This post is about my current setup for my VPN. It’s part of my “Easy to follow” series. Hurray, it just became a series, with this being the second entry! Yes, I will come back at the secure firewall, I need to get a new homelab, because the old one is now remote and I don’t want to mess with it too much. Here, I will present how to setup a (Linux) router that you can connect to any WiFi network and share a single VPN connection to all the devices behind it.
Click on any text that has a triangle at the beginning of the line, to expand and read the details inside it.
details
Begin:
What you will need:
1) A linux computer that has at least a WiFi adapter and an Ethernet port
I will be using a Raspberry Pi 3, but you can use any *Pi or other SBC that have WiFi and an Ethernet port. A Pi 4 or something similar would probably make more sense, because it can deliver more bandwidth than the ~300 Mbps that a Pi 3 does through its Ethernet port and probably get faster WiFi speeds too. And it can be powered by a battery bank. Or you can use an old laptop, your choice.
You don’t necessarily need WiFi. You can use this as a baseline for running a Linux firewall and protecting your whole network from your ISP spying on you or something. You can even use 1 ethernet port if you have a managed switch, but I sure wouldn’t recommend that, it’s cheaper to get 2 ethernet ports than a managed switch.
2) An Internet connection (assuming public WiFi)
- It can be your own, but I will pretend it would be an open public WiFi and set firewall rules accordingly
3) A VPN server and configuration files to connect to it
This can be a subscription to a VSP (VPN Service Provider), your own home VPN, or if you want to randomly transform this into a Devember entry, a Linode VPN (use coupon code Level1Techs for $100 Linode credit 60-days free trial! [insert soydev face here]), create a one-click Linode Wireguard server and get started using your own VPN server today!
This tutorial assumes you already have a VPN server, be it wireguard or OpenVPN. If you want to set one up, click here for PLL’s guide, or here and here for Linode marketplace autodeploy.
4) A power outlet / UPS / battery bank / solar panel / power generator
5.1) [optional] a switch (managed or unmanaged)
5.2) [optional] a wireless access point
5.3) [optional] instead of a switch and AP, you could go with an old all-in-one WiFi router and put in in bridge / AP mode
As mentioned, I will use a Pi 3. I’ll be presenting how to do it running Ubuntu 20.04 on it, but you can use any Linux distro, or adapt this to *BSD. If you want a quick rundown of the steps and don’t need any explanation, or if you want a “run and forget” script, jump to “Condensed version” after “Ending Notes.” Also, in the first comment after this tutorial, you will find an Alpine setup guide on the Pi. Use that if you use Alpine and not Ubuntu (note that the Condensed Version script might be compatible with other Debian-based distros).
Connecting to WiFi
So, first thing, power on your device and connect to WiFi. In basically all Linux distros, you’d do:
ip ato find your wireless adapter name (on the Pi 3 on Ubuntu, it’s called “wlan0”).- If you don’t have an existing /etc/wpa_supplicant/wpa_supplicant.conf, create one by using the following commands (edit wlan0 if it’s called something else on your machine):
[ -f /etc/wpa_supplicant/wpa_supplicant.conf ] && cp etc/wpa_supplicant/wpa_supplicant.conf etc/wpa_supplicant/wpa_supplicant.conf.original
cat << EOF > etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant
update_config=1
EOF
On some distros like Gentoo and Void, you’d replace: ctrl_interface=DIR=/var/run/wpa_supplicant with ctrl_interface=/run/wpa_supplicant
- Add your WiFi SSID to your config:
wpa_passphrase "SSID" "password" | sudo tee -a /etc/wpa_supplicant/wpa_supplicant.conf
Note: you can use this command multiple times if you got more than 1 WiFi network you want to connect to. So you’d be running this command every time you need to add a new WiFi connection and wpa_supplicant.conf will memorize it for you.
