats the same with seasonic.
They honestly are!
Seasonic is also a great Psu company!
Psh. When I had a Hyper 212 in my NZXT Apollo, I had about 2mm of clearance. You could have flexed the window and touched the heatpipes.
What about a FX-8320 overclocked to 4.0GHz (base) 4.5GHz (turbo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
I picked up a 8350!
Oh wow and I thought I was close lol..
The build looks nice indeed. I got a Deepcool gamerstorm (original) with push-pull noctua NF-F12's.. the thing sticks out past my GPU and is less than half an inch from my side panel lol. It cools very well with the noctua fans.. the stock fan was quiet but didn't perform as well.
http://imgur.com/I5lt0d0
This is an Antec 300. I think your build has a better asthetic
***The wires are the bottom are for my old antec tri-cool fans on the back and side panel of the case...
not bad, but my phanteks is bigger lol ☺
