This release its pretty rock solid from what I've experienced the past month or so with the beta/alpha. Everything's got an extra layer of polish on it
I haven't been keeping up with Fedora as much as I should so I have some questions if you don't mind. In your opinion how does it compare to 25 and also is there any major reason to upgrade vs staying on 24-25?
I tried the KDE Spin (F25) once live (from the ISO) and once on a dedicated SSD and in both cases the GUI froze or become unresponsive in other ways. Mainly while customizing the "task-bar".
So far (in the two hours I have used it) I only noticed subtle differences like cleaner icons and smoother borders, in the new version of GNOME that is.
It's generally more polished across the board. Updated applications, improved back end stuff, improved package management, etc.
I've been quite happy with it. It works well, everything so far has worked without any issues.
If you dont need to wait for 3rd party repos to catch up i would suggest upgrading as it just brings good iterative improvements across the board. If you do need to wait, give it a month or so for other repos to catch up then upgrade. F25 is still in support for a while.
I think I might have some of them. Gnome shell crashes too much, and I have "just a feeling" that other freezes, etc. are happening because of nvidia. : (
Yeah i have read about those Nvidia driver issues with Wayland. However i have an AMD gpu, and my laptops have intel igpu´s. So i cannot really say much usefull about that.
Maybe it's related to Fedora or maybe it's just my combination of hardware, but it hasn't been working out for me so far. I might revisit it at one point, when I upgrade my hardware.