- Connect to the WiFi network:
sudo wpa_supplicant -B -i wlan0
By default, it should use /etc/wpa_supplicant/wpa_supplicant.conf, but if that doesn't work, use:
sudo wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
sudo dhclient
WiFi works better if you let netplan take care of it. So:
[ -f /etc/netplan/50-cloud-init.yaml ] && sudo cp /etc/netplan/50-cloud-init.yaml /etc/netplan/50-cloud-init.yaml.original
sudo nano /etc/netplan/50-cloud-init.yaml
network:
ethernets:
eth0:
addresses: [10.69.69.1/24]
dhcp4: false
optional: true
nameservers:
addresses: [1.1.1.1, 1.0.0.1]
wifis:
wlan0:
dhcp4: true
dhcp6: true
access-points:
"SSID_NAME":
password: "WIFI_PSK"
version: 2
sudo netplan try
(hit enter if you want to keep the configuration - and you want to if it works)
Note: WIFI_PSK can be plaintext, but I suggest you run wpa_passphrase SSID Password and copy paste the hashed password into 50-cloud-init.yaml file. We will come back to this configuration again later Network configuration.
VPN client installation (does not contain how to configure VPN. Links under `What you will need -> 3) A VPN Server`)
Now that you are connected to WiFi, update your OS and pick the VPN poison client of your choice. Then grab your VPN config, like ovpn conf file and / or its keys and certificates (if it’s split in parts) or configure Wireguard. I won’t get into how to configure those. Check out PLL’s guide to Wireguard linked above, or use sudo openvpn --config /path/to/config.ovpn file (if your config is split with separate keys and ca certs, you can either combine all into one .ovpn file, or use the additional openvpn arguments; if unsure, always man openvpn).
sudo apt-get update
sudo apt-get upgrade -y
sudo apt-get install openssh-server
sudo systemctl enable --now ssh.service
sudo apt-get install -y openvpn
## or if you use wireguard ##
sudo apt-get install -y wireguard wireguard-tools wireguard-dkms
Then proceed to configure it.
Since you are now connected to the VPN, you need to enable routing and add a few iptables rules. To enable routing:
sudo sh -c "echo 1> /proc/sys/net/ipv4/ip_forward"
Making routing permanent and some rabling
You can make the routing permanent and not have to run this command after every reboot, but I discourage it, because if you are doing this setup to hide the devices from a network and make their traffic appear as being somewhere else, you want to make sure you won’t have traffic leakage on, say, the public WiFi network.
To make it permanent, you:
sudo nano /etc/sysctl.conf
(or the editor of your choice) and uncomment this line by removing the # sign:
net.ipv4.ip_forward=1If for some reason the line doesn't exist, just add it at the end of the config file.
Save and exit, then if you don’t echo 1 as instructed above, reboot your system for the settings to take effect (and then reconnect to the VPN).
Now, use ip a to find out the name of your Ethernet port (on the Pi 3 in Ubuntu, it is “eth0”). Add the iptables rules by using the following commands (replace wg0 with tun0 if you are using OpenVPN):
sudo iptables -A INPUT -i wlan0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A INPUT -i wlan0 -j DROP
sudo iptables -A FORWARD -i eth0 -o wlan0 -j DROP
sudo iptables -A FORWARD -i eth0 -o wg0 -j ACCEPT
sudo iptables -A FORWARD -i wg0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -t nat -A POSTROUTING -o wg0 -j MASQUERADE
Some other explanation about the above
- First rule allows responses from the internet to come back to your router. This is required if you don’t want people from the internet or from your local coffee shop WiFi to try to hack your router.
- Second rule blocks any other traffic going into your router. That means that nothing coming from wlan0 is allowed to access your router without your router making a prior connection first. If you want, for example, to connect to SSH from the public wifi to your router, you’d want to add a permit rule on tcp port 22 before the drop rule, so something like:
sudo iptables -I INPUT 2 -p tcp --dport 22 -j ACCEPT
- Third rule blocks traffic incoming from eth0 to go to wlan0, i.e. from communicating with the public WiFi network or making a connection to a website from your real location. This is basically a really dumb “kill-switch,” but that works to block any traffic leaking even before the tunnel exists to begin with, in addition to blocking traffic if the VPN connection drops for some reason. If for some reason you want your devices behind the VPN box to still communicate with the WiFi network, like say for example you are not connected to a public WiFi, but to your home internet, then all you have to do is add rules before the DROP rule. I’m not going to test this, as this is not the scope of this tutorial, but it is doable, just that instead of output interface (wlan0), you have to select a destination network or single IP - obviously, if your home subnet is the same as a public WiFi subnet, this will introduce a potentially unwanted vulnerability. I think there are ways around this if you use ufw or firewalld by defining if the network you are connected to is private or public based on the SSID, but I could be wrong. If you want to improve on this, comment bellow I guess and if it works, I’ll add it to the tutorial in a spoiler or details tag.
