CPU: 11700K
UEFI: Stock (didn’t get a chance to update it), noticed some others are having bigger issues by updating their BIOS or installing ME drivers.
It’s meant to be as simple as installing a .inf file, but I did that, rebooted, and nothing.
I also tried some drivers off the Intel site and it bricked the Win10 install from booting. Thankfully, it’s a new build and I’m just smoke testing it.
If any brave souls have been down this path, care to share some advice?
Thanks tour advice was spot on. Here’s the thing though I did try installing the MEI pack but it errors out just like the version you linked.
I traced the error to a need of .NET v4.6.2. Ok installed. Chipset driver installs fine. Yay!
Intel I225-V no luck. Boo.
Also Asus board is playing up. If I attach a second SSD I can never get my working install to boot. Even if I remove that additional drive. What’s going on? I’ve seen this behavior with my 1950X Threadripper boxes (both with Zenith Extreme mobos. I could never get Win10 to install on them)
You need to change the boot order so the OS loads from the drive you want it to. Go fiddle with the BIOS settings. Also, you should certainly do a clean installation to be on the safe side.
Power off, attach second SSD
Boot off primary via F8
After main Asus F2/Del display second smaller Asus logo and Win10 spinner missing - black display.
Same procedure above but started with both drives attached
Power off, removed the second SSD
Primary no longer bootable.
I’ve done over 6 fresh installs to troubleshoot this.
In can confirm the drives are fine. It’s just that the Asus UEFI looses track of its MBR partition etc. I’ve experienced this same issue before on the Zenith extreme boards.
The trick I used back then when I ran XenServer was to rerun the installer to repair the boot partitions.
I’ll try the Win10 ISO to try and upgrade. Will report soon. Thanks mate.
Well, you shouldn’t use MBR anyway. Go with GPT. How are you shutting the computer down? Doing a reset could trigger such a behavior (holding the power key, switching off the PSU).
What are drive models you have?
