The G2 has a single 12V rail with 62.4A
The Nex has four 12V rails from just 20A each.
Which is better then. I do not know anything about that.
The G2 basicly.
What does the ECO mode of the PSU ?
Any suggestions for a PC Case?
That's what am looking for:
Nice look
More/Less 200x500x500 ( Wan't the 200mm to stay or be above )
ATX
Cooling Options: x2 120mm front x1 120mm Behind x2 120mm Up. (Just 1 Behind and 1/2 Front preinstalled)
MAX 50€
All seems in order.
As for the psu its either a cwt or andyson unit under the hood.... If andyson avoid, if cwt then yeah its ok... plenty of corsairs range are cwt units.
Here is a great cheap psu by xfx (seasonic oem) http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9 that would be worth considering.