- Fourth rule allows traffic coming from eth0 to go through the wireguard or openvpn tunnel (again, replace wg0 with tun0 if you are using OpenVPN).
- Fifth rule allows established traffic coming from the end of the VPN tunnel to go through eth0. If you don’t allow this, you can send traffic (like a ping request) but you won’t be able to receive a response back (like a ping response). You could allow all traffic coming from the VPN to go to the network behind eth0, but that would be insecure, so don’t do that (unless obviously you know exactly what you are doing and have a firewall at the end of the tunnel anyway, in which case you probably don’t need this tutorial).
- Sixth rule enables NAT on the tunnel, so you won’t have to give routes to the network behind your Pi VPN-router box on the devices at the end of the tunnel. If you use a VSP, this is not even possible, since you are not in control of the VPN server.
Making firewall rules permanent and more rambling
Wireguard has a nifty feature where you can run a bunch of commands on connect (“PostUp”) and disconnect (“PostDown”) of a tunnel. You can add the ACCEPT commands in wg0.conf (or however else you named your wireguard config). Instead of “wg0” in the conf file, you’d use “%i” for the wireguard interface (check out PLL’s guide if you’re unsure what I’m talking about). That way you can have a permanent DROP rule from eth0 to wlan0, but still maintain a somewhat dynamic ruleset for when a tunnel is up or down. This is not limited to iptables commands, you can set wireguard to give you a mail if you disconnect (the interface is brought down), just as an example (well, the interface usually stays up, even when you can’t connect to a server, so that’s a bad example, but you get the point).
To make the iptables rules permanent, all you have to do is:
sudo apt-get update
sudo apt-get install -y iptables-persistent
sudo sh -c "iptables-save > /etc/iptables/rules.v4"
I’d suggest the only permanent rule you make is the 1st one, the DROP rule and allow Wireguard to run PostUp and PostDown. For OpenVPN, you can make all of them permanent if you so desire, as the tunnel shouldn’t change to anything other than tun0.
Now, more poison picking. At this point, your traffic from the Pi should be routed through the VPN if configured properly (i.e. no split tunneling). Behind the Pi or the computer of your choice, you can either add an AIO router in bridge / AP mode, a switch, or simply a computer. In my setup, I got a Pi 4 in a metal enclosure (so I cannot use the WiFi on it, so I’m using a Pi 3 to get WiFi… yeah, don’t judge, I know USB WiFI NICs exist).
The easiest thing to do next is static IP configuration. In my case, all I have to do on my Pi 4 (so the Linux device behind the Pi 3 VPN-router box eth0) is to:
sudo ip link set dev eth0 up
sudo ip addr add 10.69.69.2/24 dev eth0
sudo ip route add default via 10.69.69.1
and call it a day. On the Pi 3 side of things, you have to edit netplan config and add a static IP (the same one used in the default route for the Pi 4 above). On Ubuntu 20.04, it’s:
(or your preferred text editor)
And the config should look like:
network:
ethernets:
eth0:
dhcp4: false
optional: true
nameservers:
addresses: [ip1-of-your-favorite-dns,ip2-of-your-favorite-dns]
version: 2
You can stop here and go to the end if the only thing behind your Pi VPN-router box is just a single Linux computer (or just 1 device).
But since we want a whole network behind it and we want to make our lives easier, let’s move along.
If you add an AP or a switch behind the Pi 3, you need to set manual IPs to each device, which gets unwieldy fast after 5 or so devices (subjective, you can manage more than a few dozen and be fine, but come on). So, you need to make your Pi a DHCP server.
Setting up DHCP server
sudo apt-get update
sudo apt-get install -y isc-dhcp-server
sudo nano /etc/dhcp/dhcpd.conf
sudo cp /etc/default/isc-dhcp-server /etc/default/isc-dhcp-server.original
sudo cp /etc/dhcp/dhcpd.conf /etc/dhcp/dhcpd.conf.original
sudo cp /usr/lib/systemd/system/isc-dhcp-server.service /usr/lib/systemd/system/isc-dhcp-server.service.original
After the above is done, you have to edit the 3 conf files you just copied. You can simply delete everything inside them and copy the config files posted bellow, for each file.
