I recently got the Redmagic 11 Pro. I want to remove all of google’s BS and use MicroG but from what I’ve gathered it seems like you need to unlock the bootloader to do that?
I’ve had a go at unlocking the bootloader but it seems like the fastboot command has been removed entirely and due to the fact that the phone was release pretty recently there aren’t any known exploits or work arounds at this point.
I’m wondering if there’s a way I can do what I want without unlocking the bootloader or how far I can get in this state. Or do I just have to accept that I’m stuck with google for a while longer?
You’ll need to unlock the bootloader to change the OS on the phone regardless of which you choose. With the phone being pretty new it will likely take a bit before the devs of any of the degoogled OSes port their software to the phone. If there isn’t a decent user base and request from them to do so, that may not happen (I still have samsung devices that havent got a port so they sit unused).
If privacy and security is a concern than researching what hardware is compatible with the OS you want to run is a good first step. If the phone you have has functions that you want/need than you’ll need to weigh the risk vs reward and audit your personal threat model.
Don’t wanna change the OS, just wanna uninstall/deactivate google services and replace them with MicroG.
I think I can remove the google services with just adb, but it seems like I need root to get MicroG working and I can’t root the Redmagic 11 pro without unlocking the bootloader. I think.
Gotcha. If I remember correctly MiroG only replaces Google Play Services and doesn’t address the permission issues that allow for cross app data collection and some other tracking/logging issues. Depending on what the manufacturer has done to the androidOS they install on the phone there could be other concerns as well. How severe these concerns are depends on your desired level of privacy.
Removing the apps via adb would be the way to go, but Im not sure if you can install microg without access to the recovery. Rooting is afaik not needed for microg.
With the phones I flashed in the past, I always had to install a custom recovery like twrp to be able to install microg, since many stock recoveries dont offer any installation routine or block non signed apps.
