In the second example the answer is yes, but you would need to make sure your PS is powerful enough to run both cards. Hint: don't use a cheap crappy power supply.
A question that didn't get answered: My RAM: Corsair XMS3 x2 4GB Can i get the ,, Kingston HyperX Savage x2 4GB " Install them together with the Corsair's for 16 gb?
the boad supports 2 channels of ram so you can put your corsair ram in channel A and the kingston in channel B, they will have to run at the same speed though so you will have to set the speed and timings in the bios otherwise youll just get errors,
I would recommend just sticking with the 8GIG you have and getting a 16gig kit when you have the money so not to run into any probs, and not nurfing the kingston ram down to 1333Mhz
If you're getting a locked CPU, then just use the stock CPU cooler. Its not that bad for the time being. Obviously money is tight and that is an easy way to save some cash. Buy the locked CPU and use the stock cooler. Save 60-125 bucks easy and spend that money elsewhere, or save up for upgrades later.
8GB is basicly still enough for gaming, so i wouldnt botter too much right now. For the cooler, you could indeed use the stock cooler to hold out, untill you have a bit more money to spend. But basicly the the stock cooler, should be capable enough to dissipate 85W TDP from that cpu.
And last thing, i wanted to buy the Enermax 600W 90+ Platinum, but i do not need something like ,,90+ Platinum" , I think ,,80+ Bronze" would be enough and i would save 60€.
Is it worth it to pay the 60€ more for 90+ Platinum or should i stay with the 80+ Bronze. And explain me what are modulars exactly what do I need them for? Where's a difference between ,, 90+ and 80+ " and Bronze to Platinum?
Sadly am planning to go with the ASUS Z97-K MoBo which does not support SLI. If I will upgrade my GPU then i will go for a heavier one taking more Power from the PSU. For GPU's like ,, GeForce GTX Titan X " , i know it's too much and i don't need it it's just an example for any upgrades in next years, about 6.
ah allright, then still i would not buy the Enermax 600W platinum, its way too expensive, atleast in my Country, and platinum does not mean anything realy.
I would say, take a look at the EVGA that i have posted above. The Asus Z97-K does indeed not support sli. 750W should be way enough for a Titan X, it might even be a bit overkill on a Z97 based system.
looks good to me . Like i said the psu is basicly way overkill, but if you want to be prepaired for a Titan X, or any other future upgrades, then yeah you wont have to worry about the psu atleast.
You could also pickup a 650W gold psu, but a decent 650W may only be a €15,- €20,- cheaper maybe. But it just depends a bit where you wanne buy your stuff from.?
i just noticed that you are from the EU, so if you could say me your country, or give me a website where you are looking at for your parts, then i can look with you for a decent psu, European prices are a bit more expensive somethimes.
I'll be purchasing from eBay because of bad experience with Amazon and others. And I am living in Germany so it's not that easy to purchase from a Canadian/American page for me.