sudo nano /etc/default/isc-dhcp-server
Contents of /etc/default/isc-dhcp-server
# Defaults for isc-dhcp-server (sourced by /etc/init.d/isc-dhcp-server)
# Path to dhcpd's config file (default: /etc/dhcp/dhcpd.conf).
DHCPDv4_CONF=/etc/dhcp/dhcpd.conf
#DHCPDv6_CONF=/etc/dhcp/dhcpd6.conf
# Path to dhcpd's PID file (default: /var/run/dhcpd.pid).
DHCPDv4_PID=/var/run/dhcpd.pid
#DHCPDv6_PID=/var/run/dhcpd6.pid
# Additional options to start dhcpd with.
# Don't use options -cf or -pf here; use DHCPD_CONF/ DHCPD_PID instead
#OPTIONS=""
# On what interfaces should the DHCP server (dhcpd) serve DHCP requests?
# Separate multiple interfaces with spaces, e.g. "eth0 eth1".
INTERFACESv4="eth0"
INTERFACESv6=""
Contents of /etc/dhcp/dhcpd.conf
subnet 10.69.69.0 netmask 255.255.255.0 {
range 10.69.69.69 10.69.69.169;
option routers 10.69.69.254;
option domain-name-servers 1.1.1.1;
option domain-name "local";
default-lease-time 600;
max-lease-time 7200;
sudo systemctl enable --now isc-dhcp-server
Explanation
The above will set up a DHCP pool to allocate IPs between 10.69.69.69 to 10.69.69.169, which should be more than enough. Considering that this setup is supposed to run on a public WiFi network through a single WiFi connected router and through a VPN, I doubt you can push that many devices and have a decent experience anyway.
Ending notes
For those of you who want to run a single script at startup (@reboot in crontab), instead of doing all the rules persistent and enabling all the services in systemd at startup, here’s a compressed script with everything that should be happening on the Pi, in order:
sudo sh -c /path/to/startup.sh (bellow is what should be in startup.sh)
dhclient
wg-quick up wg0
Note: I have no idea how to auto-start openvpn without using a plaintext credentials file, so if you want to help, do that in the comments. So if you use openVPN and don’t want to store your authentication details in plaintext, you have to start your Pi, ssh into it from behind the eth0 port (or use a monitor and a keyboard) and start openVPN in a screen session. Then, you have to split startup.sh in 2 scripts: the first one where connect to WiFi, run dhclient, add iptables rules and enabling routing, then second script to connect to the VPN.
Obviously, if you never connected to a WiFi network before, you have to SSH into the Pi (or use a monitor and a kb) and use wpa_passphrase to add a new connection to your wpa_supplicant.conf file (as shown at the beginning of the tutorial).
You can add the above startup.sh script in root user’s crontab (sudo crontab -e -u root) to run at reboot, like:
@reboot /bin/sh -c /path/to/startup.sh
The reason why I didn’t let systemd to do everything is because this tutorial would get a little too complicated. You specifically want these commands to run in order. You can do it in systemd, but you have to specify dependencies in each unit file: start networking@wlan0, then start VPN, then apply the iptables rules, then start dhcp server, then enable ipv4 forwarding. And obviously if you let systemd to its defaults, it will do networking, then in parallel the VPN, networking rules and I think the kernel does the ipv4 forwarding first, so this is definitely not the way you want your VPN-router to behave.
Condensed version
Have not tested this script. I see nothing wrong with it, but do report if there’s any issue.
#!/bin/sh
## VPN-TYPE={ wg , ovpn } ##
echo "What VPN are you using? (wg/ovpn) : "
read ANSWER
[[ "${ANSWER}" != "wg" ] && [ "${ANSWER}" != "ovpn" ]] && echo "Insert wg or ovpn only!" && exit 1
YOUR-USER=${USER}
DEFAULT_PATH="${HOME}"
if [ "${ANSWER}" = "ovpn" ]
then
echo
echo "OpenVPN username: "
read VPN_ACC
echo "OpenVPN password (text will appear blank): "
stty -echo
read VPN_PASS
stty echo
echo
fi
echo
echo "Insert WiFi SSID: "
read SSID_NAME
echo "Insert WiFi password (text will appear blank): "
stty -echo
read WIFI_PSK
stty echo
VAR_FOR_CONF=$(wpa_passphrase "${SSID_NAME}" "${WIFI_PSK}" | sed '/#psk/d')
SSID_NAME=$(printf "${VAR_FOR_CONF}" | grep "ssid" | cut -d "=" -f 2)
WIFI_PSK=\"$(printf "${VAR_FOR_CONF}" | grep "psk" | cut -d "=" -f 2)\"
[ -f /etc/wpa_supplicant/wpa_supplicant.conf ] && sudo cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant.conf.original
cat <<EOF | sudo tee /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
EOF
printf "${VAR_FOR_CONF}" | sudo tee -a /etc/wpa_supplicant/wpa_supplicant.conf
cat << EONF > sudo tee /etc/netplan/50-cloud-init.yaml
network:
ethernets:
eth0:
dhcp4: false
optional: true
nameservers:
wifis:
wlan0:
dhcp4: true
dhcp6: true
access-points:
${SSID_NAME}:
password: ${WIFI_PSK}
version: 2
EONF
sudo netplan apply
sudo apt-get update
if [ "${ANSWER}" = "wg" ]
then
sudo apt-get install -y isc-dhcp-server iptables-persistent wireguard wireguard-tools wireguard-dkms
## remember to have your VPN configured ##
sudo [ -f /etc/wireguard/wg0.conf ] && sudo systemctl enable --now wg-quick@wg0 || echo "WARNING: Manual intervention required. It appears that /etc/wireguard/wg0.conf doesn't exist. wg-quick@wg0 has not been enabled. Please add your wireguard config and systemctl enable it manually."
elif [ "${ANSWER}" = "ovpn" ]
then
sudo apt-get install -y isc-dhcp-server iptables-persistent openvpn
## assuming the first file that will be found will be the .ovpn file ##
## you may want to set it manually here ##
OVPN_CONF=$(sudo find "${DEFAULT_PATH}" -maxdepth 3 | grep -i "\.ovpn$" | head -n 1)
[ -z ${OVPN_CONF} ] && echo "WARNING: Manual intervention required. No .ovpn file found. Add it to your home folder and edit ~/vpn-startup.sh"
echo ${VPN_ACC} > ${DEFAULT_PATH}/.ovpn-credentials
echo ${VPN_PASS} >> ${DEFAULT_PATH}/.ovpn-credentials
chmod 600 ${DEFAULT_PATH}/.ovpn-credentials
echo "#!/bin/sh" > ${DEFAULT_PATH}/vpn-startup.sh
echo "openvpn --config" ${DEFAULT_PATH}/config.ovpn "--auth-user-pass" ${DEFAULT_PATH}/.ovpn-credentials >> ${DEFAULT_PATH}/vpn-startup.sh
chmod u+x ${DEFAULT_PATH}/vpn-startup.sh
sudo iptables -A FORWARD -i eth0 -o tun0 -j ACCEPT
sudo iptables -A FORWARD -i tun0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
sudo crontab -l -u root | sudo tee /root/tmp.txt
sudo /bin/sh -c 'echo "@reboot /bin/sh -c" ${DEFAULT_PATH}/vpn-startup.sh >> /root/tmp.txt'
sudo /bin/sh -c 'cat /root/tmp.txt | crontab -'
sudo rm -f /root/tmp.txt
fi
sudo /bin/sh -c "iptables-save > /etc/iptables/rules.v4"
sudo systemctl enable --now netfilter-persistent
sed 's/^net.ipv4.ip_forward/#net.ipv4.ip_forward/g' /etc/sysctl.conf | sudo tee /etc/sysctl.conf
## I know sed -i works in Ubuntu, but I try my best to keep everything POSIX compliant, screw bashism and gnuism ##
[ -f /etc/default/isc-dhcp-server ] && sudo cp /etc/default/isc-dhcp-server /etc/default/isc-dhcp-server.original
[ -f /etc/dhcp/dhcpd.conf ] && sudo cp /etc/dhcp/dhcpd.conf /etc/dhcp/dhcpd.conf.original
[ -f /usr/lib/systemd/system/isc-dhcp-server.service ] && sudo cp /usr/lib/systemd/system/isc-dhcp-server.service /usr/lib/systemd/system/isc-dhcp-server.service.original
cat << EOISCF | sudo tee /etc/default/isc-dhcp-server
#OPTIONS=""
INTERFACESv4="eth0"
INTERFACESv6=""
EOISCF
cat << EODHCPDF | sudo tee /etc/dhcp/dhcpd.conf
EODHCPDF
sudo systemctl daemon-reload
